Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
Attached are binary of the tools to run on Linux PC and root fs from buildroot. You can use it to compile kernel and apps.</p>
Login as a user account on Linux PC, eg, hippo. The user home dir will be /home/hippo, short form as ~/ .
Use wget to download the cross tools (69MB). Best thanks to Altera's kindly hosting these files. (but don't use Windows ftp, it corrupt the files)
wget http://www.niosftp.com/pub/gnutools/nios2gcc-20080203.tar.bz2
Or,
sha1sum nios2gcc-20080203.tar.bz2
6873249d8eae7c2981aac6791f044ddaab507566 nios2gcc-20080203.tar.bz2
Open a terminal. Run as root or use sudo,
sudo tar jxf ftp://ftp.altera.com/outgoing/nios2gcc-20080203.tar.bz2 -C
The cross gcc tools was expected to be installed in /opt/nios2 dir. But you may install in any other dirs. Then setup the PATH for the cross gcc, you can add a line at the end of file ~/.bash_profile (or ~/.profile on Debian/Ubuntu) ( the file is hidden, you have to use "ls -a" to find it . For "gedit" use open Location, and enter the file name)
PATH=$PATH:/opt/nios2/bin
After you change the .bash_profile or .profile, you need to logout and login again. So that it will be in the PATH when you login.
Check with, echo $PATH
It should display like this, with nios2 path at the end, /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/opt/nios2/bin
To verify the cross gcc, try out, nios2-linux-uclibc-gcc -v
It should display the info,
Reading specs from /opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/specs
Configured with: /root/buildroot/toolchain_build_nios2/gcc-3.4.6/configure --prefix=/opt/nios2 --build=i386-pc-linux-gnu --host=i386-pc-linux-gnu --target=nios2-linux-uclibc --enable-languages=c --enable-shared --disable-__cxa_atexit --enable-target-optspace --with-gnu-ld --disable-nls --enable-threads --disable-multilib --enable-cxx-flags=-static
Thread model: posix
gcc version 3.4.6
Then try build kernel and apps as in the uClinuxDist
(EDIT: remove ccache links usage, because it doesn't work with blackfin uclinux-dist)
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
