Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
This design example allows you to simulate Altera 100Gbps Ethernet IP Core that does not include MAC so that you can get the better understanding how the control/status signals behave. Please note that this is not for Altera Low Latency 100Gbps Ethernet PHY IP Core.
Quartus Prime Software version 16.0.2 ModelSim-SE 10.4d
do run_1sttime.tcl
If you get error messages on Quartus install directory:
The minimum pulse width requirement for both status_read and status_write is one clk_status cycle. The read latency is supposed to be variable, thus you have to wait for status_readdata_valid to complete the read operation.
The 100Gbps Ethernet PHY IP Core has DC-FIFO inside to compensate the clock frequency difference between the MII TX clock (clk_txmac, 315.0 MHz or higher frequnency) and the internal 312.5 MHz clock. To avoid FIFO overflow/underflow, tx_mii_valid must be deasserted for the same cycles as tx_mii_ready, and the tx_mii_valid deassertion shouldn't be later than a few clock cycles after tx_mii_ready deassertion since the FIFO depth is shallow. The TX PHY accepts START (data = 8'hFB, control = 1'b1) located only on mii_tx_data[7:0]/[71:64]/[135:128]/[199:192]/[263:256]. If the START is mapped to wrong byte positions, the TX PHY generates error codes (data = 8'hFE, control = 1'b1).
The RX also has DC-FIFO to compensate the clock frequency difference between the internal 312.5 MHz and the MII RX clock (rx_macclk, 315 MHz or higher frequency). Your logic needs to expect the rx_mii_valid can be deasserted during frame receptions.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
