Atle had created a wonderful script to build the toolchain. Please use this instead of buildroot. Please follow Install Nios II Linux.
Buildroot is a set of Makefiles and patches that help to build the cross compiler, libraries, applications, Linux kernel and root filesystem. That is, building almost everything from sources to a working Linux system.
We used buildroot to create the cross compiler and uClibc for Nios II. But we perfer uClinux-dist to create the other parts for a MMU-less Linux.
To run buildroot, you must have a Linux desktop with software development packages. Login as root or use sudo to install these packages.
On Fedora,RHEL,Centos
sudo yum install subversion make gcc ncurses-devel bison flex gawk
On Debian/Ubuntu, sudo apt-get update sudo apt-get install subversion make gcc ncurses-dev bison flex gawk gettext
You can build in any working directory as a user account, eg. in your home dir (say /home/hippo). To grab a copy of the latest version of buildroot using anonymous svn access. (If you can't use svn, you can download a Daily Snapshots) svn co svn://uclibc.org/trunk/buildroot
And to get the latest updates, svn update
Not recommended, but if you want to enable bzero/bcopy/index/rindex support in uClibc. Edit file, buildroot/toolchain/uClibc/uClibc-0.9.29.config , around line 83, change to, UCLIBC_SUSV3_LEGACY_MACROS=y
Then configure for Nios II. Please note, if this is your first try on buildroot, you should unselect everything in 'Toolchain' first, then only select the stuff you want. You should enable fewer options until you got first build successfully.
cd buildroot
make menuconfig
Target Architecture (nios2) ---> # select and change to nios2
Target options --->
Build options --->
Toolchain ---> # select and change as follows
Toolchain type (Buildroot toolchain) --->
--- Kernel Header Options
Kernel Headers (Linux 2.6.23.x kernel headers) --->
--- uClibc Options
uClibc C library Version (uClibc 0.9.29) --->
(toolchain/uClibc/uClibc-0.9.29.config) uClibc configuration file
[ ] Enable locale/gettext/i18n support?
Thread library implementation (linuxthreads (stable/old))
[ ] Thread library debugging # optional, if you want to debug thread
[ ] Enable 'program invocation name'
--- Binutils Options
Binutils Version
() Additional binutils options
--- GCC Options
GCC compiler Version (gcc 3.4.6) --->
[ ] Enable setjmp/longjmp exceptions?
() Additional gcc options
[ ] C++ cross-compiler support
[ ] Fortran cross-compiler support
[ ] Build/install c++ compiler and libstdc++ # optional, if you want c++
[ ] Build/install c++ compiler and libstdc++?
[ ] Build/install Objective-C compiler and runtime?
[ ] Build/install Fortran compiler and runtime?
[ ] Build/install a shared libgcc # unselect
--- Ccache Options
[ ] Enable ccache support?
--- Gdb Options
[ ] Build gdb debugger for the Target
[ ] Build gdb server for the Target
[*] Build gdb for the Host # optional
GDB debugger Version (gdb 6.6)
--- elf2flt
[*] Enable elf2flt support # select
[ ] Run mklibs on the built root filesystem
--- Common Toolchain Options
[ ] Install sstrip for the target system
[ ] Install sstrip for the host/build system
[ ] Enable multilib support # optional, if you want various processor features
[ ] Enable large file (files > 2 GB) support?
[ ] Enable IPv6 # optional
[*] Enable RPC # select
[*] Enable WCHAR support # optional
[ ] Use software floating point by default
(-Os -pipe) Target Optimizations
[ ] Include target utils in cross toolchain
Package Selection for the target ---> # unselect everything
Target filesystem options ---> # unselect everything
Kernel ---> Kernel type (none) ---> # none and unselect everything
Now build everything, it will download all the sources and compile. make
Or, for Ubuntu where bash is not the default shell, make SHELL=/bin/bash (this may take a while)
After building successfully, you need to update $PATH, remove old binary toolchain (/opt/nios2/bin) and add the new build. So that the cross compiler will be in the PATH when you login Linux. Edit file ~/.bash_profile , (or ~/.profile on Debian/Ubuntu), PATH="\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\${PATH}":$HOME/path_to/buildroot/build_nios2/staging_dir/bin
Logout and login again. You can use the tools now. Run this to verify that you have it in your command search path, nios2-linux-uclibc-gcc -v
[option, only if you use 1024Hz clock tick] Before you run make, copy the attached file uClibc-0.9.29-nios2-tck-1024.patch to buildroot/toolchain/uClibc dir. This should give correct sysconf() and clock().
Optional, update to latest kernel headers. Checkout v2.6.24-uc branch of linux-2.6.git on sopc server into your working dir, eg. in your home dir.
git clone -n git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git # this will take a long time
cd linux-2.6
git remote add sopc git://sopc.et.ntust.edu.tw/git/linux-2.6.git
git fetch sopc
git branch --track v2.6.24-uc sopc/v2.6.24-uc
git checkout v2.6.24-uc
git pull
git diff v2.6.24 include/asm-nios2nommu arch/nios2nommu/Makefile >~/path_to/buildroot/toolchain/kernel-headers/linux-2.6.24-nios2nommu.patch
Clean, select 2.6.24 headers and make again.
cd buildroot
rm -rf *nios2*
make menuconfig
Toolchain --->
Kernel Headers (Linux 2.6.24.x kernel headers) --->
make
This is a guide to nios2 uClinux. We build a 'toolchain', compile kernel, and port applications to nios2 uClinux, on a Linux platform.
If you are new to GNU tools, you'd better use the
BinaryToolchain. You may try buildroot after you get more understanding of the tools.
NOTE, the build script below does not handle build error and rebuild. You must edit it or remove old build. The patches should be applied only once. This page contains OUT OF DATE informations. You should use UClinuxDist instead.
Let's start it step by step
su - # your root passwd
yum install compat-gcc-32
cd /usr/bin
mv gcc gcc4
ln -s gcc32 gcc
exit
rpm -i compat-gcc-34-3.4.5-7.i386.rpm
cd /usr/bin
mv gcc gcc4
ln -s gcc34 gcc
exit
1. login with a user account, eg, jack. do not use root account. Your home dir will be /home/jack, or in short ~/
2. download microtronix's port of nios2 linux from the forum into the ~/download dir
3. download the build0411.zip,attached at the end of this post, into dir ~/download cd ~/download unzip build0411.zip ./build The build script will download the latest snapshot,untar, patch and make. (The configs are binutils-2.15,gcc-3.4.6,uClibc-0.9.29-pre,busybox-1.1.1-pre0 and kernel header 2.6.11.) The c++ and libstdc++ will be built, too. (but they still have problems to run) The ~/rootfs dir will be created. The kenel will use this dir and ~/download/rootfs_list file to generate initramfs image. You may edit the ~/download/rootfs_list file, to add or remove dev nodes. There is a minimal .config file. The uClinux-dist will be prepared in ~/uClinux-dist-test. The apps ported by microtronix will be in ~/apps. And the 2.6.11-uc0 kernel will be in ~/linux-2.6.x , with zImage, EPCS MTD,avalon watchdog drivers added. 4. You should include this PATH to use the cross gcc after it is built PATH=$PATH:~/buildroot/build_nios2/staging_dir/bin Or you can update the path of the cross gcc in file ~/.bash_profile PATH=$PATH:$HOME/bin:$HOME/buildroot/build_nios2/staging_dir/bin so that it will be in the PATH when you login Linux.
Run this to verify that you have the proper busybox in FLT format, nios2-linux-uclibc-flthdr ~/rootfs/bin/busybox it should display the FLT header like this,
/home/jack/rootfs/bin/busybox
Magic: bFLT
Rev: 4
Build Date: Mon Mar 27 13:55:05 2006
Entry: 0x40
Data Start: 0x632c8
Data End: 0x7bb80
BSS End: 0x96750
Stack Size: 0x3e80
Reloc Start: 0x7bb80
Reloc Count: 0x344d
Flags: 0x1 ( Load-to-Ram )
5. Setup memory and io port address map of your Nios II board with <a href="/OperatingSystems/UClinux/UClinuxDist/LinuxHwselect">LinuxHwselect.
cd ~/linux-2.6.x
# generate nios2_system.h from ptf
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=your_system.ptf
Then config (see <a href="/OperatingSystems/UClinux/UClinuxDist/LinuxConfig">LinuxConfig) and compile kernel.
# config the kernel
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- menuconfig
# compile the kernel
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- zImage
Whenever you update the ~/rootfs, you have to compile the kernel and update the initramfs.
CHK usr/initramfs_list
CPIO usr/initramfs_data.cpio
GZIP usr/initramfs_data.cpio.gz
AS usr/initramfs_data.o
LD usr/built-in.o
If you didn't see the "CPIO" and "GZIP" in compile message, the initramfs is not updated. You will have to remove the file usr/initramfs_list in kernel dir, and compile again to force the update of initramfs.
6. Now the compressed kernel image is ready, arch/nios2nommu/boot/zImage . you can run it on windows, First, download the sof of your hardware to your board with quartusII programmer, Then open a nios2 sdk shell,
Note the drives mapping in nios2 sdk shell, drive c: is /cygdrive/c/ if you map your linux home to h: on windows with samba server, then drive h: is /cygdrive/h/ so the image file is /cygdrive/h/linux-2.6.x/arch/nios2nommu/boot/zImage
cd /cygdrive/h/linux-2.6.x/arch/nios2nommu/boot
nios2-download -g zImage
nios2-terminal
Here is the boot message on my custom board,
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.16 jack@localhost) (gcc version 3.4.6) #1 PREEMPT Wed Mar 22 11:48:33 CST 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 512 (order: 9, 8192 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory available: 63616k/65536k RAM, 0k/0k ROM (733k kernel code, 546k data)
Mount-cache hash table entries: 512
io scheduler noop registered
io scheduler deadline registered (default)
NIOS serial driver version 0.0
ttyS0 (irq = 1) is a builtin NIOS UART
Freeing unused kernel memory: 468k freed (0xc0000 - 0x134000)
init started: BusyBox v1.1.1-pre0 (2006.03.20-07:53+0000) multi-call binary
BusyBox v1.1.1-pre0 (2006.03.20-07:53+0000) Built-in shell (msh)
Enter 'help' for a list of built-in commands.
(Note, don't use jtag uart in production, it will not run without a nios2-terminal connection)
12. There are many applications built into busybox, enter 'help" to find out and read doc of busybox to learn them (eg udhcp server and client). You may config busybox, for more apps or to reduce size.
cd ~/buildroot
# remove old busybox apps and links
make -C build_nios2/busybox clean
# select busybox apps
make -C build_nios2/busybox menuconfig
# build busybox again
make
# rebuild rootfs
rm -rf ~/rootfs
cp -a ~/buildroot/build_nios2/root ~/rootfs
cd ~/rootfs
# remove include and lib to save space
# the dev nodes are generated via ~/download/rootfs_list
rm -rf dev usr/include usr/lib
# you may use this instead of the one from buildroot
cp ~/download/inittab etc
# check busybox header
Rebuild the kernel image for initramfs.( I have removed old ~/rootfs for simplicity in the example, you may have to reinstall others, such as kernel modules, apps, configs)
If you want to add or port apps to uClinux, you should think of adding it to busybox first. Because there are no shared objs, add apps to busybox will save some memory usage.
13. To use the apps ported by Microtronix. I have patched the Makefile of inetd,ftpd and boa using ~/download/mx140apps.diff . You can look at the patches and update other apps yourself. Note you have to prepare proper config files to run these apps.
To run boa web server,
cd ~/apps/boa/src
make
make install
mkdir ~/rootfs/etc/config
cp ~/download/boa.conf ~/rootfs/etc/config
cp ~/download/mime.types ~/rootfs/etc
mkdir ~/rootfs/home/httpd
put your index.html and other content into ~/rootfs/home/httpd . Then rebuild zImage for initramfs, boot nios2 uclinux, and run, boa&
If you want cgi, check ~/uClinux-dist-test/user/cgi_generic , in next step.
To run inetd and ftpd,
cd ~/apps/inetd
make
make install
cd ~/apps/ftpd
make
make install
echo "ftp stream tcp nowait root /bin/ftpd" >>~/rootfs/etc/inetd.conf
to use anonymous ftp user,
add "ftp:x:14:50:FTP User:/home/ftp:" to etc/passwd
add "ftp:x:50:" to etc/group
make dir home/ftp
add ftp contents to home/ftp
rebuild zImage for initramfs, boot nios uclinux, and run,
inetd&
netstat -a
inetd will invoke ftpd.
14. To use user apps ported to uClinux from uClinux-dist.
cd ~/uClinux-dist-test
make menuconfig
In menuconfig, select Kernel/Library/Defaults Selection ---> [*] Customize Vendor/User Settings (NEW) Then <exit>,<exit>,<yes>. It will enter user apps select, make your selection. It has pre-selected dhcpd and net-snmp for testing.
To compile make subdirs copy apps to ~/rootfs
make romfs
cd romfs
cp -a bin usr var ~/rootfs
Note, you have to setup config files to ~/rootfs/etc for apps (eg dhcpd.conf), check doc for each of them. You should also check ~/uClinux-dist-test/romfs/etc for other config files. ~/uClinux-dist-test/user/dhcpd/samples/dhcpd.conf
Then rebuild zImage for initramfs. (note, the boa port in uClinux-dist has problems on nios2)
To use telnetd, you have to enable pty in kernel config, [code]Device Drivers --> Character devices --> [*] Legacy (BSD) PTY support (10) Maximum number of legacy PTY in use[/code] Select telnetd in uClinux-dist-test menuconfig,
[*] telnetd
[*] telnetd does not use openpty() (NEW)
add "telnet stream tcp nowait root /bin/telnetd" to ~/rootfs/etc/inetd.conf . The password files are etc/passwd,etc/group,etc/shadow .
15. If you want to port apps, look in ~/buildroot/build_nios2/busybox, ~/apps, and ~/uClinux-dist-test/user first. There may be ported apps already. Read the file INSTALL of it. If it need "./configure", you should check it with "./configure -help" and add options. You may have to update the file config.sub, check ~/download/uClinux-dist.diff on how to add $basic_machine, eg wget
Index: user/wget/config.sub
--- user/wget/config.sub (revision 1)
+++ user/wget/config.sub (revision 3)
@@ -274,6 +274,11 @@
m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
+ nios2 | nios2-* | nios2 | nios2-*)
+ basic_machine=nios2-altera
+ os=-linux
# We use `pc' rather than `unknown'
# because (1) that's what they normally are, and
# (2) the word "unknown" tends to confuse beginning users.
Then run "./configure --host=nios2-linux-uclibc --disable-shared ...." ,a Makefile will be generated. You may have to modify the Makefile or Rules.mak. The stdinc dir and stdlib dir are default to uClibc. So you don't need the "-nostdinc" and "-nostdlib" stuf. You should add something like this to link flags to generate FLT obj, [code]LDFLAGS += -Wl,-elf2flt="-s 16000" -Wl,-v -Wl,-d[/code] Remove unused items, or that is for PC host. You can setup the install path to your rootfs. Then,"make","make install". Remeber to update the kernel image for initramfs. A sample patch, mtools-Makefile.diff, to mtools-3.9.10 Makefile is included in the attached build.zip.
(PS..) Marc sent the nios2 port of buildroot to busybox.net, and I did some patches, too. Vapier, one of the developers of busybox/uClibc/buildroot, helps to clean up the codes and incoporate into the "trunk". And he forwarded the elf2flt patches to uClinux dev team, too. All these works bring this project, simple and easy to use tools to build uClinux for the Nios2. Best thanks to marc, jdhar, and vapier.
