Bemicro cv
cancel
Showing results for
Search instead for
Did you mean:
Bemicro cv
Bemicro cv
9/9c/Top_view.PNG
BeMicro CV (Cyclone V) FPGA Evaluation Kit
The BeMicro CV Cyclone V E FPGA Development Board features an Altera 28-nm Cyclone V FPGA in the familiar BeMicro form factor. The Altera 5CEFA2F23C8N Cyclone V FPGA resident on the Be Micro CV features a hardened memory controller (HMC) that supports DDR2, DDR3 and LPDDR2. On the BeMicro CV the HMC is connected to a single 16-bit wide, 1Gb DDR3 SDRAM device (U1).
Board Highlights
The BeMicro CV board features the following major component blocks:
  • One Cyclone V E FPGA (5CEFA2F23C8N) in a 484-pin FineLine BGA (FBGA)
  • 25,000 LEs
  • 9,434 adaptive logic modules (ALMs)
  • 1,760 Kbit (Kb) M10K and 196 Kb MLAB memory
  • 4 fractional phase locked loops (PLLs)
  • 50 18x18-bit multipliers
  • 1 Hard Memory Controller
  • 224 general purpose input/output (GPIO)
  • 1.1-V core voltage
  • FPGA configuration circuitry
  • Active Serial (AS) x1 configuration (EPCS16I8N)
  • Embedded USB-BlasterTM II for use with the Quartus® II Programmer
  • Separate JTAG configuration header
  • Clocking circuitry
  • 50 MHz 1.8V oscillator
  • 24 MHz 2.5V oscillator
  • Memory
  • 1Gbit DDR3 SDRAM (8 Meg x 16 x 8 banks)
  • 1K (128 x 8) Two-wire Serial EEPROM
  • Micro SD card slot
  • General user input / output
  • 8 user LEDs
  • 2 User Pushbuttons
  • 3 User DIP switches
  • Prototyping
  • 2 Terasic 40 pin prototyping headers
  • BeMicro SDK 80-pin card edge connector
  • Power via USB or via user-provided 5V supply
Documentation
Example Designs
Examples Designs from Arrow Asia BeMicro CV Home Page
Version history
Last update:
‎06-21-2019 09:31 PM
Updated by:
Contributors
