10Gbps Ethernet MAC Debug Checklist
cancel
Showing results for
Search instead for
Did you mean:
Last Major Update
February 14, 2015
Objective
The objective of the wiki page is to provide a useful debug guideline and checklist which help to debug and identify issue related to Altera 10Gbps Ethernet MAC Megacore in order to resolve it effectively.
10Gbps Ethernet MAC Architectures & Signals comparison
Architectures: 7/74/10GbE_MAC_Architecture_comparison_1.png
Signals:
0/0f/10GbE_MAC_Signals_Comparison.png
a/a6/10GbE_MAC_Signals_Comparison_1.png
MAC + PHY Ethernet Solution
In a MAC + PHY Ethernet System, how to identify the issue: User Error? PHY Issue? MAC Issue?
c/c1/MAC_PHY_Solution.png
Thus, we need a proper Debug Checklist or guidance in order to root cause the issue.
Debug Checklist
Things to do before start debugging:
1. Understand the problem statement/requirement.
2. ACDS Version/IP Version/Target Device/LL MAC IP variants (Speed variant, adapters enable/disable, etc)
3. Check Fogbugz/KDB/Errata.
4. Crosscheck with the IEEE 802.3 Specification and Avalon Specification
5. MAC IP variants
- 10G, 1G/10G or multi-speed 10M-10G.
- MAC Options: supplementary Address, CRC on transmit Path, Statistic counter,Preamble pass-through mode, PFC.
- TIPS1: Get the 10G Verilog/VHDL Wrapper that generated by the Megawizard.
6. Configuration Register Settings
7. Timing Closure – hardware issue
8. Debug Information
- Hardware vs. Simulation
-Failing symptom: Intermittent or consistent
-Transmitter issue vs Receiver issue
9. Simplify design or test case if necessary
10. Follow the debug flow(as shown below).
Debug Flow -10G Ethernet Issue
3/3e/Debug_flow.png
Debug Step - 1st Level Check
■ Ensure all signals connected to MAC IP appropriately.
-Avalon-ST , Avalon-MM, SDR XGMII, GMII, MII interfaces
■ Ensure all clocks are operating at their specified frequencies.
-tx_clk, rx_clk, gmii_tx_clk, gmii_rx_clk, csr_clk
■ Ensure all resets are released and clocks are available.
■ Transmitted /Received input data are available.
■ Make sure no timing violation and clocks are constraint correctly.
Example of correct MAC+PHY connection�10G MAC + XAUI/10G Base-R PHY Interface
3/3c/10GMAC_10GBaseR_PHY.png
Clock Frequency for 10G Ethernet System
b/b4/Clock_freq_10G_Ethernet_system.png
Debug Step - 2nd Level Check
6/61/Debug_flow_2nd_level.png
If the problem cannot be solved with 1st level debug check , please follow the 2nd level debug check:
■ Always look at the interface to identify the error.
-Avalon-ST
-Avalon MM
-MAC-PHY Interface (MII/GMII/XGMII)
-Status signals (Speed_sel, link_fault_status, led_link,pll_locked, rx_data_ready)
-Always read out MAC Transmit /receive statistic counter to identify the packet condition sent/received by MAC.
■ Perform MAC local loopback to verify the functionality of the MAC.
■ Perform MAC+PHY serial loopback
■ Replicate issue with ACDS design example /Reference design
TIPS 2: Always get some data for analysis
-Gather all the information and compare with the expected
- User guide descriptions
- IEEE802.3 Specification
- Avalon-ST protocol
- UNH test plan
- Simulation result
-Duplicate the issue in house with ACDS example design / Reference design published on altera-wiki web.
- “..\ip\altera\ethernet\altera_eth_10g_design_example”
These example designs and reference designs can be used as a common entity for simulation and hardware verification purposes.
Case Studies
Case Study 1
  • Problem Statement:
- Packet sent on Avalon Streaming interface to MAC but no data received by PHY
  • Debug Steps:
1. Check MACPHY XGMII interface signals, no data sent out from MAC.
2. Check Link Fault status signal, value 01 (Local Fault).Local fault happens, all data sent by client user logic are dropped.
-Avalon ST TX and RX input/output signals to Avalon ST TX/RX 64 bit adapter
TIPS 3 : Before transmitting any data, make sure the link is ready:
1. rx_data_ready = 1'b1
2. link_fault_status_xgmii_rx_data = 2'b00
Case Study 2
- MAC registers Write/Read issue:
Failed to read back rx_pfc_control register value
MAC statistic counter read back wrong value
 e/ea/Case_study_3.png
c/c0/Case_study_3_1.png
  • Debug steps:
1.Check MAC variant:
d/d8/Case_study_3_2.png
Root Cause: Due to resource optimization, register logic is being optimized away because the feature is not available. Unexpected result obtained.
TIPS 4: Ensure Statistic collection and priority flow control option are enabled before try to access the related registers.
Case Study 3
- Ethernet failed to change speed:
  • Debug steps:
1.Check Avalon-MM interface
Root Cause: Write to PHY 0x2c0 register for speed change during rc_busy period.
 4/49/Case_study_4.png
TIPS 5: Expected simulation for ethernet speed changes from 10G to 1G to 100Mto 10M
 2/27/Case_study_4_1.png
8/8b/Case_study_4_2.png
Summary
-Debug the 10G MAC IP can be easy if follow a proper debug steps.
-Remember the recommended items in the checklist before debugging.
-Follow the 5 tips provided.
Version history
Last update:
‎06-26-2019 02:55 PM
Updated by:
Contributors
