Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
This is a page created for those who are interested in running an IDE for developing NIOS II uClinux code. Eclipse is based on java, initially developed by IBM, and now open source.
These two pieces of software to run Eclipse IDE: Java runtime and Eclipse-SDK.
They can be downloaded at Sun java and Eclipse.org. The example I give is based on the three files I downloaded at the time.
The following command does it
su
mkdir /usr/java
mv jre-1_5_0_06-linux-i586.bin ./
chmod 744 jre-1_5_0_06-linux-i586.bincd /usr/java
./jre-1_5_0_06-linux-i586.bin
Follow the instruction on your terminalComplete instruction can be found on java's website.
Note: It is important to install CDT before Eclipse-SDk (it shouldn't matter, but somehow I find that Eclipse did not register the later plug-in if CDT is post installed)
Download CDT 3.1 (org.eclipse.cdt.sdk-3.1.0-linux.x86.tar.gz) from here
Place the file in /usr.
cp org.eclipse.cdt.sdk-3.1.0-linux.x86.tar.gz /usr
cd /usr
tar xvzf org.eclipse.cdt.sdk-3.1.0-linux.x86.tar.gz
Place eclipse-SDK-3.2-linux-gtk.tar.gz file in /usr
tar xvzf eclipse-SDK-3.2-linux-gtk.tar.gz
rm eclipse-SDK-3.2-linux-gtk.tar.gz (optional)
/usr/eclipse/eclipse -vm /usr/java/jre1.5.0_06/bin/java &
You can follow the blackfin uClinux wiki for further stuff. Please add to this page if anyone has gone further.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
