22154 Discussions
显示无法调节亮度
Plee11
新买的INTEL NUC11PABi5无法调节亮度,如图。
我更新了WIN10系统至最新版,也安装了 英特尔驱动程度和支持助理,结果如下:
设备管理器中反复卸载删除显卡和监视器的驱动并重新安装,依然无法解决
求助各位大神解决方案,谢谢
DeividA_Intel
Hello Plee11,
Thank you for posting on the Intel® communities. I understand you are having issues with your (PRODUCT).
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Have you made any changes to the BIOS?
3. Have you checked this issue with Microsoft?
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Deivid A.
Plee11
OK, Thanks very much! I saved SSU scan-detail to a 220331.txt file already
(Virus scan in progress ...)
DeividA_Intel
Hello Plee11,
Thanks for the information provided, In this case, I would like you to try the following:
1. Check Windows updates for optional updates.
2. Load BIOS settings to default.
  1. Press F2 during boot to enter BIOS Setup.
  2. Press F9 to load defaults.
  3. Press F10 to save and exit BIOS Setup.
3. Try a BIOS recovery:
4. If the previous steps did not work, check with Microsoft since it may be related to the operating system (Windows).
Deivid A.
DeividA_Intel
Hello Plee11,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back.
Deivid A.
DeividA_Intel
Hello Plee11,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
