Contributing Code to uClinux-dist repository
cancel
Showing results for
Search instead for
Did you mean:
Here will be explained who to publish your changes and stuff into uClinux-dist repository in 10 steps.
This could be done with creating a patch and mailing it to nios2-dev mailinglist.
For Debian/Ubuntu-User package git-email is needed: (apt-get install git-email)
Mailinglist URL: nios2-dev (http://sopc.et.ntust.edu.tw/cgi-bin/mailman/listinfo/nios2-dev)
Git repository web view: uClinux-dist (http://sopc.et.ntust.edu.tw/?p=uClinux-dist.git;a=summary)
Step 1
Change the files you want to commit
Step 2
Look at the differences with:
git-diff
Step 3
Mark the files for commit with:
git-add path/to/file
Step 4
Now git-diff gives no output but you could see the diff with:
git-diff --cached
Step 5
Commit your changes with:
git commit -m 'Put your Update Message here'
Step 6
Create mail-able patch file with:
git format-patch -n -1
Step 7
Have a look at the patch file, add your message and save it:
nano 0001-xxx.patch
Step 8
Mail the patch to the nios2-dev mailinglist:
git send-email --smtp-server your.smtp.server --to nios2-dev@sopc.et.ntust.edu.tw 0001-xxx.patch
Maybe you have to add this if your server needs smtp-auth (for Debian/Ubuntu packages: libauthen-sasl-perl libnet-smtp-ssl-perl are needed!):
--smtp-user YourMailUserName --smtp-pass YourMailUserPasswort
Now 2 questions popUp:
FIRST:
Who should the emails appear to be from? [Some Name]
---> You can type your Name and email-address here if it's not the right one in format: "Your name" xyz@yourMail.Adress
SECOND:
Message-ID to be used as In-Reply-To for the first email?
---> Enter a Message-ID or continue with "Enter" this is for threading the messages to have the overview
Step 9
Now you could hopefully read something like:
"Result: 250 93502886 message accepted for delivery"
Step 10
Congratulation your first patch for nios2-uClinux-dist is complete!!
Version history
Last update:
‎12-16-2022 03:40 PM
Updated by:
