公告
Heavy cs2 game
l0x0r
初学者
3,475 次查看
cpu : i7 13700k
gpu : 4070ti oc rog arena
ram : Corsair DIMM 32 GB DDR5-7000 (2x 16 GB
power : 1200w green 80 Plus
ssd : corsair mp600 Gen4 m.2
cpu fan : deepcool assassin IV
case : Lian Li LANCOOL III E-ATX Case
Motherboard : z790-f wifi
Monitor : Asus PG259QN 360hz panel ips
Hello, don't be upset. I have a problem. I bought a computer with these specifications almost a year ago. One day my game is fast, the next day my game is heavy. For example, I change Windows. One day everything is fine. The next day when I turn off the computer, it becomes heavy. My game is 300 <400 >200 fps and the GPU temperature is 50/40 and the CPU is 60/50. This means that the problem is not due to heat. I have no problems with FPS drops or heavy games. Everything is the same. Can I solve my problem with Intel? Please help.؟؟
0 项奖励
11 回复数
AlHill
超级用户
3,470 次查看
Have you checked with nvidia?  It is their graphics card.
Have you updated your bios? The bios belongs to the board manufacturer, not Intel.
Do you know for certain that the powersupply is not experiencing any problems?  Even the best/latest/greatest can have problems.
Is your windows updated?  You did not specify what windows you have.  Microsoft is responsible for windows.
Now, the Intel possibly.  Have you run the IPDT?  If not, do so and post the results:
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
[W10 is this generation's XP]
0 项奖励
l0x0r
初学者
3,459 次查看
Most have a 4070ti or 2060.
yes i have new bios update and windos 10
I don't think it's from Windows.
0 项奖励
l0x0r
初学者
3,452 次查看
Test result and I have to say that I use the control fan program to keep the computer and graphics cool.
0 项奖励
AlHill
超级用户
3,446 次查看
OK, it says the processor is fine.
It could be the processor.
It could be the power supply.  Do you have another supply to test with?
It could be the motherboard.  Do you have another board to test with?
It could be the card.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
0 项奖励
l0x0r
初学者
3,417 次查看
Do you mean this file?
0 项奖励
ArchieD_Intel
主持人
3,306 次查看
Hi l0x0r,
  • When did the issue start? Was it after a specific driver update or game patch?
  • Have you tried adjusting the graphics settings?
  • Could you provide a screenshot of your in-game display and graphics settings?
  • Which gaming platform did you use to download the game?
  • Have you checked for any background applications or processes that might be affecting performance?
  • Have you tried running the game in a clean boot environment to rule out software conflicts?
  • Are there any specific changes you make before the performance drops occur?
Archie D.
0 项奖励
l0x0r
初学者
3,278 次查看
  • When did the issue start? Was it after a specific driver update or game patch? after update csgo to cs2
  • Have you tried adjusting the graphics settings?   yes
  • Could you provide a screenshot of your in-game display and graphics settings? yes
  • Which gaming platform did you use to download the game?  steam
  • Have you checked for any background applications or processes that might be affecting performance? yes
  • Have you tried running the game in a clean boot environment to rule out software conflicts? NO how
  • Are there any specific changes you make before the performance drops occur? no
0 项奖励
ArchieD_Intel
主持人
3,079 次查看
Hi l0x0r,
Thank you for providing the requested information. I will investigate this and will get back to you once a resolution is available. Thank you for your patience and understanding.
Archie D.
0 项奖励
ArchieD_Intel
主持人
2,999 次查看
Hi l0x0r,
I would also like to obtain a CapFrameX log to thoroughly analyze the FPS performance. Kindly ensure that the game would run for a minimum of 2 minutes.
Once you have the test results, please perform a clean boot in Windows and capture again a second CapFrameX log so I can compare it.
If you have any questions, please let me know. Thank you.
Archie D.
0 项奖励
ArchieD_Intel
主持人
2,836 次查看
Hi l0x0r,
Did you have a chance to review the previous post? Please feel free to reach out if you have any questions. Thank you.
Archie D.
0 项奖励
ArchieD_Intel
主持人
2,656 次查看
Hi l0x0r,
Archie D.
0 项奖励
回复
