682 Discusiones
Honkai Impact 3rd & Arc A770 collour blink
GSage
Principiante
15.074 Vistas
im using Intel Arc A770 8GB to play Honkai Impact 3.
the display always blinking to gray when im playing in Elysian Realm Stages(normal stages collour is purple). not just in the Elysian Realm actually
its not my monitor problem cuz i tried record&livestream.
and i dont think its a game fault, cuz only intel arc user had that problem.
is there a way to fix it?
please help me
0 kudos
1 Solución
Andres_Intel
Empleados
11.190 Vistas
Hello GSage,
Thank you for your clarification, it helps a lot.
I will continue with the investigation and as soon as I have further detailed I will let you know.
Andres P.
Ver la solución en mensaje original publicado
21 Respuestas
Andres_Intel
Empleados
13.848 Vistas
Hello GSage,
Thank you for posting on the Intel communities. I am aware that when you play Honkai Impact 3rd on your Intel® Arc™ A770 Graphics, you are experiencing color blinking.
For a better understanding of the situation, please answer the following questions:
Andres P.
GSage
Principiante
13.819 Vistas
i just change my setting an not blinking anymore. but its still gray(normal stages in Elysian Realm > Shallow Squences is Purple).
- GPU im using is Asrock Intel Arc A770 Phantom Gaming D 8GB OC.
but, i saw some youtuber playing honkai use Arc A770 16GB(LE Edition) had a same problem.
- i bought from Nano Computer at Tokopedia.
Andres_Intel
Empleados
13.802 Vistas
Hello GSage,
Thank you for your response and for all the information provided.
I noticed on the Intel® SSU that your system is not up to date, please follow the steps below and let me know the results:
Also, please answer the following question, which will help us to replicate the issue as accurately as possible in case we need it:
  • Which store did you buy the game from? For example Steam, Epic Games, etc.
Andres P.
GSage
Principiante
13.736 Vistas
i tried all the steps. its still the same
i download PC Launcher from the official site (not steam version).
https://honkaiimpact3.hoyoverse.com/asia/en-us/download
Andres_Intel
Empleados
13.702 Vistas
Hello GSage,
Thank you for completing the recommended steps.
We would like to start with an investigation, first please provide us with step by step instructions in case we need to replicate this issue. You can share a list of numeric steps or a video, from the game download and installation until the color issue.
Andres P.
GSage
Principiante
13.661 Vistas
after download pc launcher from officiall website and everything.
1.  change the bridge theme
 - set Train to the Future
 - you will see lose color there
 - from Arc A770
 - from other devices
2. go to ATTACK > Elysian Realm > Quick Start > Shallow Squence
- if the collor stages not pink/purple its a bug.
 - bug 
 - normal
Andres_Intel
Empleados
13.565 Vistas
Hello GSage,
Thank you for providing us with the step-by-step instructions, that is very helpful.
Last week we released a new graphics driver that may help to solve this issue, please follow the steps below and keep me informed of the results:
Andres P.
GSage
Principiante
13.511 Vistas
no changes with the newer driver. tell me when its actually fix for HI3 game
Andres_Intel
Empleados
13.485 Vistas
Hello GSage,
Thank you for your answer and for completing all the steps.
I will start with an investigation to provide you with the next steps, as soon as I have further information I will let you know.
Andres P.
Andres_Intel
Empleados
13.131 Vistas
Hello GSage,
Thank you for your time.
We still working on the issue reproduction I we hope to have the results soon, as soon as I have them I will let you know.
Andres P.
Andres_Intel
Empleados
12.893 Vistas
Hello GSage,
Thank you for your patience.
We have been working on the issue reproduction, we will have the results soon, I will let you know the results as soon as possible.
Andres P.
Jean_Intel
Empleados
12.723 Vistas
Hello GSage,
We would like to inform you that we have been able to replicate the issue you described. Nevertheless, we will continue to investigate the issue internally and will keep you posted with more details as soon as possible.
Jean O.
Andres_Intel
Empleados
11.731 Vistas
Hello GSage,
Thank you for all your time and patience.
We are still working on the investigation, but we would like you to update the graphics driver to the latest version, please keep us informed of the results:
Andres P.
Andres_Intel
Empleados
11.671 Vistas
Hello GSage,
Were you able to clean install the graphics driver with DDU and then install the latest graphics driver 31.0.101.5186
Andres P.
GSage
Principiante
11.643 Vistas
nothing changes. i need to play like an hour to get consistent texture.
but then i exit and reopen the game, glitch issue comes back.
i still dont understand but when im using power plan
- High Performance : texture wont load consistently, but when theres specific effect it'll glitch to normal.
- Power Saving : most of the time normal texture is loaded but inconsistent
i dont mind if the gpu takes more power. i just need consistent texture!
still waiting for the next updates. thx.
Andres_Intel
Empleados
11.617 Vistas
Hello GSage,
Thank you for letting us know the results.
We will continue with the investigation and as soon I have further details for you, I will let you know.
Andres P.
Andres_Intel
Empleados
10.051 Vistas
Hello GSage,
Thank you for all your time.
I want to let you know that our debug team tried once again replicating the issue following these steps:
  1. Start the game and advance until the Change Bridge" option appears.
  2. Set "Train to the Future" and click on "Preview".
  3. Check if the screen colors are rendered incorrectly (bright blue).
Do we need to play for an amount of time to see the issue now? We need a way to consistently see the issue in order to debug it.
Andres P.
GSage
Principiante
10.025 Vistas
from my experience, when the Bridge "Train to The Future" is rendered corretly,
most of the stages like Elysian Realm, Shallow Squence, etc will be rendered too.
but, best way to check the glitch issue is just  play Shallow Squence stages
Andres_Intel
Empleados
11.191 Vistas
Hello GSage,
Andres P.
NormanS_Intel
Moderador
7.294 Vistas
Hello GSage,
Thank you for bringing this issue to our attention. We apologize for the long wait, as we conducted a thorough investigation into your report. I would like to inform you that our priority is to target the most popular games and apps to focus our efforts on providing a high-quality, stable experience for the broadest set of users. We will continue to improve our software performance and compatibility throughout 2024 and beyond. While we can’t accommodate your request at this time, please watch our Display Changes to Grey when Playing Honkai Impact 3rd* with Intel® Arc™ Graphics article on our website for any possible changes to this situation.
Please feel free to reach out if you have any questions.
Thank you for understanding.
Norman S.
Responder
