22889 Discussions
这是显卡坏掉了吗?
张先生8831
win11运行中突然黑屏,无法关机,只好强行关机,造成系统崩溃。重新安装win10后,四个显示器只亮一台。驱动替换为标准显示器,AMD的驱动程序无法安装。这是显卡损坏还是驱动程序有问题?
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
