23268 Discussions
任务栏的Intel-Driver-and-Support-Assistant托盘图标提示有更新,打开网页后,提示“很遗憾,尝试扫描时出了些问题”
Jack698
这是日志
version.json
 "LatestVersion": "20.2.9.6",
 "ReleaseDate": "2020/03/03",
 "DownloadUrl": "https://downloadmirror.intel.com/28663/eng/Intel-Driver-and-Support-Assistant-Installer.exe",
 "DownloadSize": 2505392,
 "DownloadHash": "9dc435ee43100ab3b26efeefb2cc2813"
UpdateService.log.bak
Date/Time   Severity   Class   Method   Data   Message
2020/3/15 12:00:31   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   Manufacturer: TIMI
2020/3/15 12:00:31   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   Model: TM1801
2020/3/15 12:00:31   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Name: Microsoft Windows 10 专业版
2020/3/15 12:00:31   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Build: 10.0.18363
2020/3/15 12:00:31   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Language: 2052
2020/3/15 12:00:31   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Version: 1909
2020/3/15 12:00:31   Error   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   Failed to initialize Lantern Rock telemetry. No telemetry enabled
2020/3/15 12:00:31   Information   DSAUpdateService.Service      ()   Starting version 20.2.9.6
2020/3/15 12:00:31   Information   DSAUpdateService.Service      ()   DSA is installed
2020/3/15 12:00:31   Information   DSAUpdateService.Service      ()   LogDirectory: C:\ProgramData\Intel\DSA
2020/3/15 12:00:33   Information   DSAUpdateService.Service      ()   Update communication WCF service started
2020/3/15 12:00:33   Information   DSAUpdateService.Service      ()   Update Check poll started
2020/3/15 12:00:33   Information   DSAUpdateService.Service      ()   Successful startup
Tray.log
2020/3/15 星期日 12:00:31   Information   DSATray.App      ()   Started version 20.2.9.6
2020/3/15 星期日 12:00:31   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   Manufacturer: TIMI
2020/3/15 星期日 12:00:31   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   Model: TM1801
2020/3/15 星期日 12:00:32   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Name: Microsoft Windows 10 专业版
2020/3/15 星期日 12:00:32   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Build: 10.0.18363
2020/3/15 星期日 12:00:32   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Language: 2052
2020/3/15 星期日 12:00:32   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Version: 1909
2020/3/15 星期日 12:00:32   Error   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   Failed to initialize Lantern Rock telemetry. No telemetry enabled
2020/3/15 12:00:32   Information   DSATray.App      ()   Registered notification handlers
2020/3/15 12:00:33   Information   DSATray.App      ()   Tray communication WCF service started
2020/3/15 12:00:33   Information   DSATray.App      ()   _scanCheckInterval: 1000
2020/3/15 12:00:33   Information   DSATray.App      ()   lastCheckDetails.Ticks: 637198280448846605
2020/3/15 12:00:33   Information   DSATray.App      ()   lastNotifiedTicks: 0
2020/3/15 12:00:47   Information   DSATray.App      ()   Exiting with exit code 0
2020/3/15 星期日 12:01:47   Information   DSATray.App      ()   Started version 20.2.9.6
2020/3/15 星期日 12:01:47   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   Manufacturer: TIMI
2020/3/15 星期日 12:01:47   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   Model: TM1801
2020/3/15 星期日 12:01:47   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Name: Microsoft Windows 10 专业版
2020/3/15 星期日 12:01:47   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Build: 10.0.18363
2020/3/15 星期日 12:01:47   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Language: 2052
2020/3/15 星期日 12:01:47   Information   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   OS Version: 1909
2020/3/15 星期日 12:01:47   Error   Intel.DSA.CommonCore.Controllers.Telemetry.TelemetryController      ()   Failed to initialize Lantern Rock telemetry. No telemetry enabled
2020/3/15 12:01:47   Information   DSATray.App      ()   Registered notification handlers
2020/3/15 12:01:47   Information   DSATray.App      ()   Tray communication WCF service started
2020/3/15 12:01:49   Information   DSATray.App      ()   _scanCheckInterval: 1000
2020/3/15 12:01:49   Information   DSATray.App      ()   lastCheckDetails.Ticks: 637198280448846605
2020/3/15 12:01:49   Information   DSATray.App      ()   lastNotifiedTicks: 0
Alberto_R_Intel
sasda7, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
In reference to this scenario in order to try to fix this problem, please try the following troubleshooting steps:
Run the Intel® Driver & Support Assistant Uninstaller.
https://downloadcenter.intel.com/download/28181/Intel-Driver-Support-Assistant-Uninstaller?v=t
Restart and run the latest Intel® Driver & Support Assistant tool version 20.2.9.6.
https://downloadcenter.intel.com/download/28425/Intel-Driver-Support-Assistant?product=128824
Have you tried other browsers?
If the issue persists after trying the suggestions above, please provide the SSU report, to attach the report, once you choose "reply" select the "clip" icon on the lower-left corner.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
The latest Intel® Driver & Support Assistant Uninstaller log file: using File Explorer, search for DSAUninstaller.log
The latest Intel® Driver & Support Assistant log files: using File Explorer: go to folder = C:\ProgramData\Intel\DSA, and zip the Log files or entire folder.
Note: Uncheck Hide System files to see the AppData folder.
Show hidden files
https://support.microsoft.com/en-us/help/14201/windows-show-hidden-files
Albert R.
Jack698
Albert R., Glad to hear from you.
I try what you suggested, and it back to normal.
Thank you.
Jack698.
Alberto_R_Intel
sasda7, Thank you very much for letting us know those updates.
Perfect, excellent, it is great to hear that it is back to normal and now the Intel® Driver and Support Assistant is working properly.
Any other inquiries, do not hesitate to contact us again.
Albert R.
