713 Discussions
NEW Intel Optimization Application Crashes Games
GrobiKenobi
Z690 ASUS HERO - 14900k - 4090 GPU - DDR5 7200Mhz RAM:
Hey guys! Was wondering if anyone else is experiencing crashing in the games with the new intel tech (APO) for 14th gen CPUs. Getting constant crashing in Rainbow Six Siege (One of the two games supported) I've copied the Event Viewer log below. Not Overclocking the CPU and ran multiple ram tests on my XMP profile and it is stable.
  • ESIF(1.0.11401.38408) TYPE: ERROR MODULE: IPF TIME 39141639 ms
  • DPTF Build Version: 9.0.11401.38310
  • DPTF Build Date: Aug 21 2023 09:31:57
  • Source File: C:\jenkins\workspace\dptf\Src\DPTF\Sources\Policies\ApplicationOptimizerPolicy
  • ApplicationOptimizerPolicy.cpp @ line 304
  • Executing Function: ApplicationOptimizerPolicy :: onPolicylnitiatedCallback
  • Message: Unable to set mask for RainbowSix.exe -
  • Source File: C:\jenkins\workspace\dptf\Src\DPTF\Sources\Manager\EsifServices.cpp @ line 866
  • Executing Function: EsifServices:primitiveExecuteSet
  • Message: Error returned from ESIF services interface function call
  • Participant: NoParticipant
  • Domain: NoDomain
  • ESIF Primitive: SET_PROCESS_AFFINITY_MASK [943]
  • ESIF Instance: 255
  • ESIF Return Code: ESIF_E_NOT_FOUND [3000]
  • Policy: Application Optimization Policy [0]
Jose_Intel
Hello @GrobiKenobi
Thank you for posting on the Intel️® communities.
We understand you are experiencing issues with Intel® Application Optimization, we will be more than happy to assist you.
Please answer the following:
·      Was it working before?
·      Have you tried setting the maximum supported RAM frequency 5600 MT/s?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the report from the Intel® Processor Diagnostic Tool
Jose B.
Jose_Intel
Hello GrobiKenobi
We hope you are doing fine.
Were you able to set the RAM clock speed at 5600 MT/s?
Let us know if you still need assistance by attaching the required reports.
Jose B.
Jose_Intel
Hello GrobiKenobi
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
