Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
git is a version control system written by Linus. Kernel developers widely use it. You can find tutorials and manuals from git . Another good reference on everyday git usage are the gitmagic guide and the Kernel Hacker' Guide to git (http://linux.yyz.us/git-howto.html .
This page briefly describes how to use git to access a public server, sopc, which is created to host open-source projects of nios2 and alike.
This server is located at the Embedded System Lab., Electronic Engineering Department, National Taiwan University of Science and Technology . The server was maintained by Mon-Chau Shie, who is an assistant professor of the Electronic Dept., NTUST. Many thanks for his kind support.
(The server is behind a firewall, and you won't be able to ping.)
All contributions to kernel and u-boot should conform to the Linux kernel coding style; see the file "Documentation/CodingStyle" and the script "scripts/Lindent" in your Linux kernel source directory.
As user on local machine,
1. install git-core package , as root or via sudo. (Note, older git packages may have problem. v1.5.2 or higher is required. Try the latest version, or build it from source)
On Fedora,RHEL,Centos, yum install git-core ( for Centos, you can add git packages from epel)
On Suse, zypper install git-core gitk
On Debian,Ubuntu, sudo apt-get install git-core
If you have older version, try update. Or better, build from the latest git source, which is 1.5.3.8 at this time of writing. You can check your installed git version with "git --version".
If have older version and you want to build from source, uninstall or remove the old package.
http://www.kernel.org/pub/software/scm/git/git-1.5.3.8.tar.bz2 (later versions are now available - look for them here http://www.kernel.org/pub/software/scm/git/ )
tar jxf git-1.5.3.8.tar.bz2 # extract to any directory outside uClinux-dist
cd git-1.5.3.8
./configure
make
sudo make install # will install git to /usr/local/bin
(UPDATE) Please follow InstallNios2Linux, and switch to the "test-nios2" branch.
MIRRORS: You can choose the mirror nearest to you and replace the url in remote "origin".
url = http://git.opensource.emlix.com/git/nios2/uclinux-dist.git (DE) gitweb = http://git.opensource.emlix.com/ . (Best thanks to emlix.com)
(If you want to contribute, please send me ,Hippo, an e-mail attaching a public key for ssh access. ie, run 'ssh-genkey' and send me the file ~/.ssh/id_rsa.pub. Please also give me your real name and preferred user name on this server. This will allow you to push the git server.)
As user on local machine, setup your local git as described in previous section.
1. as a user, give your real name as it is a norm in Linux kernel mailing list.
git config --global user.email you@email.com
git config --global user.name "Your Name"
2. edit .git/config, add ssh to remote origin,
[remote "origin"]
url = ssh+git://sopc.et.ntust.edu.tw/git/uClinux-dist.git
fetch = +refs/heads/*:refs/remotes/origin/*
OR
[remote "origin"]
url = ssh+git://your_account_name@sopc.et.ntust.edu.tw/git/uClinux-dist.git
3. edit, test, commit... Please add signoff (-s) to your commits. Please add "nios2:" to the commit message of nios2 arch specific patches, or names of the subsystem or drivers otherwise. See http://www.kernel.org/pub/software/scm/git/docs/user-manual.html#creating-good-commit-messages
git status # check which files should be committed
git diff the_files_or_subdir_to_be_updated # double check the diff
git add the_files_or_subdir_to_be_updated
git commit -s # commit with your signoff,
git log # have a look at your commit log
If you found any mistakes after commit, you can revert with "git reset --soft HEAD^".
4. when you are ready, you may send your new commit to the public server
git push
Or, you can submit the patches via e-mail , eg to the nios2-dev mailing list.
git format-patch AAAA..BBBB # generate patches from commit AAAA to commit BBBB, output numbered patches
git send-email --smtp-server your.mail.server --to whom@where 0001-xxxx.patch
5. if you want to make a lot of changes or develop a new driver, you may create an experimental branch. You can push the branch early so that others can join the test.
git branch my_test_branch
git checkout my_test_branch
...edit,test,commit...
git push origin my_test_branch
6. You can use git-format-patch and git-am to cherry-pick and merge branches, read the man pages.
git format-patch AAAA..BBBB # generate patches from commit AAAA to commit BBBB, create numbered patches 00xxx.patch
git checkout v2.6.23-uc
git pull
git am 00xxx.patch
git log # check again
git push origin v2.6.23-uc
This is how I setup the sopc git server using Debain 4.0. It should be the same for Ubuntu. It is welcome to mirror the sopc server. Install a minimum system with netinst.iso . As root on server, 0. Add this line, for updated git packages from backports.org . deb http://www.backports.org/debian etch-backports main contrib non-free to your /etc/apt/sources.list.
1. apt-get install openssh-server apache2 rsync
apt-get -t etch-backports install git-core git-daemon-run gitweb
2. edit file /etc/apache2/sites-available/gitweb, replace "example.org" with your domain name.
<VirtualHost *>
ServerName git.example.org
ServerAdmin webmaster@localhost
HeaderName HEADER
# bogus but safe DocumentRoot
DocumentRoot /var/cache/git
ErrorLog /var/log/apache2/gitweb-error.log
CustomLog /var/log/apache2/gitweb-access.log combined
Alias /robots.txt /var/www/cvs.robots.txt
Alias /gitweb.css /var/www/gitweb.css
Alias /git-logo.png /var/www/git-logo.png
Alias /git-favicon.png /var/www/git-favicon.png
Alias /git /var/cache/git
ScriptAlias / /usr/lib/cgi-bin/gitweb.cgi
RedirectMatch permanent "^/~(.*)$" "<a rel="freelink" href="http://example.org/~$1" >http://example.org/~$1"
</VirtualHost>
ln -s /etc/apache2/sites-available/gitweb /etc/apache2/sites-enabled/100-gitweb
(optionally, copy png files from git source git/gitweb to /var/www)
(optionally, make link for ssh, ln -s /var/cache/git / )
Note that Step #2 is only required if you want to enable HTTP access to your repository.
3. prepare for publishing, you can place the git in home or (other shared ?) dir, eg /home/you/git/uClinux-dist.git, then add a symlink in /var/cache/git .
as a user,
cd ~
mkdir git
cd git
mkdir uClinux-dist.git
cd uClinux-dist.git
git --bare init --shared
git remote add --mirror origin git://sopc.et.ntust.edu.tw/git/uClinux-dist.git
git --bare fetch # to pull from server at origin, will take some time at first run
The --mirror tag is required so the remote refs (ie: test-nios2) will be stored as a head in your repository instead of a pointer to a remote branch. This is necessary if others need to access your repository. Since running git-fetch on a bare GIT repository will take a very long time, if you already have a local working copy of the repository on the machine, you can do the following (instead of the above):
cd to local working copy (eg: cd ~/nios2-linux/uClinux-dist.git)
git-clone --bare . <destination for mirror> (eg: git-clone --bare . ~/git/uClinux-dist.git)
cd <mirror> (eg: cd ~/git/uClinux-dist.git)
Remove any branches you don't want using git-branch -D
git --bare fetch
Since this already has the test-nios2 branch now (you cloned it), the fetch will be much faster
touch git-daemon-export-ok # to enable <a rel="freelink" href="git://" >git://
git --bare update-server-info # to enable <a rel="freelink" href="http://" >http://
chmod a+x hooks/post-update
edit description # to display on gitweb
You can add a cron job to pull updates from origin daily,
cd /home/you/git/uClinux-dist.git
git --bare fetch
as root, add this link for publishing.
ln -s /home/you/git/uClinux-dist.git /var/cache/git
4. update your DNS server, resolve both names to the same ip. git.example.org is the virtual host. example.com is the real host.
We have bandwidth issue with our git server at NTUST. To help reduce the network loading, please don't clone directly from sopc server whenever possible.
These patches were merged to buildroot. You won't need to use this directly.
boards.git dev board projects
elf2flt.git elf2flt utility
These patches were merged to buildroot and uclinux.org CVS. You won't need to use this directly.
gcc3.git gcc 3.4
insight.git Insight GDB
linux-2.6.git Linux kernel.
To use this git, please clone from Linus' git and fetch from sopc server. See <a href="/KernelPatches KernelPatches].
u-boot.git Das U-Boot
To use this git, please clone from DENX git and fetch from sopc server.
uClinux-dist.git uClinux distro
To use this git, please download uClinux-dist-20080131.tar and fetch from sopc server.
test : patches of uClinux-dist-test from uclinux.org
/usr/share/doc/git-core/ http://www.kernel.org/pub/software/scm/git/docs/user-manual.html#maintaining-topic-branches
Community support is provided during standard business hours (Monday to Friday 7AM - 5PM PST). Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
