Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
NFS server setup, login as root on server,
In Kernel Settings, check
File systems -> Network File Systems -->
[*] NFS file system support
[*] Provide NFSv3 client support
In Application/Library Settings, check
Network Applications -->
[*] portmap
Run portmap before mount command:
portmap &
mkdir /mnt/nfs
mount -t nfs -n -o nolock,rsize=1024,wsize=1024 192.168.1.2:/home/nios2 /mnt/nfs ( eg, server ip 192.168.1.2)
add fstab in [/nios2-linux]/uClinux-dist/vendors/Altera/nios2/ and edit the Makefile to have a copy in /etc in kernel image.
Content of fstab:
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
192.168.1.2:/home/nios2 /mnt/nfs nfs rsize=1024,wsize=1024,noauto,nolock 0 0
Now you can access the mount point with:
portmap &
mkdir /mnt/nfs
mount /mnt/nfs
Or you could add these lines in [/nios2-linux]/uClinux-dist/vendors/Altera/nios2/rc to mount it automatically at startup
Then Nios II client can access files on /home/nios2 of server through /mnt/nfs mount point.
The mount command in sash does not support nfs mount.
You may use the busybox "mount", and enable the "nfs support" in busybox "mount". You may enable "cp" in busybox, which can support recursive copy. You need to clean up busybox, with "make -C user/busybox clean" , "make" "make romfs" and "make linux image" to rebuild kernel image.
To create a rootfs for NFS, login as a root on your PC host,
cp -a /home/hippo/uClinux-dist/romfs/* /home/nios2
rm /home/nios2/init
mkdir /home/nios2/dev
on your Nios2, mount /home/nios2 as /mnt/nfs as above.
cp -a /dev/* /mnt/nfs/dev
NFS root, read kernel Documentation/nfsroot.txt
Before you try NFS root, you should start with initramfs and test a nfs mount. If the nfs mount works without problem, then you can disable initramfs by empty the initfamfs path in kernel config. There is a bug in SYSFS, so you must disable SYSFS.
Networking --> Networking options -->
[*] TCP/IP networking
[*] IP: kernel level autoconfiguration
[*] IP: DHCP support
[ ] IP: BOOTP support
[ ] IP: RARP support
[*] Root file system on NFS
File systems -> Pseudo filesystems -->
[ ] sysfs file system support
You need to add a command line in kernel config. ( eg, server ip = 192.168.1.2 , nios2 client ip 192.168.1.10/255.255.255.0 , gateway 192.168.1.254, hostname nios2 )
root=/dev/nfs rw nfsroot=192.168.1.2:/home/nios2/roofs ip=192.168.1.10:192.168.1.2:192.168.1.254:255.255.255.0:nios2:eth0:off
Or if you setup to use DHCP , (with those parameters in dhcpd.conf) . the kernel command line is simple,
root=/dev/nfs rw ip=dhcp
Note, the new smc91x and dm9000 driver do not have ethernet MAC address programmed. You need to hack the driver code to add them or use the old smc91111 drivers.
Sample /etc/dhcpd.conf ,
ddns-update-style none;
default-lease-time 21600;
max-lease-time 21600;
option subnet-mask 255.255.255.0;
option option-128 code 128 = string;
option option-129 code 129 = text;
use-host-decl-names on;
subnet 192.168.1.0 netmask 255.255.255.0 {
option log-servers 192.168.1.2;
option broadcast-address 192.168.1.255;
option routers 192.168.1.254;
option domain-name-servers 192.168.1.254;
range 192.168.1.10 192.168.1.100;
group {
host nios2 {
hardware ethernet 00:07:ed:0a:03:29;
fixed-address 192.168.1.10;
option root-path "192.168.1.2:/home/nios2";
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
