Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
If you will write driver, try out the hello world module example in the (must have) book "Linux Device Driver 3rd ed.".
In your kernel dir, eg, nios2-linux/linux-2.6, (NOT in the uClinux-dist dir)
save the file to drivers/misc/hello.c
#include <linux/init.h>
#include <linux/module.h>
MODULE_LICENSE("Dual BSD/GPL");
static int hello_init(void)
printk(KERN_ALERT "Hello, world\n");
return 0;
static void hello_exit(void)
printk(KERN_ALERT "Goodbye, cruel world\n");
module_init(hello_init);
module_exit(hello_exit);
Add these lines to drivers/misc/Kconfig, before the "#endif" line.
config HELLO
tristate "example hello module"
help
Enable example hello module.
Add the line to drivers/misc/Makefile
obj-$(CONFIG_HELLO) += hello.o
If you want to use a new device node, you can add it to uClinux-dist/vendors/Altera/nios2/romfs_list
Platform devices are created by platform-specific code in nios2-linux/linux-2.6/arch/nios2/kernel/config.c
Unless this file is modified to create a platform device, probing your module will fail.
It is suggested that you create a local branch using git in advance. Then add these files, and save them with commits.
Please refer to git tutorial. eg, assume you are at the official "test-nios2" branch.
git branch
* test-nios2
# rename the branch as your own experimental branch
git branch -M test-nios2 test-hello
git branch
* test-hello
# add/edit files with text editor
# save changes with git
git add drivers/misc/hello.c
git add drivers/misc/Kconfig
git add drivers/misc/Makefile
git commit -s -m "hello: example kernel driver"
# take a look!
git log
# Or
gitk
# You may pull updates to this branch. And save your future works with this experimental branch.
git pull origin test-nios2
# You can also create a new official "test-nios2" which was gone with previous renaming.
git branch --track test-nios2 origin/test-nios2
git branch
* test-hello
test-nios2
# You can switch between branches
git checkout test-nios2
# Or
git checkout test-hello
Go back to uClinux-dist, (NOT in the kernel source tree linux-2.6)
cd nios2-linux/uClinux-dist
Enable your driver in kernel using "make menuconfig", the driver will be "compile-in" -- run directly at boot.
Device Drivers -->
Misc devices --->
<*> example hello module
Save, make and boot. Then you should see the message "Hello, world" displayed.
If you want to be able to load the module after kernel boot,
then enable module support in kernel and build the hello.ko module.
Still in uClinux-dist, (NOT in the kernel source tree linux-2.6)
In kernel selection,
Loadable module support -->
[*] Enable loadable module support
[*] Module unloading
Device Drivers -->
Misc devices --->
<M> example hello module
In apps selection, (this should be selected already with default config)
Busybox -->
[*] insmod
[*] insmod: lsmod
[*] insmod: modprobe
[*] insmod: rmmod
[ ] insmod: Pre 2.1 kernel modules
[ ] insmod: 2.1 - 2.4 kernel modules
[*] insmod: 2.6 and above kernel modules
[ ] insmod: Model version checks
[ ] insmod: Support tainted module checking with new kernels
Then, in ~/uClinux-dist dir, rebuild with,
make user/busybox_clean
make
The modules objects, (eg hello.ko) will be installed in romfs/lib/modules tree.
Boot nios2 uClinux, and load module
modprobe hello
There is an (outdated) example driver in Chinese from Alex.liu, http://www.icwin.net/ShowArtitle.ASP?art_id=8452&cat_id=52
You can compile the hello module alone, without building the whole kernel.
In the module dir, linux-2.6/drivers/misc, compile it with,
make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C ~/nios2-linux/uClinux-dist/linux-2.6.x M=`pwd` modules
nios2-linux-uclibc-strip -R .comment -R .note -g --strip-unneeded hello.ko
Then you can transfer the module file, hello.ko, to your board with ftp or nfs mount if you have ethernet port, and try out with "insmod hello.ko" and "rmmod hello". Or you may replace the old module at /lib/modules/2.6.27-rc1/kernel/drivers/misc , then you can use "modprobe hello".
You can save the time to rebuild the whole kernel, download and reboot.
Or if you want to build module outside the kernel tree, ie external module, create a Makefile in your module dir, with only one line,
obj-m := hello.o
Then build it with the same commands above.
For details, please read,
linux-2.6/Documentation/kbuild/modules.txt
linux-2.6/Documentation/kbuild/makefiles.txt
Community support is provided during standard business hours (Monday to Friday 7AM - 5PM PST). Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
