667 Discussions
Why does my CPU use 100% randomly?
TacticTwinkie
Hello good afternoon everyone I hope you are well.
When i play video games the CPU has peaks of 100% usage (every 10, 20 minutes or every 15), if I use it for things like video editing and so on, multi task nothing bad happens, all stable, no lag at any time, the games go well even in ultra, high, medium, or low quality, but there always comes a time when it freezes for about 3 seconds because the CPU goes up to 100%, I have no rare processes in the background, I have tried windows 11,10 home or 10 LTSC original activated with key since its installation, no rare cracks, all legal, in windows settings I have the game mode activated and selecting by default the graphics card in high performance mode for the games I use, system reinstalled clean from 0 from the BIOS, updated drivers, I disabled windows startup programs that I did not need and so on, I have RAM to spare (32 GB) the system is not tight, no matter if I use windows 10 home, windows 11 or windows 10 LTSC, the thermal paste is new, if I have heatsink for the CPU, it was out of nowhere that started doing that, also i updated the BIOS to the lastest version and deactivated the cpu control by asus to grant the control to intel (default) and i have the same issue, nothing changes, Is there anything I should disable in the bios?, I don't know what to do anymore. (attached captures)
Thanks for reading, sorry for the bible.
Labels (2)
ACarmona_Intel
Hello TacticTwinkie,
May I know when the issue started? And to confirm, does the issue only arise when playing games?
Furthermore, please provide the complete model of your processor.
By the way, the queries that I have asked will greatly help me to quickly isolate the issue.
I look forward to your response!
Carmona A.
TacticTwinkie
Hello @ACarmona_Intel  the processor model is 11th Gen Intel(R) Core(TM) i5-11400 @ 2.60 GHz, it just started one day, I was playing normally and it started happening, I didn't change anything in the settings or from the BIOS, the lag just happen when i play, i have an GEFORCE RTX 3060Ti
David48
I have core i5 5th gen laptop.
ACarmona_Intel
Thank you so much for the quick response.
Please try the following troubleshooting steps outlined in this article for a possible solution.
By the way, you can skip the other troubleshooting steps if you have already taken them; furthermore, if the issue still persists, please provide an example of the games where the issue occurs and please generate an SSU report to help me further analyze important details on your system, such as the OS build number, graphics driver version, complete model of your system, etc. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file. This will help me to deeply investigate the issue.
And if you have any questions, please let me know.
Carmona A.
ACarmona_Intel
We would like to know if you have any questions regarding the recommendation that we have provided.
If so, kindly inform me, as we would be glad to assist you.
Carmona A.
ACarmona_Intel
Again, we would like to know if you have any questions regarding the recommendation that we have provided.
Carmona A.
NormanS_Intel
We have not heard back from you so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Norman S.
