6472 Discussions
why cyclone v soc HPS running linux can only get 200 BogoMIPS?
AWu6
when linux running on cyclone v soc HPS, it can only get 200.00 BogoMIPS as below.
root@socfpga:~# cat /proc/cpuinfo
processor      : 0
model name     : ARMv7 Processor rev 0 (v7l)
BogoMIPS       : 200.00
Features       : half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpd32
CPU implementer : 0x41
CPU architecture: 7
CPU variant    : 0x3
CPU part       : 0xc09
CPU revision   : 0
Hardware       : Altera SOCFPGA
Revision       : 0000
Serial         : 0000000000000000
root@socfpga:~# uname -a
Linux socfpga 4.14.73-ltsi #29 SMP Sun Feb 16 23:33:38 CST 2020 armv7l GNU/Linux
root@socfpga:~#
I'm a little confused about this. when set up HPS in QSYS, CPU main frequency was configured as 800MHz, so i think there was large gap between 800MHz and 200 BogoMIPS for cortexA9, but i don't know why.
i have checked the PLL devide registers value in linux env, related ones were actually set same with configured in QSYS, is there any problem about this?
thanks.
EBERLAZARE_I_Intel
May I know the process of the Linux compilation that was made? OR is this from a prebuilt image used from Rocketboards? Which Linux/version are you using?
Also, what was the booting method, via SD card, QSPI etc?
Was there any error/issue during the booting of preloader/u-boot? Can you share the boot logs for preloader,u-boot,kernel and Linux?
AWu6
Sending discover...
Sending discover...
No lease, failing
Starting portmap daemon...
INIT: Entering runlevel: 5
Starting OpenBSD Secure Shell server: sshd
NET: Registered protocol family 10
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
done.
Starting syslogd/klogd: done
Starting Lighttpd Web Server: lighttpd.
Stopping Bootlog daemon: bootlogd.
Poky 8.0 (Yocto Project 1.3 Reference Distro) 1.3 socfpga_cyclone5 ttyS0
socfpga_cyclone5 login: root
root@socfpga_cyclone5:~# cat /proc/cpuinfo
Processor      : ARMv7 Processor rev 0 (v7l)
processor      : 0
BogoMIPS       : 1594.16
processor      : 1
BogoMIPS       : 1594.16
Features       : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls
CPU architecture: 7
CPU variant    : 0x3
CPU part       : 0xc09
CPU revision   : 0
Revision       : 0000
this is the prebuilt image from rocketboards.org, boot from SD CARD. so huge gap.
AWu6
hi El,
  -- not prebuilt image. compiled myself, linux version is Linux socfpga 4.14.73-ltsi, download from https://github.com/altera-opensource
compiler is download from linaro
 booting from NAND FLASH.
yes, of course, i will post it later. by the way, rootfs come from the EDS installation directory.
AWu6
Hi El,
boot info as below:
U-Boot SPL 2013.01.01 (Dec 04 2019 - 18:04:45)
BOARD : Altera SOCFPGA Cyclone V Board
------current cpu : 0 ------
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 3125 KHz
CLOCK: QSPI clock 400000 KHz
RESET: WARM
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
NAND: Denali NAND controller
U-Boot 2013.01.01 (Dec 04 2019 - 18:07:52)
CPU  : Altera SOCFPGA Platform
I2C:  ready
DRAM: 1 GiB
NAND: NAND: Denali NAND controller
512 MiB
MMC:  ALTERA DWMMC: 0
In:   serial
Out:  serial
Err:  serial
Net:  mii0
Hit any key to stop autoboot: 0
printer-loader #
AWu6
Hi El,
this is linux booting info:
NAND read: device 0 offset 0x180000, size 0x80000
 524288 bytes read: OK
## Starting application at 0x3FF5A5A4 ...
## Application terminated, rc = 0x0
## Flattened Device Tree blob at 00a00000
  Booting using the fdt blob at 0x00a00000
  Loading Device Tree to 03ff7000, end 03fffe5d ... OK
Starting kernel ...
[   0.000000] Booting Linux on physical CPU 0x0
[   0.000000] Linux version 4.14.73-ltsi (root@localhost.localdomain) (gcc version 4.9.4 20151028 (prerelease) (Linaro GCC 4.9-2016.02)) #16 SMP Sun Feb 16 23:03:21 CST 2020
[   0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[   0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[   0.000000] OF: fdt: Machine model: Altera SOCFPGA Cyclone V
[   0.000000] Memory policy: Data cache writealloc
[   0.000000] percpu: Embedded 44 pages/cpu @ddbcd000 s150720 r8192 d21312 u180224
[   0.000000] Built 1 zonelists, mobility grouping on. Total pages: 121920
[   0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock6 rw rootfstype=jffs2 init=/init mem=480M log_buf_len=1048576
[   0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[   0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[   0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[   0.000000] Memory: 472776K/491520K available (8192K kernel code, 532K rwdata, 1628K rodata, 1024K init, 1158K bss, 18744K reserved, 0K cma-reserved, 0K highmem)
[   0.000000] Virtual kernel memory layout:
[   0.000000]    vector : 0xffff0000 - 0xffff1000  (  4 kB)
[   0.000000]    fixmap : 0xffc00000 - 0xfff00000  (3072 kB)
[   0.000000]    vmalloc : 0xde800000 - 0xff800000  ( 528 MB)
[   0.000000]    lowmem : 0xc0000000 - 0xde000000  ( 480 MB)
[   0.000000]    pkmap  : 0xbfe00000 - 0xc0000000  (  2 MB)
[   0.000000]    modules : 0xbf000000 - 0xbfe00000  ( 14 MB)
[   0.000000]      .text : 0xc0008000 - 0xc0900000  (9184 kB)
[   0.000000]      .init : 0xc0c00000 - 0xc0d00000  (1024 kB)
[   0.000000]      .data : 0xc0d00000 - 0xc0d85358  ( 533 kB)
[   0.000000]       .bss : 0xc0d8ba3c - 0xc0ead4d0  (1159 kB)
[   0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[   0.000000] ftrace: allocating 26827 entries in 79 pages
[   0.000000] Hierarchical RCU implementation.
[   0.000000] RCU event tracing is enabled.
[   0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[   0.000000] L2C-310 erratum 769419 enabled
[   0.000000] L2C-310 enabling early BRESP for Cortex-A9
[   0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[   0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[   0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[   0.000000] L2C-310: CACHE_ID 0x410030c9, AUX_CTRL 0x46060001
[   0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
[   0.000006] sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 21474836475ns
[   0.000019] Switching to timer-based delay loop, resolution 10ns
[   0.000247] GIC: PPI13 is secure or misconfigured
[   0.000280] GIC: PPI13 is secure or misconfigured
[   0.000442] Console: colour dummy device 80x30
[   0.000469] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=1000000)
[   0.000484] pid_max: default: 32768 minimum: 301
[   0.000603] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[   0.000614] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[   0.001141] CPU: Testing write buffer coherency: ok
[   0.001361] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[   0.001660] Setting up static identity map for 0x100000 - 0x100060
[   0.001779] Hierarchical SRCU implementation.
[   0.002273] smp: Bringing up secondary CPUs ...
[   0.002692] smp: Brought up 1 node, 1 CPU
[   0.002705] SMP: Total of 1 processors activated (200.00 BogoMIPS).
[   0.002713] CPU: All CPU(s) started in SVC mode.
[   0.003474] devtmpfs: initialized
[   0.008026] random: get_random_u32 called from bucket_table_alloc+0xfc/0x250 with crng_init=0
[   0.008300] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[   0.008502] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[   0.008521] futex hash table entries: 512 (order: 3, 32768 bytes)
[   0.857848] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xdc
[   0.864180] nand: Micron MT29F4G08ABADAWP
[   0.868223] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[   0.877649] Bad block table found at page 262080, version 0x01
[   0.884655] Bad block table found at page 262016, version 0x01
[   0.891826] 8 ofpart partitions found on MTD device denali-nand
[   0.897748] Creating 8 MTD partitions on "denali-nand":
[   0.902956] 0x000000000000-0x000000080000 : "NAND Flash Boot Area 512KB"
[   0.910558] 0x000000080000-0x000000100000 : "NAND Flash u-boot 512KB"
[   0.918177] 0x000000100000-0x000000180000 : "NAND Flash u-boot parameters 512KB"
[   0.926673] 0x000000180000-0x000000200000 : "NAND Flash FDT 512 KB"
[   0.933932] 0x000000200000-0x000000e00000 : "NAND Flash fpga config rbf file 12 MB"
[   0.942726] 0x000000e00000-0x000001400000 : "NAND Flash kernel 6 MB"
[   0.950306] 0x000001400000-0x000011400000 : "NAND Flash ubi rootfs 224 MB"
[   0.959677] 0x000011400000-0x000011e00000 : "NAND Flash baremetal image 10 MB"
[   0.968323] cadence-qspi ff705000.flash: couldn't determine fifo-depth
[   0.974830] cadence-qspi ff705000.flash: Cannot get mandatory OF data.
SimoneBo
I'm facing with the same issue....
Boot logs show me:
" Switching to timer-based delay loop, resolution 10ns
  Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=1000000) "
Moreover I'm getting a slower boot time respect when I used a 3.10.36-ltsi linux-socfpga kernel.
@AWu6 did you get a slower boot too? Did you find a fix for that issue?
@EBERLAZARE_I_Intel, I think is a Devices Tree related issue, may you share an example of dts working on 4.x linux-socfpga kernel?
Thanks a lot in advance,
Simone
AWu6
Hi Simon,
    not fix 200 BogoMIPS issue, i can't get any more help about this issue, and i have checked PLL configuration, it's configured as 800MHz main clock frequency.
    for slow boot issue, i think it may be related to your boot media speed, such as NAND FLASH or QSPI FLASH. i have encountered it, root cause is low speed configure of NAND FLASH controller.
best regards
alex
SimoneBo
HI AWu6,
thanks for the replay.
The slow boot, and generally the low performance of the processor was caused by a wrong definition of clocks/PLL/oscillators section in the devices tree. I update that device tree section with one found in linux-socfpga, (4.14.x) and everything goes well. Slow boot and generally low performance disappeared.
That devices tree works well with 3.10.x kernel but with 4.14.x no.
With the old device tree seems that the 4.14.x kernel started using a clock frequency lower than 800MHz. No one log or indication was present at startup in boot logs.
Have a good day,
Simone
minmax
Hi @SimoneBo,
I'm facing the same issue on DE10-nano platform and kernel 4.14 or later.
I tried to add some changes to device tree referring .dts file created by sopc2dts and put the updated dtb file to my system, but I was not able to solve this issue. I still see 200.00 BogoMIPS.
Could you kindly tell me what changes you applied to dts file ?
minmax
SimoneBo
Hi @minmax ,
I still see "200.00 BogoMIPS" but I can see that the overall performances was heavily improved.
I updated, in .dts file, the clocks/pll section as  reported in 4.14.x of linux-socfpga git repo.
Simone
minmax
Hi @Simone,
I see. I got your situation. Thank you.
Since I already used the latest dts file of 4.14.x branch of linux-socfpga git repo, it seems that I'm now on the same page of you.
I hope 200 BogoMIPS issue itself will be fixed in the future.
minmax
vrbavojtech
I am still facing the same issue with Linux kernel 5.19 + u-boot v2022.10. What exactly did you update in the device tree section to make the MPU clock frequency 800MHz?
Thanks in advance.
Vojtěch
AWu6
Hi El,
btw, i want boot dual core for SMP and the kernel configured as SMP, but only one core booted, so i want to know how to boot dual core for SMP? is there any thing need configured in preloader or uboot?
best regards
alex
EBERLAZARE_I_Intel
Hi Alex,
Unfortunately, we do not have design examples on SMP boot up to help your exact issue.
Let me dig in the information for you. I will let you know once I got them.
In the mean time, you may check this forum post discussing similar issue to yours, please check it out:
https://forums.intel.com/s/question/0D50P00003yyKvTSAU/how-do-i-boot-hps-of-cyclone-v-soc-on-amp
Regards.
EBERLAZARE_I_Intel
Hi Alex,
Based on my findings, the bogomips in your design are supposedly 200 for each core, thus 400 in total, but since there is one in the system thus showing only 200.
If you are facing any othre issues/error kindly let me know.
Eber.
