701 Discussions
Werid High cpu Usage in game Related to Resource Loading
cnalligator
My laptop has worked unproperly all of a sudden ever since someday.
It appears to be high cpu usage with around 70~80% during games which never happened before. For small games the high cpu usage seemed to last for mins then drop to normal usage with 20%; For some games like The Division2 , it just stays at 80%(Which used to be 40%). It has caused frame rate drop and gpu usage drop like from 90% down to aroound 70%, especaially in large games.
The problem seems to be relevant to resource loading.
I checked the threads with Process Explorer during high cpu usage in game, it seemd that threads named "nvd3dumx.dll!QueryOglResource" has eaten up half of the cpu usage, which never happened like that before. The loading threads tends to stay for a long time taking up high cpu uasge even everything seemed all loaded fine. For some games larger it just keeps on with high useage
I don't quite remember if i had updated the system or the drivers the day before this problem came out. But i've tried uninstalling the driver with ddu and reinstalling the stable one i used before, repairing the games themselves, reinstalling dx and all kinds of library and driver, and restoring the computer several times (with files saved), but none of them worked.
I've also run many test applications for the disk, ram, cpu and gpu but they all seemed to work just fine.
This problem came out all of a sudden one day, and I completely have no clue whether it's a hardware problem or a software problem anymore, coulud really use some help.
My sytem info:
System Information
Time of this report: 7/18/2022, 21:49:48
Machine name: DESKTOP-K06U71F
Machine Id: {00007606-7353-48BA-81D4-6CBF01942B9C}
Operating System: Windows 11 家庭中文版 64-bit (10.0, Build 22000) (22000.co_release.210604-1628)
Language: Chinese (Simplified) (Regional Setting: Chinese (Simplified))
System Manufacturer: MECHREVO
System Model: Taitan Series GM7MG0M
BIOS: N.1.07MRO05 (type: UEFI)
Processor: Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz (16 CPUs), ~2.3GHz
Memory: 16384MB RAM
Available OS Memory: 16292MB RAM
Page File: 9498MB used, 9737MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 144 DPI (150 percent)
System DPI Setting: 144 DPI (150 percent)
DWM DPI Scaling: UnKnown
Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: Unknown
DxDiag Version: 10.00.22000.0653 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce RTX 3060 Laptop GPU
Manufacturer: NVIDIA
Chip type: NVIDIA GeForce RTX 3060 Laptop GPU
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_2520&SUBSYS_11161D05&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 14168 MB
Dedicated Memory: 6023 MB
Shared Memory: 8145 MB
Current Mode: 2560 x 1440 (32 bit) (165Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.639648,0.330078), Green(0.299805,0.599609), Blue(0.149414,0.059570), White Point(0.312500,0.329102)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: BOE0977
Native Mode: 2560 x 1440(p) (40.002Hz)
Output Type: Displayport Embedded
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvldumdx.dll
Driver File Version: 30.00.0015.1123 (English)
Driver Version: 30.0.15.1123
DDI Version: 12
Feature Levels: 12_2,12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 3.0
Hardware Scheduling: DriverSupportState:Stable Enabled:True
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported by Graphics driver
Detachable GPU: No
Hybrid Graphics GPU: Discrete
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 2022/1/10 8:00:00, 1058432 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71E3E-6660-11CF-D67A-19310EC2D335}
Vendor ID: 0x10DE
Device ID: 0x2520
SubSys ID: 0x11161D05
Revision ID: 0x00A1
Driver Strong Name: oem82.inf:0f066de34e33bff9:Section057:30.0.15.1123:pci\ven_10de&dev_2520&subsys_11161d05
Rank Of Driver: 00CF0001
Video Accel:
DXVA2 Modes: {86695F12-340E-4F04-9FD3-9253DD327460} DXVA2_ModeMPEG2_VLD {6F3EC719-3735-42CC-8063-65CC3CB36616} DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD {32FCFE3F-DE46-4A49-861B-AC71110649D5} DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 {20BB8B0A-97AA-4571-8E99-64E60606C1A6} {15DF9B21-06C4-47F1-841E-A67C97D7F312} DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC {9947EC6F-689B-11DC-A320-0019DBBC4184} {33FCFE41-DE46-4A49-861B-AC71110649D5} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {DDA19DC7-93B5-49F5-A9B3-2BDA28A2CE6E} {B8BE4CCB-CF53-46BA-8D59-D6B8A6DA5D2A} {6AFFD11E-1D96-42B1-A215-93A31F09A53D} {914C84A3-4078-4FA9-984C-E2F262CB5C9C} {8A1A1031-29BC-46D0-A007-E9B092CA6767}
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 4
MPO Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
MPO Stretch: 10.000X - 0.500X
MPO Media Hints: resizing, colorspace Conversion
MPO Formats: NV12,P010,YUY2,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
PanelFitter Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
PanelFitter Stretch: 10.000X - 0.500X
Sound Devices
Description: 扬声器 (Realtek(R) Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0274&SUBSYS_1D05112B&REV_1000
Manufacturer ID: N/A
Product ID: N/A
Type: N/A
Driver Name: RTKVHD64.sys
Driver Version: 6.0.9102.1 (English)
WHQL Logo'd: Yes
Date and Size: 2021/1/12 8:00:00, 6021608 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Emulation Only
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: 麦克风 (Realtek(R) Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 1
FriendlyName: HD Webcam
Category: Camera
SymbolicLink: \\?\usb#vid_04f2&pid_b65a&mi_00#6&fa823cd&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
Rotation: 0
SensorOrientation: 0
Manufacturer: Microsoft
HardwareID: USB\VID_04F2&PID_B65A&REV_2210&MI_00,USB\VID_04F2&PID_B65A&MI_00
DriverDesc: USB Video Device
DriverProvider: Microsoft
DriverVersion: 10.0.22000.708
DriverDateEnglish: 6/21/2006 00:00:00
DriverDateLocalized: 2006/6/21 0:00:00
Service: usbvideo
Class: Camera
DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
ProblemCode: No Problem
BusReportedDeviceDesc: HD Webcam
Parent: USB\VID_04F2&PID_B65A\0001
DriverProblemDesc: n/a
UpperFilters: n/a
LowerFilters: WdmCompanionFilter
Stack: \Driver\ksthunk,\Driver\usbvideo,\Driver\ACPI,\Driver\usbccgp
ContainerCategory: n/a
SensorGroupID: n/a
MFT0: n/a
DMFT: n/a
CustomCaptureSource: n/a
DependentStillCapture: False
EnablePlatformDMFT: True
DMFTChain: n/a
EnableDshowRedirection: True
FrameServerEnabled: n/a
AnalogProviders: n/a
MSXUCapability: n/a
ProfileIDs: n/a
DirectInput Devices
Device Name: 鼠标
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: 键盘
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC539
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1A81, 0x2039
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: ITE Device(8291)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x048D, 0x6008
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: HIDI2C Device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x093A, 0x0274
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB 根集线器(USB 3.0)
| Vendor/Product ID: 0x8086, 0x06ED
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 7/16/2022 08:39:50, 696656 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 6/5/2021 20:04:46, 221512 bytes
| +-+ USB 输入设备
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 6/5/2021 20:04:46, 73728 bytes
| | | Driver: hidclass.sys, 6/5/2021 20:04:46, 274432 bytes
| | | Driver: hidparse.sys, 6/5/2021 20:04:46, 77824 bytes
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 7/16/2022 08:39:50, 69632 bytes
| | | | Driver: kbdclass.sys, 7/16/2022 08:39:50, 91488 bytes
| +-+ USB 输入设备
| | | Service: HidUsb
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 7/16/2022 08:39:49, 65536 bytes
| | | | Driver: mouclass.sys, 7/16/2022 08:39:49, 91488 bytes
| | Service: usbccgp
| +-+ USB 输入设备
| | | Service: HidUsb
| | | | Service: kbdhid
| +-+ USB 输入设备
| | | Service: HidUsb
| | | | Service: kbdhid
Gameport Devices
PS/2 Devices
+ PS/2 标准键盘
| Matching Device ID: *PNP0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/16/2022 08:39:49, 155648 bytes
| Vendor/Product ID: 0x093A, 0x0000
| Service: mouhid
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 33.9 GB
Total Space: 102.4 GB
File System: NTFS
Model: SAMSUNG MZVLQ512HALU-00000
Drive:
Free Space: 106.6 GB
Total Space: 385.0 GB
File System: NTFS
System Devices
Name: Intel(R) USB 3.1 可扩展主机控制器 - 1.10 (Microsoft)
Device ID: PCI\VEN_8086&DEV_06ED&SUBSYS_11161D05&REV_00\3&11583659&0&A0
Driver: C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS, 10.00.22000.0778 (Chinese (Simplified)), 7/16/2022 08:39:50, 656736 bytes
Driver: C:\WINDOWS\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.22000.0778 (English), 7/16/2022 08:39:50, 162592 bytes
Name: Realtek Gaming 2.5GbE Family Controller
Device ID: PCI\VEN_10EC&DEV_8125&SUBSYS_11161D05&REV_05\01000000684CE00000
Driver: C:\WINDOWS\system32\DRIVERS\rt640x64.sys, 10.54.1111.2021 (Chinese (Simplified)), 1/17/2022 20:04:24, 1159224 bytes
Name: Intel(R) PCI Express Root Port #14 - 06B5
Device ID: PCI\VEN_8086&DEV_06B5&SUBSYS_11161D05&REV_F0\3&11583659&0&ED
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.22000.0778 (Chinese (Simplified)), 7/16/2022 08:39:48, 537960 bytes
Name: Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x16) - 1901
Device ID: PCI\VEN_8086&DEV_1901&SUBSYS_11161D05&REV_02\3&11583659&0&08
Name: Intel(R) Serial IO UART Host Controller - 06A8
Device ID: PCI\VEN_8086&DEV_06A8&SUBSYS_11161D05&REV_00\3&11583659&0&F0
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ialpss2_uart2_cnl.inf_amd64_df1115697e57a59a\iaLPSS2_UART2_CNL.sys, 30.100.2020.0007 (English), 5/14/2020 09:42:46, 305928 bytes
Name: Intel(R) Wi-Fi 6 AX201 160MHz
Device ID: PCI\VEN_8086&DEV_06F0&SUBSYS_00748086&REV_00\3&11583659&0&A3
Driver: C:\WINDOWS\system32\DRIVERS\Netwtw10.sys, 22.00.0001.0001 (English), 10/2/2020 11:16:02, 5526888 bytes
Driver: C:\WINDOWS\system32\DRIVERS\Netwfw10.dat, 10/2/2020 11:16:02, 26575820 bytes
Driver: C:\WINDOWS\system32\IntelIHVRouter08.dll, 21.12120.0000.0001 (English), 10/2/2020 11:16:02, 1062248 bytes
Name: Intel(R) PCI Express Root Port #9 - 06B0
Device ID: PCI\VEN_8086&DEV_06B0&SUBSYS_11161D05&REV_F0\3&11583659&0&E8
Name: 标准 NVM Express 控制器
Device ID: PCI\VEN_144D&DEV_A809&SUBSYS_A801144D&REV_00\4&6EC92F8&0&00E8
Driver: C:\WINDOWS\system32\DRIVERS\stornvme.sys, 10.00.22000.0527 (English), 7/16/2022 08:39:49, 226672 bytes
Name: Intel(R) SMBus - 06A3
Device ID: PCI\VEN_8086&DEV_06A3&SUBSYS_11161D05&REV_00\3&11583659&0&FC
Driver: n/a
Name: Intel(R) LPC Controller (HM470) - 068D
Device ID: PCI\VEN_8086&DEV_068D&SUBSYS_11161D05&REV_00\3&11583659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.22000.0001 (English), 6/5/2021 20:04:45, 53576 bytes
Name: Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) Gaussian Mixture Model - 1911
Device ID: PCI\VEN_8086&DEV_1911&SUBSYS_11161D05&REV_00\3&11583659&0&40
Driver: n/a
Name: Intel(R) Thermal Subsystem - 06F9
Device ID: PCI\VEN_8086&DEV_06F9&SUBSYS_11161D05&REV_00\3&11583659&0&90
Driver: n/a
Name: NVIDIA GeForce RTX 3060 Laptop GPU
Device ID: PCI\VEN_10DE&DEV_2520&SUBSYS_11161D05&REV_A1\4&F1CE845&0&0008
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NVWMI\nvPerfProvider.man, 1/11/2022 07:54:58, 14175 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NVWMI\nvWmi.mof, 1/11/2022 07:54:58, 148921 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NVWMI\nvWmi64.exe, 2.36.0000.0000 (English), 1/11/2022 16:52:28, 4478432 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\MessageBus.dll, 1.22.2758.1620 (English), 1/11/2022 16:51:38, 7534520 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\NVDisplay.Container.exe, 1.35.3033.8148 (English), 1/11/2022 16:51:40, 1018496 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\NvContainerRecovery.bat, 1/11/2022 07:54:58, 1951 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\dlsargs.xml, 1/11/2022 07:54:58, 544 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\dlsnetparams.csv, 1/11/2022 07:54:58, 1191192 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\messagebus_client.conf, 1/11/2022 07:54:58, 57 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\nvgwls.exe, 1/11/2022 16:51:42, 33227904 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\nvtopps.db3, 1/11/2022 07:54:58, 122880 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\LocalSystem\NvXDCore.dll, 30.00.0015.1123 (English), 1/11/2022 16:51:46, 1842296 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\LocalSystem\NvcDispCorePlugin.dll, 30.00.0015.1123 (English), 1/11/2022 16:51:44, 523704 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\LocalSystem\NvcDispWatchdog.dll, 1.34.3030.7627 (English), 1/11/2022 16:51:44, 744376 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\LocalSystem\_DisplayDriverRAS.dll, 1.10.0000.0000 (English), 1/11/2022 16:51:48, 2617472 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\LocalSystem\_NvMsgBusBroadcast.dll, 1.34.3030.7627 (English), 1/11/2022 16:51:50, 3190200 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\LocalSystem\messagebus.conf, 1/11/2022 07:54:58, 57 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\LocalSystem\wksServicePluginZero.dll, 30.00.0015.1123 (English), 1/11/2022 16:51:48, 1238144 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\Session\NvFBCPlugin.dll, 6.14.0015.1123 (English), 1/11/2022 16:51:52, 1379968 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\Session\_nvppo.dll, 30.00.0015.1123 (English), 1/11/2022 16:52:00, 1607800 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\Session\_nvtopps.dll, 30.00.0015.1123 (English), 1/11/2022 16:52:02, 14253536 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\Session\nvprofileupdaterplugin.dll, 30.00.0015.1123 (English), 1/11/2022 16:51:54, 2192512 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\Session\nvxdsyncplugin.dll, 8.17.0015.1123 (English), 1/11/2022 16:51:56, 1815208 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\Display.NvContainer\plugins\Session\wksServicePlugin.dll, 30.00.0015.1123 (English), 1/11/2022 16:51:58, 622248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 30.00.0015.1123 (English), 1/11/2022 16:45:20, 731096 bytes
Driver: C:\WINDOWS\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 1/11/2022 07:54:58, 1821968 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 8.17.0015.1123 (English), 1/11/2022 16:46:48, 5733504 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nv3dappshext.dll, 6.14.0015.1123 (English), 1/11/2022 16:45:40, 1001896 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nv3dappshextr.dll, 6.14.0015.1123 (Chinese (Simplified)), 1/11/2022 16:45:42, 94176 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvcoproc.bin, 1/11/2022 07:54:58, 9888657 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvcpl.dll, 8.17.0015.1123 (English), 1/11/2022 16:46:48, 5733504 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvdevtools.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:22, 4545144 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvdevtoolsr.dll, 30.00.0015.1123 (Chinese (Simplified)), 1/11/2022 16:47:24, 234424 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvdisps.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:26, 11603368 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvdispsr.dll, 30.00.0015.1123 (Chinese (Simplified)), 1/11/2022 16:47:28, 11320248 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvgames.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:52, 12360872 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvgamesr.dll, 30.00.0015.1123 (Chinese (Simplified)), 1/11/2022 16:47:54, 12646056 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvlicensings.dll, 6.14.0015.1123 (English), 1/11/2022 16:48:44, 4550104 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvlicensingsr.dll, 6.14.0015.1123 (Chinese (Simplified)), 1/11/2022 16:48:46, 296416 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvshext.dll, 1.02.0000.0001 (English), 1/11/2022 16:50:28, 131000 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvsmartmax.dll, 6.14.0010.10003 (English), 1/11/2022 16:50:32, 204968 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvsmartmax64.dll, 6.14.0010.10003 (English), 1/11/2022 16:50:36, 246232 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvsmartmaxapp.exe, 6.14.0010.10003 (English), 1/11/2022 16:50:38, 276448 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvsmartmaxapp64.exe, 6.14.0010.10003 (English), 1/11/2022 16:50:40, 284840 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvsvc64.dll, 30.00.0015.1123 (Chinese (Simplified)), 1/11/2022 16:50:42, 2654168 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvsvcr.dll, 30.00.0015.1123 (Chinese (Simplified)), 1/11/2022 16:50:44, 1767040 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvsvs.dll, 30.00.0015.1123 (English), 1/11/2022 16:50:44, 5063096 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvsvsr.dll, 30.00.0015.1123 (English), 1/11/2022 16:50:46, 1946224 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvui.dll, 8.17.0015.1123 (English), 1/11/2022 16:50:50, 6644848 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvuir.dll, 8.17.0015.1123 (Chinese (Simplified)), 1/11/2022 16:50:52, 2611328 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvvitvs.dll, 30.00.0015.1123 (English), 1/11/2022 16:51:00, 7407544 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvvitvsr.dll, 30.00.0015.1123 (Chinese (Simplified)), 1/11/2022 16:51:00, 4112000 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvwss.dll, 30.00.0015.1123 (English), 1/11/2022 16:51:08, 12206208 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvwssr.dll, 30.00.0015.1123 (Chinese (Simplified)), 1/11/2022 16:51:10, 9360816 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvxdapix.dll, 8.17.0015.1123 (English), 1/11/2022 16:51:12, 9326520 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvxdbat.dll, 8.17.0015.1123 (English), 1/11/2022 16:51:16, 1622440 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvxdplcy.dll, 8.17.0015.1123 (English), 1/11/2022 16:51:18, 1874048 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libcuda.so, 1/11/2022 07:54:58, 137240 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libcuda.so.1, 1/11/2022 07:54:58, 137240 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libcuda.so.1.1, 1/11/2022 07:54:58, 137240 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libnvcuvid.so, 1/11/2022 07:54:58, 5864608 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libnvcuvid.so.1, 1/11/2022 07:54:58, 5864608 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libnvdxdlkernels.so, 1/11/2022 07:54:58, 35512144 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libnvidia-encode.so, 1/11/2022 07:54:58, 424400 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libnvidia-encode.so.1, 1/11/2022 07:54:58, 424400 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libnvidia-ml.so.1, 1/11/2022 07:54:58, 207272 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libnvidia-opticalflow.so, 1/11/2022 07:54:58, 354768 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libnvidia-opticalflow.so.1, 1/11/2022 07:54:58, 354768 bytes
Driver: C:\WINDOWS\system32\lxss\lib\libnvwgf2umx.so, 1/11/2022 07:54:58, 45918760 bytes
Driver: C:\WINDOWS\system32\lxss\lib\nvidia-smi, 1/11/2022 07:54:58, 690808 bytes
Driver: C:\WINDOWS\system32\DRIVERS\NVIDIA Corporation\license.txt, 6/24/2022 11:05:46, 28827 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\_nvngx.dll, 30.00.0015.1123 (English), 1/11/2022 16:51:38, 1542576 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\cudnn_infer64_7.dll, 1/11/2022 16:45:14, 22774200 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvngx.dll, 30.00.0014.9516 (English), 1/11/2022 16:48:52, 487592 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvngx_update.exe, 30.00.0015.1123 (English), 1/11/2022 16:48:56, 1187960 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvngxdlss.dll, 1/11/2022 16:48:54, 26280 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\FreqTransfer32.exe, 1/11/2022 16:52:06, 3704744 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\FreqTransfer64.exe, 1/11/2022 16:52:08, 4003440 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\GreenScreenBG01.jpg, 1/11/2022 07:54:58, 281528 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\GreenScreenBG02.jpg, 1/11/2022 07:54:58, 499736 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\HighresBlender32.exe, 1/11/2022 16:52:08, 3810416 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\HighresBlender64.exe, 1/11/2022 16:52:10, 4109280 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\NvCamera32.dll, 7.01.0797.0802 (English), 1/11/2022 16:52:12, 8043448 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\NvCamera64.dll, 7.01.0797.0802 (English), 1/11/2022 16:52:12, 8543872 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\NvCameraAllowlisting32.dll, 7.01.0797.0802 (English), 1/11/2022 16:52:14, 558200 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\NvCameraAllowlisting64.dll, 7.01.0797.0802 (English), 1/11/2022 16:52:14, 704936 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\NvCameraEnable.exe, 1/11/2022 16:52:16, 370800 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\NvImageConvert32.exe, 1/11/2022 16:52:18, 3705976 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\NvImageConvert64.exe, 1/11/2022 16:52:20, 3987368 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\ReShadeFXC32.exe, 2.00.0000.0000 (English), 1/11/2022 16:52:20, 774056 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\ReShadeFXC64.exe, 2.00.0000.0000 (English), 1/11/2022 16:52:22, 887920 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\ShotWithGeforce518x32.rgba, 1/11/2022 07:54:58, 66304 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\SphericalEquirect32.exe, 1/11/2022 16:52:24, 3674744 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\SphericalEquirect64.exe, 1/11/2022 16:52:24, 3923880 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\Sticker01.png, 1/11/2022 07:54:58, 49695 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\Sticker02.png, 1/11/2022 07:54:58, 474002 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\Sticker03.png, 1/11/2022 07:54:58, 380006 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\Sticker04.png, 1/11/2022 07:54:58, 86881 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\Sticker05.png, 1/11/2022 07:54:58, 59304 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\Sticker06.png, 1/11/2022 07:54:58, 13547 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\Sticker07.png, 1/11/2022 07:54:58, 6342 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\Sticker08.png, 1/11/2022 07:54:58, 96493 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\d3dcompiler_47_32.dll, 6.03.9600.16384 (English), 1/11/2022 16:52:04, 3466872 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\d3dcompiler_47_64.dll, 6.03.9600.16384 (English), 1/11/2022 16:52:04, 4175784 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\scratches.jpg, 1/11/2022 07:54:58, 346354 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\tools_licenses.txt, 1/11/2022 07:54:58, 15970 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvCamera\ui.tga, 1/11/2022 07:54:58, 120236 bytes
Driver: C:\WINDOWS\system32\MCU.exe, 1.01.5204.20580 (Chinese (Simplified)), 1/11/2022 16:45:36, 849016 bytes
Driver: C:\WINDOWS\system32\nvdebugdump.exe, 6.14.0015.1123 (English), 1/11/2022 16:47:16, 455800 bytes
Driver: C:\WINDOWS\system32\nvidia-smi.exe, 8.17.0015.1123 (English), 1/11/2022 16:48:10, 710824 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvopencl32.dll, 30.00.0015.1123 (English), 1/11/2022 16:49:26, 16292792 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvopencl64.dll, 30.00.0015.1123 (English), 1/11/2022 16:49:32, 18970552 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvcompiler32.dll, 30.00.0015.1123 (English), 1/11/2022 16:45:50, 41486504 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvcompiler64.dll, 30.00.0015.1123 (English), 1/11/2022 16:46:04, 46249912 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvcompilernext32.dll, 30.00.0015.1123 (English), 1/11/2022 16:46:16, 60178352 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvcompilernext64.dll, 30.00.0015.1123 (English), 1/11/2022 16:46:32, 67797432 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvlddmkm.sys, 30.00.0015.1123 (English), 1/11/2022 16:48:36, 42270168 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libcuda.so.1.1, 1/11/2022 07:54:58, 22555496 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libcuda_loader.so, 1/11/2022 07:54:58, 137240 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libnvcuvid.so.1, 1/11/2022 07:54:58, 5864608 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libnvdxdlkernels.so, 1/11/2022 07:54:58, 35512144 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libnvidia-encode.so.1, 1/11/2022 07:54:58, 424400 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libnvidia-ml.so.1, 1/11/2022 07:54:58, 1869112 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libnvidia-ml_loader.so, 1/11/2022 07:54:58, 207272 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libnvidia-nvvm.so, 1/11/2022 07:54:58, 26941176 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libnvidia-opticalflow.so.1, 1/11/2022 07:54:58, 354768 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libnvidia-ptxjitcompiler.so.1, 1/11/2022 07:54:58, 11419032 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\libnvwgf2umx.so, 1/11/2022 07:54:58, 45918760 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nv-vk64.json, 1/11/2022 07:54:58, 671 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvDecMFTMjpeg.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:18, 639400 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvDecMFTMjpegx.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:20, 812656 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvEncMFTH264.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:36, 1172920 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvEncMFTH264x.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:38, 1457272 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvEncMFThevc.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:40, 1177512 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvEncMFThevcx.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:40, 1470584 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvcuda32.dll, 30.00.0015.1123 (English), 1/11/2022 16:46:50, 20415408 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvcuda64.dll, 30.00.0015.1123 (English), 1/11/2022 16:46:56, 23575680 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvd3dumx.dll, 30.00.0015.1123 (English), 1/11/2022 16:44:38, 24974672 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvd3dumx_cfg.dll, 30.00.0015.1123 (English), 1/11/2022 16:44:46, 25218848 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvdlistx.dll, 30.00.0015.1123 (English), 1/11/2022 16:45:00, 216136 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvdxdlkernels.dll, 1/11/2022 16:47:34, 35818616 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvidia-smi, 1/11/2022 07:54:58, 690808 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvldumdx.dll, 30.00.0015.1123 (English), 1/11/2022 16:45:04, 1058432 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvml.dll, 8.17.0015.1123 (English), 1/11/2022 16:48:48, 1170400 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvoglv64.dll, 30.00.0015.1123 (English), 1/11/2022 16:49:14, 49773736 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvoptix.bin, 1/11/2022 07:54:58, 133668492 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvoptix.dll, 7.04.0001.0000 (English), 1/11/2022 16:49:42, 43128448 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvptxJitCompiler32.dll, 30.00.0015.1123 (English), 1/11/2022 16:49:58, 7974016 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvptxJitCompiler64.dll, 30.00.0015.1123 (English), 1/11/2022 16:50:02, 9100456 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvrtum64.dll, 30.00.0015.1123 (English), 1/11/2022 16:50:08, 72648360 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvvm64_40_0.dll, 6.14.0011.9000 (English), 1/11/2022 16:51:04, 17957304 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvwgf2umx.dll, 30.00.0015.1123 (English), 1/11/2022 16:45:22, 43279720 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvwgf2umx_cfg.dll, 30.00.0015.1123 (English), 1/11/2022 16:45:36, 43691680 bytes
Driver: C:\WINDOWS\system32\NvFBC64.dll, 6.14.0015.1123 (English), 1/11/2022 16:47:50, 2120872 bytes
Driver: C:\WINDOWS\system32\NvIFR64.dll, 6.14.0015.1123 (English), 1/11/2022 16:48:32, 1528440 bytes
Driver: C:\WINDOWS\system32\OpenCL.dll, 3.00.0001.0000 (English), 1/11/2022 16:51:26, 1466792 bytes
Driver: C:\WINDOWS\system32\nvEncodeAPI64.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:46, 983208 bytes
Driver: C:\WINDOWS\system32\nvapi64.dll, 30.00.0015.1123 (English), 1/11/2022 16:44:26, 7609160 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:06, 2935776 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 7.17.0015.1123 (English), 1/11/2022 16:47:12, 8609912 bytes
Driver: C:\WINDOWS\system32\nvinfo.pb, 1/11/2022 07:54:58, 89178 bytes
Driver: C:\WINDOWS\system32\nvml.dll, 8.17.0015.1123 (English), 1/11/2022 16:48:50, 711848 bytes
Driver: C:\WINDOWS\system32\nvofapi64.dll, 1/11/2022 16:49:00, 798168 bytes
Driver: C:\WINDOWS\system32\vulkan-1-999-0-0-0.dll, 1.03.0198.0001 (English), 6/24/2022 23:26:20, 1432304 bytes
Driver: C:\WINDOWS\system32\vulkan-1.dll, 1.03.0198.0001 (English), 6/24/2022 23:26:20, 1432304 bytes
Driver: C:\WINDOWS\system32\vulkaninfo-1-999-0-0-0.exe, 1.03.0198.0001 (English), 6/24/2022 23:26:30, 1905936 bytes
Driver: C:\WINDOWS\system32\vulkaninfo.exe, 1.03.0198.0001 (English), 6/24/2022 23:26:30, 1905936 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nv-vk32.json, 1/11/2022 07:54:58, 671 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvIccAdvancedColorIdentity.icm, 1/11/2022 07:54:58, 3288 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvd3dum.dll, 30.00.0015.1123 (English), 1/11/2022 16:44:30, 21250248 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvd3dum_cfg.dll, 30.00.0015.1123 (English), 1/11/2022 16:44:54, 21655440 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvdispco64.exe, 1.00.0016.0000 (English), 1/11/2022 16:47:24, 1552296 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvdlist.dll, 30.00.0015.1123 (English), 1/11/2022 16:45:00, 181808 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvldumd.dll, 30.00.0015.1123 (English), 1/11/2022 16:45:02, 882224 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvoglv32.dll, 30.00.0015.1123 (English), 1/11/2022 16:49:02, 36471768 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvwgf2um.dll, 30.00.0015.1123 (English), 1/11/2022 16:45:08, 35323536 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\nvwgf2um_cfg.dll, 30.00.0015.1123 (English), 1/11/2022 16:45:48, 35938120 bytes
Driver: C:\WINDOWS\SysWow64\NvFBC.dll, 6.14.0015.1123 (English), 1/11/2022 16:47:48, 1602216 bytes
Driver: C:\WINDOWS\SysWow64\NvIFR.dll, 6.14.0015.1123 (English), 1/11/2022 16:48:30, 1179096 bytes
Driver: C:\WINDOWS\SysWow64\OpenCL.dll, 3.00.0001.0000 (English), 1/11/2022 16:51:24, 1206384 bytes
Driver: C:\WINDOWS\SysWow64\nvEncodeAPI.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:42, 793768 bytes
Driver: C:\WINDOWS\SysWow64\nvapi.dll, 30.00.0015.1123 (English), 1/11/2022 16:44:22, 6455824 bytes
Driver: C:\WINDOWS\SysWow64\nvcuda.dll, 30.00.0015.1123 (English), 1/11/2022 16:47:04, 5098112 bytes
Driver: C:\WINDOWS\SysWow64\nvcuvid.dll, 7.17.0015.1123 (English), 1/11/2022 16:47:08, 7713408 bytes
Driver: C:\WINDOWS\SysWow64\nvofapi.dll, 1/11/2022 16:48:58, 638936 bytes
Driver: C:\WINDOWS\SysWow64\vulkan-1-999-0-0-0.dll, 1.03.0198.0001 (English), 6/24/2022 23:26:26, 1145584 bytes
Driver: C:\WINDOWS\SysWow64\vulkan-1.dll, 1.03.0198.0001 (English), 6/24/2022 23:26:26, 1145584 bytes
Driver: C:\WINDOWS\SysWow64\vulkaninfo-1-999-0-0-0.exe, 1.03.0198.0001 (English), 6/24/2022 23:26:34, 1478384 bytes
Driver: C:\WINDOWS\SysWow64\vulkaninfo.exe, 1.03.0198.0001 (English), 6/24/2022 23:26:34, 1478384 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvtfig.inf_amd64_90367366be992b1c\NvTelemetry64.dll, 14.03.0060.0000 (English), 1/11/2022 16:50:48, 4466112 bytes
Name: Intel(R) Host Bridge/DRAM Registers - 9B44
Device ID: PCI\VEN_8086&DEV_9B44&SUBSYS_11161D05&REV_02\3&11583659&0&00
Driver: n/a
Name: Intel(R) Serial IO I2C Host Controller - 06E8
Device ID: PCI\VEN_8086&DEV_06E8&SUBSYS_11161D05&REV_00\3&11583659&0&A8
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ialpss2_i2c_cnl.inf_amd64_666eecf21665eb26\iaLPSS2_I2C_CNL.sys, 30.100.2020.0007 (English), 5/14/2020 09:42:42, 196360 bytes
Name: Intel(R) Management Engine Interface #1
Device ID: PCI\VEN_8086&DEV_06E0&SUBSYS_11161D05&REV_00\3&11583659&0&B0
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\heci.inf_amd64_c22251d5ea82b3c3\x64\TeeDriverW10x64.sys, 2131.01.0004.0000 (English), 8/19/2021 05:30:18, 309384 bytes
Name: Intel(R) Chipset SATA/PCIe RST Premium Controller
Device ID: PCI\VEN_8086&DEV_06D7&SUBSYS_11161D05&REV_00\3&11583659&0&B8
Driver: C:\WINDOWS\system32\DRIVERS\iaStorAC.sys, 17.09.0000.1007 (English), 4/30/2020 10:35:04, 1346528 bytes
Driver: C:\WINDOWS\system32\DRIVERS\iaStorAfs.sys, 17.09.0000.1007 (English), 4/30/2020 10:35:04, 74208 bytes
Driver: C:\WINDOWS\system32\iaStorAfsService.exe, 17.09.0000.1007 (English), 4/30/2020 10:35:06, 2924000 bytes
Driver: C:\WINDOWS\system32\iaStorAfsNative.exe, 17.09.0000.1007 (English), 4/30/2020 10:35:06, 220640 bytes
Driver: C:\WINDOWS\system32\OptaneEventLogMsg.dll, 17.09.0000.1007 (English), 4/30/2020 10:35:08, 24552 bytes
Driver: C:\WINDOWS\system32\Optane.dll, 17.09.0000.1007 (English), 4/30/2020 10:35:08, 115176 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\iastorac.inf_amd64_86dc7f4c001ddecd\HfcDisableService.exe, 17.09.0000.1007 (English), 4/30/2020 10:35:02, 1916384 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\iastorac.inf_amd64_86dc7f4c001ddecd\RstMwService.exe, 17.09.0000.1007 (English), 4/30/2020 10:35:08, 2244072 bytes
Driver: C:\WINDOWS\system32\RstMwEventLogMsg.dll, 17.09.0000.1007 (English), 4/30/2020 10:35:08, 27624 bytes
Name: High Definition Audio 控制器
Device ID: PCI\VEN_8086&DEV_06C8&SUBSYS_112B1D05&REV_00\3&11583659&0&FB
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.22000.0001 (English), 6/5/2021 20:04:43, 180224 bytes
Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.22000.0653 (English), 7/16/2022 08:39:46, 135168 bytes
Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.22000.0653 (English), 7/16/2022 08:39:46, 462848 bytes
Device ID: PCI\VEN_10DE&DEV_228E&SUBSYS_11161D05&REV_A1\4&F1CE845&0&0108
Name: Intel(R) SPI (flash) Controller - 06A4
Device ID: PCI\VEN_8086&DEV_06A4&SUBSYS_11161D05&REV_00\3&11583659&0&FD
Driver: n/a
Name: Intel(R) Shared SRAM - 06EF
Device ID: PCI\VEN_8086&DEV_06EF&SUBSYS_11161D05&REV_00\3&11583659&0&A2
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.22000.0120
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.22000.0120
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.22000.0653
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.22000.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.22000.0001
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.22000.0653
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.22000.0120
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.22000.0653
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.22000.0653
DV Muxer,0x00400000,0,0,qdv.dll,10.00.22000.0653
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.22000.0001
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.22000.0653
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.22000.0001
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.22000.0001
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.22000.0653
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.22000.0795
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.22000.0653
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.22000.0653
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.22000.0001
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.22000.0001
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.22000.0001
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.22000.0653
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.22000.0653
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.22000.0653
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.22000.0653
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.22000.0708
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.22000.0001
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.22000.0001
DV Splitter,0x00600000,1,2,qdv.dll,10.00.22000.0653
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.22000.0001
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.22000.0708
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.22000.0001
Video Renderer,0x00800001,1,0,quartz.dll,10.00.22000.0001
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.22000.0653
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.22000.0001
Video Renderer,0x00400000,1,0,quartz.dll,10.00.22000.0001
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.22000.0653
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.22000.0653
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,10.00.22000.0653
File writer,0x00200000,1,0,qcap.dll,10.00.22000.0653
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.22000.0653
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.22000.0001
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.22000.0708
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.22000.0653
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.22000.0653
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.22000.0653
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.22000.0653
Null Renderer,0x00200000,1,0,qedit.dll,10.00.22000.0653
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.22000.0653
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.22000.0708
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.22000.0653
Smart Tee,0x00200000,1,2,qcap.dll,10.00.22000.0653
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.22000.0001
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.22000.0001
Wave Parser,0x00400000,1,1,quartz.dll,10.00.22000.0001
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.22000.0001
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.22000.0001
File stream renderer,0x00400000,1,1,quartz.dll,10.00.22000.0001
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.22000.0708
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.22000.0653
AVI Mux,0x00200000,1,0,qcap.dll,10.00.22000.0653
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.22000.0001
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.22000.0001
File Source (URL),0x00400000,0,1,quartz.dll,10.00.22000.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.22000.0653
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.22000.0708
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.22000.0653
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.22000.0001
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink 转换程序,0x00200000,1,1,ksproxy.ax,10.00.22000.0708
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.22000.0653
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.22000.0653
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.22000.0653
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.22000.0653
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.22000.0001
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.22000.0653
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.22000.0001
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.22000.0001
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.22000.0001
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.22000.0001
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.22000.0001
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.22000.0001
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.22000.0001
Audio Capture Sources:
麦克风 (Realtek(R) Audio),0x00200000,0,0,qcap.dll,10.00.22000.0653
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.22000.0653
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.22000.0653
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.22000.0653
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.22000.0001
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.22000.0001
WDM Streaming Capture Devices:
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.22000.0708
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.22000.0708
HD Webcam,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.22000.0708
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22000.0653
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22000.0653
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22000.0653
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22000.0653
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.22000.0653
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.22000.0653
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.22000.0653
WDM Streaming Communication Transforms:
Audio Renderers:
扬声器 (Realtek(R) Audio),0x00200000,1,0,quartz.dll,10.00.22000.0001
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.22000.0001
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.22000.0001
DirectSound: 扬声器 (Realtek(R) Audio),0x00200000,1,0,quartz.dll,10.00.22000.0001
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
mfcore.dll, 10.00.22000.0795
mfreadwrite.dll, 10.00.22000.0001
mfcaptureengine.dll, 10.00.22000.0653
mfsensorgroup.dll, 10.00.22000.0708
windows.media.dll, 10.00.22000.0778
frameserver.dll, 10.00.22000.0708
frameserverclient.dll, 10.00.22000.0708
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpegx.dll, 30.00.0015.1123
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.22000.0795
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.22000.0653
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.22000.0001
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.22000.0795
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.22000.0653
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.22000.0120
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.22000.0653
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.22000.0653
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.22000.0653
WebpImageExtension
VP9VideoExtensionDecoder
HEIFImageExtension
Video Encoders:
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264x.dll, 30.00.0015.1123
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevcx.dll, 30.00.0015.1123
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.22000.0778
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.22000.0653
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.22000.0653
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.22000.0653
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.22000.0708
VP9VideoExtensionEncoder
HEIFImageExtension
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.22000.0653
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.22000.0653
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.22000.0653
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.22000.0653
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.22000.0071
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.22000.0593
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.22000.0778
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.22000.0708
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.22000.0120
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.22000.0708
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.22000.0795
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.22000.0795
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.22000.0120
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.22000.0653
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.22000.0653
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.22000.0708
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.22000.0653
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.22000.0795
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.22000.0795
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.22000.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.22000.0653
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.22000.0795
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.22000.0653
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.22000.0653
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.22000.0653
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.22000.0795
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.22000.0653
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.22000.0653
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.22000.0653
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.22000.0708
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.22000.0001
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.22000.0653
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.22000.0653
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.22000.0708
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.22000.0653
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.22000.0001
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.22000.0708
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.22000.0795
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D8033-DB46-11CF-B4D1-00805F6CBBEA}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
{C2FE6F0A-4E3C-4DF1-9B60-50863091E4B9}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
