Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
This wiki pages assumes you have basic familiarity with HyperLynx DRC too. If you would like to learn more about this tool please visit the HyperLynx DRC page.
This page is created to help you test your board layout against Altera External Memory Interfaces (EMIF) guildelines, using MentorGraphics HyperLynx DRC tool. We have identified some of these guidelines to be critical in interface functionality. We also understand that during post layout checks, these guidelines are difficult to manually verify which motivated us to work with Hyperlynx DRC and automate the checking of these critical guidelines. For each of these critical guidelines, we have created custom rules in HyperLynx DRC and are providing the following information to help you better understand the usage and violation reporting of each rule:
Description: A brief overview of which Layout Guideline this rule checks and any other necessary info to help you better understand the guideline.
Input Object List: The input needed to run the rule. For these rules usually means an object list that contains the electrical nets being tested.
Parameters: Parameters allow you to modify some options within the rule. All parameters are by default set to Altera recommended values, but you may test your design at different values when necessary.
Violations: For every violation within each rule a row is added to the violation report with details regarding the violation. In this section,we explain what kind of information is provided with each violation so you can find and fix those violations faster.
https://www.youtube.com/watch?v=joaef_YpxGc
Now you have imported all the guidelines into HyperLynx DRC. To run a specific rule:
To run all rules at once:
The length of all electrical nets checked must be within a maximum length specified
The object list of all electrical nets to be checked
Maximum Length: Maximum length requirement; i.e., all nets must be less than or equal to this length. Default is 4.5 inches.
Include Package Length: Yes=include package length for length calculation. No= exclude package length for length calculation.
Net length is longer than maximum length specified
Net delays in a net group must be within the maximum allowed skew. For DQ/DQS/DM signals within a DQS group, default value for max skew is 20ps.
The object list of all DQ/DQS/DM nets to be checked
Max Skew: Maximum allowable skew for total delays. Default is 20ps.
Include Package Delay: Yes= include package delay for total net delay calculation.No= do not include package delay for total net delay calculation. You must select Yes here if your board traces compensate for package skew mismatch. If Yes is selected, you must run Add Pin Package Delay script first to provide the necessary info.
Calculate Propagation Delay from Stackup: Yes= propagation velocity is calculated from the field solver using the board stackup information.No= 167 ps/in will be used as signal propagation velocity.
Net Delay Mismatch:The two identified nets are not within the maximum allowed skew
All the address and command signals must be delay matched compared to clock traces within the tolerance specified.
x = y +/- 20 ps
x + x1 = y + y1 +/- 20 ps
x + x1 + x2 = y + y1 + y2 +/- 20 ps
x + x1 + x2 + x3 = y + y1 + y2 + y3 +/- 20 ps
None. All necessary information is given to the code through parameters.
Reference Object List: The name of the object list containing all the clock traces to which other traces are compared
Target Object Lists: The names of a set of object lists that contain address, command, and control nets. Multiple object lists can be specified using comma separated value format; for example: objList1, objList2.
Maximum Tolerance: Maximum skew allowed for a address, command, or control net to be different from any clock net. The default is 20ps.
Include Package Delay: Yes= include package delay for total net delay calculation; No= do not include package delay for total net delay calculation. You must select Yes here if your board traces compensate for package skew mismatch. If Yes is selected, you must run Add Pin Package Delay script first to provide the necessary info.
Calculate Propagation Delay from Stackup: Yes= propagation velocity is calculated from the field solver using the board stackup information. No= 167 ps/in will be used as signal propagation velocity. Recommendation is to use Yes.
Delay Matching Violation: The delay of the identified net is greater or less than at least one clock net.
Maintain at least 3H spacing between the edges (air-gap) these traces. Where H is the vertical distance to the closest return path for that particular trace.
An object list of all electrical nets to be checked. The object list must only contain Data, Data Strobe, and Data Mask nets.
Space Multiple: The number of spaces or H (as mentioned in description) which the code will use to determine whether two traces are too close or not. Space (H) is the distance to the closest return path for the net with a bigger H (out of the two nets being compared). Default value is 3.
If two nets within the object list have segments that are parallel and closer than minimum distance, then a violation is thrown. The script reports the violating segments with the longest parallel overlap, not the violating segments with the smallest distance between them. If two nets are too close at a point (vs parallel lines) or they cross over each other (on different layers of course), it is not a violation.
For Address/Command/Control traces: Maintain at least 3H spacing between the edges (air-gap) these traces. Where H is the vertical distance to the closest return path for that particular trace.
For Clock traces: Maintain at least 5H spacing between two clock pair or a clock pair and any other memory interface trace. Where H is the vertical distance to the closest return path for that particular trace.
An object list which contains all address, command, and clock nets to be checked. The list must only contain these signals.
Space Multiple: The number of spaces (H) which the code will use to determine whether two non-clock traces are too close or not. Space is the distance to the closest return path for the net with a bigger H (out of the two nets being compared). The default value is 3.
Space Multiple for Clock Traces: The number of spaces (H) which the code will use to determine whether a non-clock trace is too close to a clock trace or two clock traces are close to each other. Space(H) is the distance to the closest return path for the net with a bigger H (out of the two nets being compared). The default value is 5.
If two nets within the object list have segments that are parallel and closer than the minimum distance, then a violation is thrown. The script reports the violating segments with the longest parallel overlap, not the violating segments with the smallest distance between them. If two nets are too close at a point (vs parallel lines) or they cross over each other (on different layers of course), it is not a violation.
Below mentioned leveling rules are only applicable for fly by typologies only. For now, the DRC tool only allow you to check the leveling rules for Discrete component based interfaces. The DRC tool doesn't have a way to encorporate DIMM delays in to the calculation
The timing between the DQS and clock signals on each device calibrates dynamically to meet tDQSS. To make sure the skew is not too large for the leveling circuit’s capability:
1. Propagation delay of clock signal must not be shorter than propagation delay of DQS signal at every device:
(CKi) – DQSi > 0; 0 < i < number of components – 1
2. Total skew of CLK and DQS signal between groups is less than one clock cycle:
(CKi + DQSi) max – (CKi + DQSi) min < 1 × tCK
If you are using a DIMM topology, your delay and skew must take into consideration value for the actual DIMM.
None. All input information gets provided through parameters.
DQS Object List: The object list that contains all DQS nets.
CLK Object List: The object list that contains all clock nets
Maximum Skew: Maximum skew allowed for DQSi+CLKi between different groups; the default value is 1600 ps. Please ensure the parameter type is string and you only enter a numerical number in unit of pico seconds
Include Package Delay: Yes= Include package delay for total net delay calculation. No= do not include package delay for total net delay calculation. If Yes is selected, you must run Add Pin Package Delay script first to provide the necessary info.
Calculate Propogation Delay from Stackup: Yes= propagation velocity is calculated from the field solver using the board stack up information. No= 167 ps/in will be used as signal propagation velocity
DQS after CLK: If delay of the DQS net is greater than any net in the CLK Object List. The error will show you both DQS and clock nets violating this rule as well as the delay difference.
Maximum Skew: If the maximum skew for DQSi + CLKi between different groups exceed maximum skew
This rule does not check for any physical violation. This is more like an add on script that you have to run before you run your Data and Address/Command skew matching rules If you have deskewed for package skew mismatch on the PCB, then you must run this rule so the following rules take that into consideration when running. Be sure to run it before running each of the following rules.
If you have not deskewed, then no need to run and please select No for this option at each of the above rules.
None
Comp RefDes:The reference designator of the FPGA. This is the prefix to all pin names in the targeted FPGA.
PPD Filename:Name of the package file which contains all pin package delays for the specified FPGA. The file must be in CSV format with the following template: Column A = Pin Number, Column B = Total Delays(ps), Column C = Total Length(mm). If you do not have the package delay file or the file you have does not have the above mentioned format then please contact Altera Support.
If either parameters are left empty, or the file names entered cannot be found within the script folder, a violation is submitted.
