GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
524 Discussions
[hellow world sycl program] runtime call abort() while call sycl::handler::parallel_for
gamma-coco
It should be a stupid problem. Can any one please tell me what was happened .
The following is the problem code:
#include <sycl/sycl.hpp>
#include <vector>
#include <iostream>
#include <string>
#if FPGA_HARDWARE || FPGA_EMULATOR || FPGA_SIMULATOR
#include <sycl/ext/intel/fpga_extensions.hpp>
#endif
void exception_handler(sycl::exception_list exceptions) {
		for (std::exception_ptr const& e : exceptions) {
			try {
				std::rethrow_exception(e);
			catch (sycl::exception const& e) {
				std::wcout << L"Caught asynchronous SYCL exception: ";
				std::cout << e.what() << std::endl;
int wmain(int argc, char* argv[]) {
	constexpr size_t dataSize = 10000;
	std::vector<int> hostData;
	hostData.resize(dataSize);
	sycl::queue commandQueue(sycl::gpu_selector_v);
	std::cout << "run in device: " << commandQueue.get_device().get_info<sycl::info::device::name>() << std::endl;
		sycl::range<1> dataRange(dataSize);
		sycl::buffer<int, 1> dataBuffer(hostData.data(), hostData.size());
		commandQueue.submit([&](sycl::handler& handle) {
			sycl::accessor<int, 1, sycl::access::mode::write, sycl::access::target::device> dataAccesor(dataBuffer, handle, sycl::write_only, sycl::no_init);
			handle.parallel_for(dataRange, [=](auto index) {
				dataAccesor[index] = (double)index;
	return 0;
gamma-coco
Thanks all,
I name the Kernal and now it worked without conclude to a function. That final code is:
#include <vector>
#include <iostream>
#include <string>
#endif
constexpr int dataSize = 1000;
			try {
int wmain(int argc, wchar_t* argv[]) {
    auto selector = sycl::default_selector_v;
    std::vector<float> dataSet_1;
	dataSet_1.resize(dataSize);
    try {
        sycl::queue commandQueue(sycl::gpu_selector_v, exception_handler);
        std::cout << "Running on device: "
        std::cout << "Vector size: " << dataSet_1.size() << std::endl;
			sycl::range<1> num_items{ dataSet_1.size() };
			sycl::buffer<float, 1> sum_buf(dataSet_1.data(), num_items);
			commandQueue.submit([&](sycl::handler& h) {
				sycl::accessor<float, 1, sycl::access::mode::write> accessBuffer(sum_buf, h, sycl::write_only, sycl::no_init);
				h.parallel_for<class MyKernal>(num_items, [=](sycl::id<1> i) {
					accessBuffer[i] = 0.01F * (float)i;
		// Wait until compute tasks on GPU done
		commandQueue.wait();
		sycl::buffer<float> bufferA(dataSet_1);
		sycl::host_accessor readAccessor(bufferA, sycl::read_only);
		for (auto item : readAccessor) {
			std::cout << item << std::endl;
        std::cout << "An exception is caught: " << e.what() <<std::endl;
        std::terminate();
	return 0;
The point is I must name the kernal.
Ben_A_Intel
Hello!  A good first thing to check is: do you have a supported GPU?  Because you're specifically requesting a GPU queue...
... if you don't have a GPU you'll get an exception when you try to use it.
If you aren't sure, can you please include your output if you run sycl-ls?
A few other helpful things to know would be: How are you compiling your program?  What OS and what compiler version are you using?  Is there any other information included in the abort() message?
gamma-coco
Thank @Ben_A_Intel for quick response.
I have a GPU, it is the result of sycl-ls
C:\Program Files (x86)\Intel\oneAPI>sycl-ls
[opencl:acc:0] Intel(R) FPGA Emulation Platform for OpenCL(TM), Intel(R) FPGA Emulation Device 1.2 [2023.16.6.0.28_042959]
[opencl:cpu:1] Intel(R) OpenCL, Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz 3.0 [2023.16.6.0.28_042959]
[opencl:gpu:2] Intel(R) OpenCL Graphics, Intel(R) Arc(TM) A770 Graphics 3.0 [31.0.101.4669]
[ext_oneapi_level_zero:gpu:0] Intel(R) Level-Zero, Intel(R) Arc(TM) A770 Graphics 1.3 [1.3.26771]
I use visual studio 2022 & DPC++ in windows.
The abort() occurs by memory access exception:
Unhandled exception at 0x00007FF8DAB24C3C in SyclRun.exe: Microsoft C++ exception: sycl::_V1::runtime_error at memory location 0x00000094D2739570.
if I comment out the "handle.parallel_for()" statement:
			//handle.parallel_for(dataRange, [=](auto index) {
			//	dataAccesor[index] = index;
the program exit normally.
gamma-coco
I did the following 2 changes and it works:
1.) use float instead of double in Kenerl function
    ** It seems Intel A770 GPU don't support FP64
2.) conclude the submit call to a seperate function.
   ** If I don't do it, it failed with "No kernel named was found -46 (PI_ERROR_INVALID_KERNEL_NAME)"
The worked code is:
#include <vector>
#include <iostream>
#include <string>
#endif
void vectorInitialize(sycl::queue& commandQueue, std::vector<float>& dataSet) {
	sycl::range<1> num_items{ dataSet.size() };
	sycl::buffer<float, 1> sum_buf(dataSet.data(), num_items);
	h.parallel_for(num_items, [=](sycl::id<1> i) {
			try {
    try {
		vectorInitialize(commandQueue, dataSet_1);
        std::terminate();
	return 0;
Thanks for @Ben_A_Intel  for your help.
Now the new question is why I must conclude the vectorInitialize to a function.
gamma-coco
Thanks all,
#include <vector>
#include <iostream>
#include <string>
#endif
			try {
    try {
        std::terminate();
	return 0;
SeshaP_Intel
We can see that your issue got resolved. Could you please confirm whether we can close this thread from our end?
Thanks and Regards,
Pendyala Sesha Srinivas
gamma-coco
dear @SeshaP_Intel ,
Thank you for reply.
Yes, this issue can be closed.
Thanks & regards,
Gamma
SeshaP_Intel
Thanks for the confirmation. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
