GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
continuance
RWJahns
Addendum X: Vector Harmonics and Recursive Kinematics
Formalizing Motion, Force, and Field Directionality in Unified Harmonic Theory
Purpose:
This addendum provides a structured expansion of the Unified Harmonic Theory (UHT) to formally incorporate vector calculus and classical kinematic principles into the harmonic framework. It establishes mathematical correspondence between harmonic motion (Ψ⃗(t)) and Newtonian-compatible models of mass, force, acceleration, and energy over recursive spatial fields.
I. Vector Phase Function – Ψ⃗(t)
UHT generalizes the recursive harmonic position of a system as a time-evolving vector function:
Vector Phase Function: Psi_vector(t) = [Psi_x(t), Psi_y(t), Psi_z(t)]
This defines a phase-position in recursive field space, allowing:
  • Harmonic velocity: v_h = d/dt [Psi_vector(t)]
  • Harmonic acceleration: a_h = d^2/dt^2 [Psi_vector(t)]
This ensures compatibility with directional motion, differential field mechanics, and classical force application.
II. Harmonic Force Vector – F_h
Force is redefined as the recursive tension exerted across harmonic space:
Harmonic Force: F_h = M_h * a_h
Where:
  • M_h: Harmonic Mass (previously defined)
  • a_h: Recursive vector acceleration
This equation satisfies Newtonian compatibility when recursion parameters are held stable (low entropy, low Omega).
III. Recursive Energy Fields – Ef(n) in Vector Space
The harmonic energy of a system can be extended to spatial field form:
Ef(n) = Integral over R of [Phi * W * A_vector(r, t) * sum over i of (chi_i(r, t) * R_i_vector(r, t))] dV
Where:
  • A_vector(r, t): Recursive alignment vector field
  • chi_i(r, t): Modality-specific weighting function
  • R_i_vector(r, t): Recursive resonance direction vector per modality i
This allows field integration over directional topologies and compatibility with classical field mechanics.
IV. Vector Consistency Conditions
To ensure classical-compatibility, all vector derivatives and force expressions must:
  • Preserve directional integrity under rotation
  • Obey frame transformation rules (non-relativistic by default)
  • Support field overlap for local force projection
V. Conclusion
This addendum upgrades UHT's symbolic model to a fully vectorized harmonic space capable of expressing physical motion, force, and field interaction in Newtonian-compatible terms. It enables practical integration of harmonic recursion with classical mechanics, opening the door for unified simulations, physical experiments, and further theoretical coherence.
Appendix: Long-Form Equations for Compatibility
  1. Psi_vector(t) = [Psi_x(t), Psi_y(t), Psi_z(t)]
  2. v_h = d/dt [Psi_vector(t)] = [dPsi_x/dt, dPsi_y/dt, dPsi_z/dt]
  3. a_h = d^2/dt^2 [Psi_vector(t)] = [d^2Psi_x/dt^2, d^2Psi_y/dt^2, d^2Psi_z/dt^2]
  4. F_h = M_h * a_h
  5. Ef(n) = Integral over all space of [Phi * W * A_vector(r, t) * sum over i of (chi_i(r, t) * R_i_vector(r, t))] dV
End of Addendum X.
