Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
You can import the uClinux-dist to Nios2 IDE, ie Eclipse, and debug kernel.
The debug info (-g) is disabled by default. To enable debug info,
Kernel hacking -->
[*] Kernel debugging
[*] Compile the kernel with debug info
1. Open Nios2 IDE from a shell, ie, run "nios2-ide" .
2. From IDE menu, import the uClinux-dist dir. After you press [finish], it will take some time scanning the dir.
3. Connect jtag cable to your board, and configure your fpga with nios2-configure-sof if it is not configured yet.
4. Select project uclinux from the left-hand side of the windows.Set Up a Debug Configuration.
5. A Debug Configuration Manager will come out,
6. If the Confirm Perspective Switch dialog box appears, click Yes. You can debug the kernel now.
Reference
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
