Altera 1588 System Level Solution
cancel
Showing results for
Search instead for
Did you mean:
Last Major Update
February 14, 2015
Objective
The objective of the wiki page is to provide an overview to user about Altera 1588 solution at a system level and positioning of Altera’s Ethernet MAC and PCS+PMA with 1588 hardware IP capable of time-stamping PTP packets with very high accuracy down to a few nanoseconds.
Introduction
IEEE 1588 v2 (IEEE Standards Association, 2008) is standard that defines a precision timing protocol (PTP) used in packet networking to precisely synchronize the real time-of-day (ToD) clocks and frequency sources in a distributed system to a master ToD clock, which in turn is synchronized to a global clock source. With the advent of 1588 v2, it makes synchronization to the tune of nanoseconds within packet networks, enabling low-cost phase and frequency synchronization in applications such as wireless, mobile backhaul, wireline and industrial instrumentation potentially replacing the costlier TDM networks used for similar purposes. The 10M-10G Ethernet low-latency MAC and PCS+PMA (PHY) 1588 solution from Altera supports a static error of +/- 3ns across the throughputs of 10Gbps, 1Gbps & 100Mbps with the random error of +/- 1ns, +/- 2ns, and +/- 5ns from the PHY for the throughputs of 10Gbps, 1Gbps & 100Mbps respectively.
For more details of Altera 1588 information, please refer to :Altera_1588_solution
The document attached covers:
■ System Level Block diagram involving Altera Ethernet +1588 IP ; TOD, MAC+PHY 1588 IP ,Packet Parser, CPU and FIFO/CAM.
■ 1-step mechanism and 2-step mechanism
■ 1588 Synchronization process between master and Slave clocks
■ PTP clocks : Ordinary Clock, Transparent Clock and Boundary Clock
■ 1588 master/slave functional flow of Altera 1588 hardware IP in different PTP clock
Version history
Last update:
‎06-21-2019 06:38 PM
Updated by:
Contributors
