Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
BeMicro Max 10 is an FPGA Evalution Kit produced by Arrow Electronics. It is available at http://www.arrow.com/bemicro/
BeMicro Max 10 adopts Altera’s non-volatile MAX 10 FPGA built on 55-nm flash process. Users can take advantage of the features Altera offers in the MAX 10 FPGA device, such as an ADC block, temperature sense diode and flash memory. BeMicro Max 10 includes a variety of peripherals connected to the MAX 10 FPGA such as 8MB SDRAM, accelerometer, digital-to-analog converter (DAC), temperature sensor, thermal resistor, photo resistor, LEDs, pushbuttons and several different options for expansion connectivity.
Features Altera MAX 10 FPGA with ADC block, temperature sense diode, onchip-RAM, user flash memory and non-volatile self-configuration.
When reading the MAX®10 ADC channels on the BeMicro Max 10 the value that is read by the ADC differs from what is measured using an external oscilloscope. This constant offset reading occurs because there is an incorrect voltage connection on I/O Banks VCCIO1A and VCCIO1B (originally set to 3.3V).
To correct this issue, VCCIO1A and VCCIO1B need to be connected to a 2.5V rail for this dual-supply device.
This is a full day lab in which the user will build a complete Nios II processor based system using the QSys system integration tool.
Note: you may need to modify the bemicro_max10_serial_flash_controller_hw.tcl in the IP directory for Quartus 15.0 and later Line 20 calling out supported devices, change MAX10FPGA to MAX10 (this will be needed for Quartus 15.0 and later) without this change, the IP will be grayed out in Qsys.
Example designs are now being supported in Altera's Design Store. The links below for the project archive will take you to the latest version on the Altera design store.
WARNING: There is a pin assignment error in the template project below. The following pin pairs on J4 are swapped: 11/12, 13/14, 15/16, 17/18, 19/20, 21/22, 23/24, 25/26, 27/28, 29/30, 31/32, 33/34, 35/36, 37/38, 39/40.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
