GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
477 Discussions
My A770 won't update anymore
YamaZahir
This has been this case for the last few updates. Everytime i extract it it just disappears. I've tried everything but nothing will work. Anybody know how i can fix this?
Mike_Intel
Hello YamaZahir,
For us to further check this, please help provide the following details:
  1. Can you share the steps on how you updated the driver?
  2. Can you share screenshot or video of the issue?
  3. Is it working before?
  4. What is your OS?
Michael L.
YamaZahir
I first used the driver&support assistant as i do normally. Then for some reason after its loading the installer it just crashes and it fails.
Also tried downloading the driver myself but that didn't work either. It always crashes after it tries loading as in the picture. This wasn't an issue up until like 2 months ago. Also this is on windows.
Also here is a picture of how many times i tried downloading the updates
I also have never since i have owned my intel arc have been able to download an update from the intel arc control.
Mike_Intel
Hello YamaZahir,
Thank you for the update
Let me ask additional questions about this issue.
  1. Are you using an Intel brand Arc Graphics?
  2. Can you share a picture of your Arc Graphics unit?
  3. Are you just trying to update the driver? Can you share the link where you downloaded the driver?
Michael L.
YamaZahir
Mike_Intel
Hello YamaZahir,
Have you tried contacting Asrock if they have their own custom driver for your Graphics card?
OEM manufacturer may alter, modify or enhance their product and to enable those enhancements, they may have their own drivers.
Michael L.
Mike_Intel
Hello YamaZahir,
Michael L.
YamaZahir
Mike_Intel
Hello YamaZahir,
Here is the latest generic driver for Arc A770. Kindly download it and install it manually. You may run the driver as Administrator to avoid errors during installation if your system needs user privilege's.
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Michael L.
YamaZahir
That won't work as i already explained.
Mike_Intel
Hello YamaZahir,
Have you tried running the installer as Administrator? Can you share a video manually installing the driver so that we can see if there is an error.
Michael L.
Mike_Intel
Hello YamaZahir,
Michael L.
YamaZahir
Here's a video showing that i doesn't work.
Mike_Intel
Hello YamaZahir,
Can you try these steps. Please follow all the steps specially disconnecting from the internet.
  1. Restart the system.
  2. Uninstall the existing graphics driver.
    1. Disconnect from the internet to make sure the driver will not be automatically updated by Windows.
    2. Go to the Intel Graphics entry in the Device Manager.
    3. Right-click Intel Graphics and click Uninstall.
    4. In the device removal dialog box, check Delete the driver software for this device and click OK.
    5. Restart the computer after the uninstallation is complete.
  3. Install the driver again by downloading the specific driver from Download Center.
Michael L.
YamaZahir
Mike_Intel
Hello YamaZahir,
Thank you for the update.
We need to further check this issue. Kindly generate the latest SSU logs of your system for us to investigate.
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
Michael L.
YamaZahir
Here are the last logs
Mike_Intel
Hello YamaZahir,
Michael L.
ACarmona_Intel
Hello YamaZahir,
Thank you so much for providing us your SSU.
Please try the following troubleshooting below for a possible solution with the issue:
  1. Uninstall the driver using the Display Driver Uninstaller. Instructions in this article: How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
  2. Download the latest intel graphics driver. (instructions in this article, How to Get Zip File Version) of the Intel® Graphics Driver.
  3. Unzip the driver.
  4. Open Device Manager:
  • Right-click the Intel® ArcTM Graphics device from the Display Adapters section. From the drop-down menu, choose Update Driver.
    • Click Browse my computer for drivers.
    • Click Browse, search for, and select the unzipped folder of the driver.
    • Once the driver is installed, restart the computer.
Note: An alternative method to compress files is to utilize the built-in compression functionality provided by Windows, commonly referred to as the 'Compressed (zipped) Folder' feature.
And for further guidance, refer to this article: Exit Code 1: There was a problem repairing your driver in the Intel® ArcTM Graphics article, which outlines the identical steps necessary for the query. A third-party application can also be used to zip the file, such as 7-Zip.
By the way, if you have any questions, please let me know.
Furthermore, please let us know the result of the troubleshooting steps that you are about to perform, since if the issue still persists, we will raise the case with our engineers for further investigation.
Carmona A.
Mike_Intel
Hello YamaZahir,
I am just making a follow up if you tried our last recommendations.
Michael L.
Mike_Intel
Hello YamaZahir,
I am sending another follow up to check if you tried our recommendations.
Michael L.
