22695 Discusiones
2 GPU: Intel Arc A380 8 display
EnriqueGJr
Novato
3.629 Vistas
Hi, I want to create a PC that is capable for 8 display with different content (web based content - power BI, Animation, Videos),
Is intel Arc A380 capable of doing it?
1080P displays required only.
0 kudos
7 Respuestas
DeividA_Intel
Empleados
3.572 Vistas
Hello EnriqueGJr,
Thank you for posting on the Intel® communities. I understand that you have some questions related to the Intel® Arc™ A380 Graphics.
Based on our website (ark.intel.com) the Intel® Arc™ A380 Graphics supports up to 4 displays and the resolution supported is:
Max Resolution (HDMI):
4096 x 2160@60Hz
Max Resolution (DP):
7680 x 4320@60Hz
If you have any questions, please let me know.
Deivid A.
EnriqueGJr
Novato
3.567 Vistas
Hello Deivid,
Sorry to Clarify we will buy 3 pieces of intel arc a380 and put it in a capable motherboard with 2 pcie 4 16x8 and 1 pcie 3 16x4 . Will i get 12 display (extended) out of it?
DeividA_Intel
Empleados
3.546 Vistas
Hello EnriqueGJr,
Thank you for the information provided
Deivid A.
DeividA_Intel
Empleados
3.432 Vistas
Hello EnriqueGJr,
Thanks for your patience. Based on the investigation, I would like to let you know that there should be no problem to enable the extended display/desktop (the Intel term MGPU Combined Display, aka MCD) with this configuration.
However, the platform performance will be capped by the lowest PCIe data throughput. If you have any questions, just let me know.
Deivid A.
DeividA_Intel
Empleados
3.377 Vistas
Hello EnriqueGJr,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
DeividA_Intel
Empleados
3.348 Vistas
Hello EnriqueGJr,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
EnriqueGJr
Novato
3.330 Vistas
Hi Deivid,
Thank you, we are in the process of purchasing this PC with 3 GPU , and 12 TV display to try in out
Responder
