656 Discusiones
Intel HD Graphics 620 Gpu Lags Games
WedgeBudgie
Principiante
8.802 Vistas
so one week ago, i did a clean install of windows 10 and installed everything new including drivers and so on But then after installing the drivers , and i started a Game I notice that my gpu was not using enough shared memory, only using 0.1 to 0.4 of the 8Gb of shared memory available and then i saw that my 3D on the GPU was Going Up and down many times and the shared memory is really low . I don't know what is happening? I did everything i could to fix the problem but I can't.
Specs:
 Processor Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz, 2712 Mhz.
16Gb Ram
i dont know what is happening ?
0 kudos
12 Respuestas
Jean_Intel
Empleados
8.749 Vistas
Hello WedgeBudgie,
Thank you for posing on the Intel communities. We understand that you are facing performance issues when playing games.
It is important to mention that the amount of graphics memory in use is dynamically allocated to balance the needs of the operating system and all running applications.
  • In what game are you experiencing this performance issue?
  • Is the issue present on older graphic drivers?
  • Verify the game's minimum requirements.
    • Confirm that no other heavy workload programs are running in the background while playing.
    • Open the Task Manager (Ctrl+Shift+Esc).
  • Click the CPU and Memory tabs to check whether anything is using up large chunks of your CPU or RAM (for instance, a web browser with many tabs open).
  • Create a report using the Intel System Support Utility (Intel SSU) report:
    • Download the Intel SSU
    • Open the application and click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
Also, we noticed that you have a different thread regarding this issue. To void duplicate efforts and confusion, we will close your other thread and will continue the support here.
Jean O.
WedgeBudgie
Principiante
8.708 Vistas
Hello it's me wedge i don't know why i cant access my other account that's why i couldn't respond so i did a new one.
    Guild wars 2 and Csgo simple to run games.
    yes it is persistent .
here is the report of the  Intel System Support Utility.
yeah Ty for closing my other Post.
also when i play games my CPu goes really hard on the laptop i dont know why . maybe thats why i have so much lag.
Jean_Intel
Empleados
8.721 Vistas
Hello WedgeBudgie,
We hope you are doing fine.
Jean O.
WedgeBudgie
Principiante
8.708 Vistas
yes i responded to the other post sorry for being this late but i couldn't access my other account idk why.
Jean_Intel
Empleados
8.677 Vistas
Hello WedgeBudgie
Thank you for your response.
Regarding your issue, we would like to recommend the following:
  • Check with the game developer for the latest patches and updates.
  • You mentioned that the CPU workload goes high when playing the games, please confirm that no other heavy workload programs are running in the background while playing.
  1. Open the Task Manager (Ctrl+Shift+Esc).
    1. Click the CPU tabs to check whether anything is using up large chunks of your CPU (for instance, a web browser with many tabs open).
  • Confirm that the processor passes the Intel® Processor Diagnostic Tool test.
  • It is important to mention that there are two different types of drivers, generics provided by Intel and Equipment Manufacturer drivers, that are customized to work with each specific system. The best thing to do is to use the drivers provided by the system manufacturer (OEM) to eliminate the potential impact caused by loading non-custom drivers. Please perform a clean driver installation, installing driver 20.19.15.4568.
Jean O.
WedgeBudgie
Principiante
8.656 Vistas
Okey first
    here is the test file.
    Then i try installing.
    this one but it wouldn't let me since it is Braswell and the laptop is Kaby Lake, So i installed this one
    Then this one i did installed and it did let me.
    i did try searching for a older graphics card with the number 20.19.15.4568  but i couldnt find any at all.
WedgeBudgie
Principiante
8.655 Vistas
also for some odd reason my GPU is now at
3.0ghz ? even do the base speed is 2.71ghz ? how do i changed it back like how did this happen ?
Jean_Intel
Empleados
8.579 Vistas
Hello WedgeBudgie,
About the frequency, it is important to mention that the Base Frequency for your CPU is 2.70 GHz; however, your processor's Max Turbo Frequency is 3.10 GHz, this is the maximum single-core frequency at which the processor is capable of operating using Intel® Turbo Boost Technology. The behavior you share is under the processor specifications.
Also, regarding your issue, we want to confirm the following:
  • When you look through the task manager, do you check if there is a specific app with a heavy workload under the processes tab?
  • Does the performance improve if you end unecessary app processes?
  • Are the task manager screenshots you shared from when you were running the game?
  • Do you know if the games worked like expected before?
Jean O.
WedgeBudgie
Principiante
8.540 Vistas
  • As for the Ghz of the CPU, i never set that to turbo boost at all. i dont know how that happen. it wasnt my doing.
    No at all when i run games the cpu goes crazy going down and up from 20 to 70 for nothing at all and thats why i have so many lagg spikes
    No at all
    yes they are those screenshots are when i run Guild wars 2 on the laptop
    not all since this laptop is used so the games are still running bad even do the ram is enough  but the cpu is the problem and i dont know why ? even do i can get my hands  on older graphic drivers like 25.00.00 for 620 hd graphics the most older ones i could get to install where 27.00.00. maybe i need older graphics drivers ?
    or is that the drivers of the cpu it self are really old or any other driver in this laptop.
Jean_Intel
Empleados
8.518 Vistas
Hello WedgeBudgie,
Thanks for the information provided.
It is essential to mention that the Intel® Turbo Boost Technology is an automatic process and it lets the CPU run at its base clock speed when handling light workloads, then jump to a higher clock speed for heavy workloads. That's why when you run the game, you put a heavy workload on the CPU, and in doing so, the  Intel® Turbo Boost Technology is activated increasing the CPU speeds up to the Max Turbo Frequency. For further information visit the following article.
We will look further into this scenario and give you a response as soon as possible.
Best regards
Jean O.
Jean_Intel
Empleados
8.373 Vistas
Hello WedgeBudgie,
We appreciate your patience.
We have tried to replicate your issue in our lab; unfortunately, we did not experience the problems you reported. We recommend you contact your system manufacturer (HP) for further support since this issue can be related to your system (memory, temperatures, etc.).
Also, you can reach out to the game developers for more recommendations.
Best regards
Jean O.
Jean_Intel
Empleados
8.241 Vistas
Hello WedgeBudgie,
Best regards.
Jean O.
Responder
