Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
Overview
Altera PCI Express Arria 10 Development kit with 10AX115S2F45I1SG
A system with either 32-bit or 64-bit Linux or 64-bit Windows 7 installed
Follow the following instructions to install and run the application
In the application, there are multiple options to configure the software. The user can run read DMA (move data from system memory to the on-chip memory in the FPGA), write DMA (move data from on-chip memory to system memory), or simultaneous read and write. The user can also control the transfer size of each descriptor, the number of descriptors, and how many loops the DMA runs. There is description to explain all the options when the application is started. To run the DMA, type in "1" to start it.
The reference design was created by ACDS 16.0.2
Link to download the project File:PCIe A10GX AVMM DMA On Chip Mem 1602.zip
Link to download the application and driver File:Linux for AVMM DMA On Chip Mem.tar.gz
64-bit Windows driver and application:File:Gui package 090 80000000.zip.
In the package, there is a word document which explains how to install the driver, what additional software needed to be installed, and how to run the application.
Updated 64-bit Windows driver with more accurate throughput calculation:File:AVMM DMA Windows GUI.zip.
error: macro "__DATE__" might prevent reproducible builds [-Werror=date-time]
error: macro "__TIME__" might prevent reproducible builds [-Werror=date-time]
solution: turn off the the date-time error by adding the following line to the Makefile, after the line containing the "CPPFLAGS +=" :
ccflags-y += "-Wno-date-time"
August 22, 2016 - Created this page
June 12, 2017 - Troubleshooting section added
