815 Discussions
CS2 crashed - Failure.Exception.IP.Module=igd10umt64xe.DLL
Rafa3
CS2 crashed. The dump it generated mentions that Failure.Exception.IP.Module=igd10umt64xe.DLL  after I analyzed it with WinDbg.
My pc specs are the following:
- OS: Windows 11
- CPU: 1215U
- iGPU drivers: 32.0.101.7088
I attached the dump file in a zip file to this post.
IP_IN_PAGED_CODE:
igd10umt64xe!QueryDesiredMode1+50c76
00007fff`10334496 4883780800 cmp qword ptr [rax+8],0
SYMBOL_NAME: igd10umt64xe+a4496
MODULE_NAME: igd10umt64xe
IMAGE_NAME: igd10umt64xe.DLL
STACK_COMMAND: ~13s; .ecxr ; kb
FAILURE_BUCKET_ID: INVALID_POINTER_READ_c0000005_igd10umt64xe.DLL!Unknown
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
IMAGE_VERSION: 32.0.101.7088
FAILURE_ID_HASH: {50f3037f-17d3-fd14-0052-46e3d505301c}
Followup: MachineOwner
Rafa3
Would a 9GB memory dump file help you to track down the issue? Because I had one from once it crashed randomly and the game did not "crash succesfully" by creating a dump file, so I created a memory dump with task manager.
I could try that with the latest (7088) driver provided by Intel.
Jobert_Intel
Hi Rafa3,
Thank you so much for your response and for going the extra mile to help us investigate this further — we truly appreciate it!
To answer your question, yes, a 9GB memory dump file would absolutely be helpful in tracking down the issue. Please go ahead and provide us with the dump file using the latest driver version 7088 provided by Intel. Once we have received the file, we will review it and use it to further investigate the root cause of the issue.
Regarding the Black Ops issue, we kindly ask that you create a new thread for that concern, as we are only able to address one issue per thread. This will allow us to give each concern the full attention it deserves and ensure a more efficient resolution for both issues.
If you have any questions or need further assistance in the meantime, please do not hesitate to reach out. We look forward to receiving the dump file and getting this fully resolved for you as soon as possible!
Jobert T.
Jobert_Intel
Hi Rafa3,
I wanted to check if you had the chance to review the questions I posted.
Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jobert T.
Rafa3
Yes,
  1. The dump files of "Failure.Exception.IP.Module=igd10umt64xe.DLL" crashes I can attach are from crashes that occur in the moment exactly 1. after launching the game, 2. during the black screen with the "VALVE" black letters inside the red rectangle, and 3. before the transition to the orange slide with the "Counter Strike..." letters. Sometimes these occur before the "VALVE" letters appear.
  2. I deleted the 9GB memory dump that I had generated and, after hours attempting for a random crash in-game in a map loaded. That is, the "Failure.Exception.IP.Module=igd10umt64xe.DLL"-crash while playing the game and not the random crash after launching the game.
  3. I will try to recreate the conditions that I remember for the 9GB memory dump that I generated once. If I recall correctly, it happened after I tried clearing the DirectX shader cache. That seemed to crash consistently.
  4. The 7088 driver resolved the previously mentioned artifacting in Black Ops. It is not a real issue if your team already fixed that.
Rafa3
The dump files described in 1. are inside the zip file attached here.
Jobert_Intel
Hi Rafa3,
Thank you for sharing the information I requested. I will look into this further and will update you as soon as a solution is found. I appreciate your patience and understanding.
Jobert T.
alexmorgan2121
The dump strongly points toward the Intel graphics driver, since igd10umt64xe.DLL is the module where the access violation occurred. I’d first try a clean installation of the Intel graphics driver rather than simply updating over the existing version. If possible, test both the latest driver and the OEM driver provided for your specific laptop, since OEM packages can include platform-specific fixes.
I’d also make sure Windows 11 is fully updated and verify whether the crash occurs only in CS2. If it happens consistently after driver installation, try disabling overlays and hardware acceleration from other applications and test CS2 with default graphics settings.
Because the failure is an INVALID_POINTER_READ inside the Intel graphics module, the dump is useful evidence for Intel support. If a clean driver installation and OEM driver do not resolve it, I’d provide the dump, exact system model, BIOS version, and CS2 crash details when reporting the issue.
SeanD_Intel
Hi @alexmorgan2121,
Thank you for your input and suggestions — we truly appreciate your willingness to help the community!
@Rafa3, has already performed several of the troubleshooting steps you mentioned, including clean driver installations using DDU, testing both the Intel Generic driver and the OEM driver provided by Lenovo, as well as a full Windows reinstall. Despite these efforts, the issue has continued to persist.
Hello @Rafa3,
Considering the current situation, we would like to suggest the following additional steps to help further isolate the issue:
1. Disable Fast Startup
Fast Startup saves the system state to a hibernation file, which may preserve an unstable driver state across sessions. Disabling this forces Windows to reload the kernel and graphics driver cleanly on every boot, which may help prevent the crash from occurring after waking from sleep.
  1. Open Control Panel > Power Options
  2. Click "Choose what the power buttons do"
  3. Click "Change settings that are currently unavailable"
  4. Uncheck "Turn on fast startup" and save the changes
2. Clear DirectX Shader Cache
Corrupted shader files that are restored from a sleep state can force the driver to attempt invalid memory reads during game startup compilation, which aligns closely with the behavior you have been experiencing.
  1. Open the Start Menu, search for and open Disk Cleanup
  2. Select your C: drive
  3. Check DirectX Shader Cache and click OK to delete
  4. Restart your PC afterward
Please try both steps and let us know if the issue persists after applying them.
Sean Lemuel D.
