SDI II MegaCore Debug Checklist
Introduction
This document describes the hardware debug flow and provides a checklist when testing out the Altera SDI II MegaCore. These guidelines help you verify your design, identify the problems, and resolve them quickly.
Most Frequent Ask Questions in SDI II
- SDI II Tx Issue
- Why SDI II output is not available?
- Why the SDI II output have high jitter?
- SDI II Rx Issue
- Why SDI II Rx frame locked cannot be locked to the incoming SDI signal?
- The rx_std shows incorrectly.
- Why the frame locked always toggling?
- Reconfiguration issue
- The SDI II Rx cannot be locked when the incoming signal is switch to HD signal.
- I have long locking time when received HD signal.
SDI II Debug Guideline Tips
- Identify problem statement.
- Understand the problem statement/requirement.
- ACDS Version/IP Version/Target Device.
- SDI II IP Variant.
- Triple rate/ Dual rate/ Single rate
- Transceiver only, SDI II protocol only or both
- Get the SDI II Verilog/VHDL Wrapper that generated by the Megawizard/IP Catalog GUI.
- Check if any known issue in solution or patch available.
- Timing Closure.
- Debug Information.
- Hardware or Simulation
- Tx issue or Rx issue
- SD, HD or 3G signal
- Simplify test case/environment if necessary
- Duplicate the issue in Altera development kit.
- Follow the debug flow for SDI II Tx Issue/Rx Issue on sections below in dev kit/customer board.
Debug Flow – SDI II Tx Issue
The following diagram shows an overview of the SDI II Tx debug flow.
Debug Steps – SDI II Tx Implementation
- Ensure all signals connected to SDI II MegaCore appropriately (refer to UG/reference design/example design).
- Ensure all clocks are operating at their specified frequencies.
- reference clock, xcvr_refclk
- transmitter clock, tx_coreclk
- parallel clock, tx_pclk
- Verify the board design – Signal integrity, driver and equalizer.
- Example: Ensure the driver used is support SD/HD/3G when user using SDI II triple rate mode.
- Confirm data feed into signal tx_datain, tx_datain_valid tx_trs, tx_std, tx_ln, tx_vpid_byte*, tx_line_f*, tx_clkout, tx_pclk are correct. (signal tap)
- Ensure cascade PLL is not applied to the transceiver reference clock (Not recommended).
Clock Frequency For SDI II Tx
- The xcvr_refclk signal must be externally multiplexed in order to support 1/1.000 and 1/1.001 data rate factor. Extra xcvr_refclk_alt available for 1/1.001 data rate factor if “Tx PLL Dynamic Switching” option is enabled (Available for Arria V, Cyclone V, Stratix V and Arria V GZ devices).
Signal Tap – SDI II Tx Implementation
- Ensure all the resets are released.
- Ensure clock and transmited data, tx_datain are available.
- Ensure tx_std and tx_trs are set correctly following the SDI standard defined by user.
Debug Steps – SDI II Tx Transceiver
- Confirm all the transceiver signals are behave correctly. Verify tx_datain, tx_clkout, tx_pll_locked, tx_analogreset, tx_digitalreset, pll_powerdown. (you can found the signal by typing *phy|<signal name> into signal tap)
- Ensure all resets are released
- Ensure pll_locked is asserted
- Ensure data is available in signal tx_datain
Signal Tap - SDI II Tx Transceiver
- tx_clkout might be same frequency and same phase with reference clock. If the signal tap clock triggered by reference clock, it will shows constant low or constant high.
- You may use tx_clkout as triggered clock to confirm the availability of the clock.
Debug Flow – SDI II Rx Issue
The following diagram shows an overview of the SDI II Rx debug flow.
Debug Steps – SDI II Rx Implementation
- Ensure all signals connected to SDI II MegaCore appropriately.
- Example: rx_coreclk_is_ntsc_paln must set to “LOW” when receiver controller clock is 148.5MHz or “HIGH” when reference clock is 148.35MHz.
- receiver controller clock, rx_coreclk
- Ensure reset is synchronous with reference clock.
- Example: Ensure the equalizer used is support SD/HD/3G when user using SDI triple rate mode.
- Enable “Increase Tolerance Level” option.
- Signal tap rx_std, rx_dataout, rx_ln, rx_ln_b, rx_trs, rx_frame_locked, rx_trs_locked, rx_align_locked, rx_clkout to verify the problem.
- Ensure cascade pll is not applied to the serial reference clock. (Not recommended).
- Ensure the incoming SDI data is clean (within SDI jitter spec) and correct.
Clock Frequency For SDI II Rx
- You can use either reference clock to received 1/1.000 and 1/1.001 data rate factor.
Signal Tap – SDI II Rx Implementation
- Ensure rx_std, rx_dataout, rx_ln, rx_ln_b, rx_trs shows correctly.
- Ensure rx_align_locked, rx_trs_locked, rx_frame_locked asserted.
Debug Steps – Reconfiguration
- When power up, the transceiver is running at 3G/SD mode. Reconfiguration is not performed.
- Reconfiguration perform when incoming signal is switch from SD/3G to HD, HD to SD/3G or incoming signal is not available.
- Keep sending the 3G or SD signal to receiver during power up.
- Ensure the 3G or SD signal is locked properly.
- Switch the incoming signal to HD
- Locking issue happened
- Ensure the reconfig process is written correctly.
- Replacing the reconfig logic files (sdi_ii_ed_reconfig_mgmt & sdi_ii_reconfig_logic) from Altera reference design. (located in submodules folder) or
- Signal tap
- Ensure start reconfiguration is asserted when reconfiguration required.
- Ensure reconfig done is asserted after reconfiguration process.
- Ensure reconfig data are sent correct for HD or SD/3G mode. (refer to sdi_ii_reconfig_logic.v inside the submodules folder).
Debug Steps – SDI II Rx Transceiver
- Confirm all the transceiver signals are correct. Verify rx_parallel_data, rx_clkout, rx_pll_locked, rx_analogreset, rx_digitalreset, pll_powerdown. (you can found the signal by typing *phy|<signal name> into signal tap).
- Ensure all resets are released.
- Ensure mgmt_clk_clk, rx_clkout, and rx_parallel_data are available.
- Ensure LTD and LTR behaved correctly.
- LTD asserted : HD and 3G received.
- LTR asserted : SD received.
Signal Tap - SDI II Rx Transceiver
- rx_clkout might be same frequency and same phase with reference clock. If the signal tap clock triggered is reference clock, it will shows constant low or constant high.
- You may use rx_clkout as triggered clock to confirm the availability of the clock.
