Intel Graphics Command Center
JadeJacarandaYT
when i start to record valorant(fullscreen) with intel graphic command center, it automatically stops recording when a alt tab to the game. When i play valorant in full screen windowed, then recording works fine. What may cause this?
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
