Source Synchronous Analysis with TimeQuest
cancel
Showing results for
Search instead for
Did you mean:
Source Synchronous Timing.pdf
Source Synchronous Timing Projects.zip
This document goes into detail on how to constrain source-synchronous interfaces. It is a follow-on to the TimeQuest User Guide:
https://forums.intel.com/s/createarticlepage?articleid=a3g0P0000005R9MQAU&action=view
The document starts off with a standardized approach to constraining source-synchronous interfaces, called the Explicit Clock Method.  This easy-to-understand method works whether the FPGA is the receiver or transmitter, and if the interfaces are center-aligned or edge-aligned.
Next is a section on the Implicit Clock Method, which I consider to be purely optional.
There is a section called Miscellaneous, which covers many of the details and points of confusion for source-synchronous DDR interfaces.
Finally are the examples. There are some generic examples(without projects) as well as analysis of four Texas Instrument devices interfacing to an FPGA.
I started a thread on this document in the alteraforum at:
http://www.alteraforum.com/forum/showthread.php?p=128042#post128042
Version history
Last update:
‎06-26-2019 06:35 PM
Updated by:
Contributors
