cpu : i7 13700k
gpu : 4070ti oc rog arena
ram : Corsair DIMM 32 GB DDR5-7000 (2x 16 GB
power : 1200w green 80 Plus
ssd : corsair mp600 Gen4 m.2
cpu fan : deepcool assassin IV
case : Lian Li LANCOOL III E-ATX Case
Motherboard : z790-f wifi
Monitor : Asus PG259QN 360hz panel ips
Hello, don't be upset. I have a problem. I bought a computer with these specifications almost a year ago. One day my game is fast, the next day my game is heavy. For example, I change Windows. One day everything is fine. The next day when I turn off the computer, it becomes heavy. My game is 300 <400 >200 fps and the GPU temperature is 50/40 and the CPU is 60/50. This means that the problem is not due to heat. I have no problems with FPS drops or heavy games. Everything is the same. Can I solve my problem with Intel? Please help.؟؟
Have you checked with nvidia? It is their graphics card.
Have you updated your bios? The bios belongs to the board manufacturer, not Intel.
Do you know for certain that the powersupply is not experiencing any problems? Even the best/latest/greatest can have problems.
Is your windows updated? You did not specify what windows you have. Microsoft is responsible for windows.
Now, the Intel possibly. Have you run the IPDT? If not, do so and post the results:
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
[W10 is this generation's XP]
Most have a 4070ti or 2060.
yes i have new bios update and windos 10
I don't think it's from Windows.
Test result and I have to say that I use the control fan program to keep the computer and graphics cool.
OK, it says the processor is fine.
It could be the processor.
It could be the power supply. Do you have another supply to test with?
It could be the motherboard. Do you have another board to test with?
It could be the card.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Hi l0x0r,
- When did the issue start? Was it after a specific driver update or game patch?
- Have you tried adjusting the graphics settings?
- Could you provide a screenshot of your in-game display and graphics settings?
- Which gaming platform did you use to download the game?
- Have you checked for any background applications or processes that might be affecting performance?
- Have you tried running the game in a clean boot environment to rule out software conflicts?
- Are there any specific changes you make before the performance drops occur?
Archie D.
- When did the issue start? Was it after a specific driver update or game patch? after update csgo to cs2
- Have you tried adjusting the graphics settings? yes
- Could you provide a screenshot of your in-game display and graphics settings? yes
- Which gaming platform did you use to download the game? steam
- Have you checked for any background applications or processes that might be affecting performance? yes
- Have you tried running the game in a clean boot environment to rule out software conflicts? NO how
- Are there any specific changes you make before the performance drops occur? no
Hi l0x0r,
Thank you for providing the requested information. I will investigate this and will get back to you once a resolution is available. Thank you for your patience and understanding.
Archie D.
Hi l0x0r,
I would also like to obtain a CapFrameX log to thoroughly analyze the FPS performance. Kindly ensure that the game would run for a minimum of 2 minutes.
Once you have the test results, please perform a clean boot in Windows and capture again a second CapFrameX log so I can compare it.
If you have any questions, please let me know. Thank you.
Archie D.
Hi l0x0r,
Did you have a chance to review the previous post? Please feel free to reach out if you have any questions. Thank you.
Archie D.
Hi l0x0r,
Archie D.
