Arria 10 Transceiver PHY Pin Planning
cancel
Showing results for
Search instead for
Did you mean:
Arria 10 Pin Planning Design (Unofficial)
How to use Arria 10 Pin Planning tool to quickly develop and validate your transceiver based design.
Arria 10 Pin Planning Documentation Example 1
The document link below describes how a user can quickly develop an A10 pinout using some of the common IP’s that are used for Transceiver based systems. This includes the fundamental building block of the Native PHY, and other IP’s such as Hard PCIe (Gen 2 and Gen3) and the TSE(Triple Speed Ethernet) IP.
File:Using the A10 Pin Planner design v001.zip
Arria 10 Pin Planning Design Example 1
This design example shows implementation of Native PHY, and other IP’s such as Hard PCIe (Gen 2 and Gen3) and the TSE(Triple Speed Ethernet) IP.
Arria 10 Pin Planning Design File 1
File:FPGA TOP A10 Pin Planner Design.qar
Arria 10 Pin Planning Design Specifications
The table below lists the specifications for this design:
AttributeSpecification
DeviceArria 10
Quartus versionQuartusII v14.0a10s
Modelsim versionModelsim SE v10.4d
DatarateVarious
Data patternVarious
Number of channelsVarious
IP usedNative PHY IP,ATX PLL IP, fPLL IP,Transceiver PHY reset controller
Arria 10 Pin Planning Documentation Example 2
The document link below describes how a user can quickly develop an A10 pinout using some of the common IP’s that are used for Transceiver based systems. This includes the fundamental building block of the Native PHY, and other IP’s such as Hard PCIe (Gen 2 and Gen3), TSE(Triple Speed Ethernet),XAUI, 10G Base-KR, Seriallite III, LL 10G/40G, Interlaken, JESD204B IP.
File:Using the A10 Pin Planner design v002.zip
Arria 10 Pin Planning Design Example 2
This design example shows implementation of Native PHY, and other IP’s such as Hard PCIe (Gen 2 and Gen3) TSE(Triple Speed Ethernet),XAUI, 10G Base-KR, Seriallite III, LL 10G/40G, Interlaken, JESD204B IP.
Arria 10 Pin Planning Design File 2
DeviceArria 10
DatarateVarious
Data patternVarious
IP usedNative PHY IP,ATX PLL IP, fPLL IP, Transceiver PHY reset controller
© 2013 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate. Retrieved from http://www.alterawiki.com/wiki/Altera_Wiki
Version history
Last update:
‎06-21-2019 08:46 PM
Updated by:
Contributors
