What steps can I follow to bring up the E-tile PAM4 PMA?
cancel
Showing results for
Search instead for
Did you mean:
340 Discussions
What steps can I follow to bring up PAM4 PMA in Intel® Stratix® 10 FPGA / Intel Agilex® FPGA E-tile design?
Intel® Stratix® 10 FPGA/Intel Agilex® FPGA E-tile PHY requires a bring-up process to ensure normal operating. The PMA bring-up is user-triggered and requires configuring a few registers.
Registers 0x200 to 0x203 could be used to trigger a simple PMA bring-up process, and the steps are as follows.
  1. Enable PRBS31 and internal serial loopback.
    1. Write 0x200 = 0x0D     (enable PRBS31 and internal serial loopback)
    2. Write 0x201 = 0x0
    3. Write 0x202 = 0x0
    4. Write 0x203 = 0x93     (this picks the opcode for SET_OPERATION_MODE)
    5. Read 0x207 until it becomes 0x80. This indicates that the operation was completed successfully.
  1. Run initial adaptation. Enable mission mode, disable internal serial loopback and disable PRBS31.
    1. Write 0x200 = 0xE1     (medium adaptation effort for PAM4, disable PRBS after adaptation)
    2. Write 0x201 = 0x01     (disable internal serial loopback after adaptation)
    3. Write 0x202 = 0x01     (enable initial adaptation)
    4. Write 0x203 = 0x96     (this picks the opcode for START_ADAPTATION)
  1. Check the link status with “rx_is_lockedtodata.”
Loading PMA Configuration Register SET_OPERATION_MODE
Loading PMA Configuration Register START_ADAPTATION
Some extra steps or different register values may be required depending on real transceiver design and link behavior.
  • Static temperature flows (STF) and dynamic temperature flows (DTF) have different processes for successful link bring-up.
https://www.intel.com/content/www/us/en/programmable/documentation/kqh1479167866037.html#xld1535735424506
  • If using a PMA configuration, load the PMA configuration is required
https://www.intel.com/content/www/us/en/programmable/documentation/kqh1479167866037.html#vrl1547592218047
  • If RX simplex mode is used
https://www.intel.com/content/www/us/en/programmable/documentation/kqh1479167866037.html#xmz1573163945902
  • If valid data rate traffic is not available at the RX, rerun initial adaptation until valid traffic is available
You can refer to the Intel E-Tile Transceiver PHY User Guide for further details.
Notices & Disclaimers
Intel technologies may require enabled hardware, software or service activation.
No product or component can be absolutely secure.
© Intel Corporation.  Intel, the Intel logo, Altera, Arria, Cyclone, Enpirion, MAX, Nios, Quartus
and Stratix, and other Intel marks are trademarks of Intel Corporation or its subsidiaries.  Other names and brands may be claimed as the property of others.
The products described may contain design defects or errors known as errata which may cause the product to deviate from published specifications.  Current characterized errata are available on request.​
The Intel logo, and Intel Agilex are trademarks of Intel Corporation or its subsidiaries
He Zhengmiao (James)
Version history
Last update:
‎03-14-2023 10:54 PM
Updated by:
