GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
516 Discussions
Intel Graphics software not loading properly
scottgordon
Having issues on startup with intel software/ drivers not loading properly. I am having to remove it from task manager and reboot.
I noticed the GPU getting hot and the fans not running  but for a second then stop. the fan curve was not being used.  but upon reboot  it works again. at the end or the day I turn it off  and the next morning repeats.
scottgordon
Attached is the file you asked for.
Thank You
Scott Gordon
<<<email address removed>>>
AlHill
How about some information?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[CoPilot is a virus]
scottgordon
Thank You
Scott Gordon
