22959 Discussions
Как повысить частоту обновления экрана?
NMyuk
Доброй ночи! У меня новый Acer Predator Helios 300 (Win10, Core i5. RTX2060) и я никак не могу повысить частоту обновления экрана. По умолчанию стоит 60hz (экран поддерживает 144hz), обновление, удаление и новая установка драйверов никак проблему не решают. Нельзя выбрать ничего кроме 60hz
LeonWaksman
  1. Your laptop is equipped with GeForce RTX2060 graphics. Why are you are you using Intel Command Center and not GeForce setup?
  2. You should ask your question Acer support. Acer is responsible for your laptop.
Leon
n_scott_pearson
For laptop products, you should only use drivers validated and made available by your laptop manufacturer. Then, even if the drivers are from Intel, you laptop manufacturer is responsible for their operation, so contact them regarding any problems you have (you already paid them for this service, demand that they provide it!). Believe me, a company like Acer reporting a problem will have far higher priority than a lone individual having a problem.
