This page describes the minimal setup required to run the NIOS2 gdb server on a Linux host. It is assumed that the USB Blaster is used as the JTAG interface.
Setting up USB Blaster
#!/bin/sh
# USB-Blaster hotplug script
# Allow any user to access the cable
chmod 666 $DEVICE
2. Add the following lines to /etc/hotplug/usb.usermap to tell the hotplug system to run the above script when it detects the USB Blaster
# Altera USB-Blaster
usbblaster 0x03 0x09fb 0x6001 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0
usbblaster 0x03 0x09fb 0x6002 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0
usbblaster 0x03 0x09fb 0x6003 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0
The NIOS2 gdb server doesn't talk directory to the USB Blaster cable. The jtagd daemon is the program that actually talks to the USB Blaster. jtagd listens on localhost port 1309 for connections from applications such as nios2-gdb-server-wrapped and jtagconfig. The jtagconfig program isn't actually required, but it's handy for making sure that the USB Blaster cable and target hardware are functioning.
What's important is that jtagd must be running before jtagconfig or nios2-gdb-server-wrapped can be used.
The set of files required to run jtagd, jtagconfig, and the gdb-server are shown below
-rwxr-xr-x 1 grante users 29296 Oct 20 2005 jtagconfig
-rwxr-xr-x 1 grante users 340120 Oct 28 22:51 jtagd
-rw-r--r-- 1 grante users 62452 Oct 30 13:52 jtagd.pgm_parts
-rwxr-xr-x 1 grante users 15440 Oct 28 22:51 libccl_ver.so
-rwxr-xr-x 1 grante users 182208 Oct 28 21:55 libjtag_client.so
-rwxr-xr-x 1 grante users 145229 Oct 28 21:55 nios2-gdb-server-wrapped
The file jtagd.pgm_parts needs to be in /etc/jtagd. I leave the rest of the files in a single directory.
A Startup Script
Along with the files listed above, I have a shellscript called gdb-server.sh shown below:
#!/bin/bash
test -f ~/.jtag.conf ||
echo "you don't have a $HOME/.jtag.conf file. Creating an empty one"
touch ~/.jtag.conf
for f in jtagd nios2-gdb-server-wrapped jtagconfig libccl_ver.so libjtag_client.so
do
test -f $f || { echo "$f must be in this directory"; exit 1; }
done
test -f /etc/jtagd/jtagd.pgm_parts ||
echo -"/etc/jtagd/jtagd.pgm_parts file is missing. Attempting to create one..."
test -d /etc/jtagd || mkdir --verbose /etc/jtagd
cp --verbose jtagd.pgm_parts /etc/jtagd
echo "OK"
(grep -q usbblaster /etc/hotplug/usb.usermap && test -f /etc/hotplug/usb/usbblaster) ||
echo "missing config in /etc/hotplug/usb.usermap -- please see usbblaster.readme"
exit 0
export LD_LIBRARY_PATH=$PWD
set -x
./jtagd
./jtagconfig
exec ./nios2-gdb-server-wrapped --tcpport 8888 --tcppersist
The shell script above does the following:
When you run the script above, you should see something like this:
$ ./gdb-server.sh
+ ./jtagd
+ ./jtagconfig
1) USB-Blaster [USB 4-1.1]
020B30DD EP2C20
020A10DD EPM240
+ exec ./nios2-gdb-server-wrapped --tcpport 8888 --tcppersist
Using cable "USB-Blaster [USB 4-1.1]", device 1, instance 0x00
Processor is already paused
Listening on port 8888 for connection from GDB:
You can then start nios2-elf-gdb and connect to the gdb server using the "target remote" command as shown below:
$ nios2-elf-gdb
GNU gdb 6.1
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "--host=i686-pc-linux-gnu --target=nios2-elf".
(gdb) target remote localhost:8888
Remote debugging using localhost:8888
0x08000000 in ?? ()
(gdb)
Happy debugging...
