Downloading Linux Distribution
cancel
Showing results for
Search instead for
Did you mean:
For new users who have not used nios2 git before, download the tarball (2GB) ,as a normal user,
wget http://www.niosftp.com/pub/linux/nios2-linux-20100621.tar
sha1sum nios2-linux-20100621.tar
3865fa6662a98e591f5dbff1421506bcb15ffd66 nios2-linux-20100621.ta2
tar xf nios2-linux-20100621.tar
cd nios2-linux
./checkout
For existing nios2 git users, (with nios2-linux-20080619.tar or nios2-linux-20090730.tar) there is no need to download the tarball. You may add a new branch to track the nios2 mmu kernel and use clone to get the binary toolchain.
cd nios2-linux
git clone git://sopc.et.ntust.edu.tw/git/toolchain-mmu.git
cd linux-2.6
git fetch origin
git branch nios2mmu origin/nios2mmu
git checkout -f unstable-nios2mmu
git clean -f -x -d
cd ..
cd uClinux-dist
git fetch origin
git branch trunk origin/trunk
git checkout -f trunk
git clean -f -x -d
In short, to build with a kernel using the MMU, use the nios2mmu branch on linux-2.6, and the trunk branch on uClinux-dist. To build without an MMU, use the test-nios2 branch on linux-2.6, and the test-nios2 branch on uClinux-dist.
Next step: Linux Quick start
Version history
Last update:
‎06-26-2019 05:09 AM
Updated by:
Contributors
