When using the B580 graphics card on Windows 11 25H2, games running under the Vulkan graphics API are forced into fullscreen mode instead of borderless windowed mode. During this time, the color gamut and brightness of the entire system are forcibly restricted. Even after closing the game, the color gamut and brightness restrictions do not revert (though this should be an issue on Microsoft’s side). Nevertheless, I still hope to see improved support for Vulkan as soon as possible, especially regarding borderless window functionality.
Hello lhmxing,
- Was it working fine before?
- If yes, what was the last change made in the system before the issue started?
- What are the troubleshooting steps that you tried before?
- We can only support 1 issue and/or 1 game per thread. Kindly tell me which game would you like us to focus on for this thread?
- For me to review the hardware and the driver installed, please help generate the SSU logs of your system. Kindly refer to the link below for the steps:
Michael L.
Hello lhmxing,
Michael L.
Hello lhmxing,
Thank you for the update.
Kindly try to perform driver update using DDU and update me on this thread if there will be changes using the latest driver.
Kindly refer to the link below for the steps and the direct link of the latest driver.
How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
Intel® Arc™ Graphics - Windows*
Michael L.
Hello lhmxing,
I am just making a follow up if you tried the recommendations from my last post.
Michael L.
Hello lhmxing,
I am sending another follow up to check if you already tried my last recommendation.
Michael L.
