673 Discussions
i31005g1 igpu disconnects under stress
kmilo
When im playing fortnite the game suddenly crashes saying something like "the gpu got disconnected" (this appears after the game freezes when is under so much stress or if i specifically open the festival or lego mode), also i was trying to use suyu o yuzu but using vulkan inmediately crashes the app (in the log says that the device got disconnected too)
I mentioned this two errors because it seems that the gpu panics under pressure, so my question is: how can i stop the gpu from hunging itself? even if i have to lower a little its performance
Labels (2)
RobbieR_Intel
Hello kmilo,
Thank you for reaching out! I understand that you're dealing with issues while playing Fortnite and using the Suyu/Yuzu emulator.
Kindly answer the following questions:
  • Did you make recent changes to the system?
  • Have you done troubleshooting steps?
  • Has this issue happened before, or is this a new problem you're experiencing?
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
We look forward to your response!
Robbie R.
RobbieR_Intel
Hello kmilo,
Robbie R.
RobbieR_Intel
Hello kmilo,
Robbie R.
