22680 Discussions
2 monitor issue with nuc10i5fnh
DrZoidberg
Trying to connect 2 monitors to my NUC, one via USB-C (DP1.2) the other via HDMI 2.0b.
Both Monitors are AOC cu34g2x, so should be no issues there.
Problem as follows, i can run both Monitors in isolation, but as soon as i connect the 2nd, either by HDMI or DP the 2nd Monitor will not be detected.
For absolute clarity i'm trying to connect as per the first 2 display option example in the link
https://www.intel.com/content/www/us/en/support/articles/000056438/intel-nuc.html
All my drivers are up to date
I can run both monitors at the same time if i connect 1 directly to HDMI and the other from the Monitor HDMI via a HDMI to USB C lead into the NUC TB3,
HELP
DeividA_Intel
Hello DrZoidberg,
Thank you for posting on the Intel® communities. I want to understand what happened just as much as you do and to proceed further, I would like to confirm the following:
1. What is the BIOS version installed?
2. What is the graphics driver's version installed?
3. Did you test with different cables?
4. Have you performed any firmware updates to the monitors?
5. Just to confirm, the configuration only works if you use an adapter HDMI to USB-C?
Deivid A.
LeonWaksman
Hן @DrZoidberg
Are you following the procedure to detect the second monitor?
Leon
DrZoidberg
2nd Monitor is not detectable when connected via USB-C to DP when 1st Monitor is connected by HDMI, but will 2nd Monitor will work when 1st Monitor is disconnected
DeividA_Intel
Hello DrZoidberg,
Thanks for your response. In this case, can you provide these details?
Deivid A.
DrZoidberg
Hi Deivid A
1. What is the BIOS version installed? BIOS Version/Date Intel Corp. FNCML357.0062.2023.0719.2024, 19/07/2023
2. What is the graphics driver's version installed?  Graphic driver 31.0.101.2121
3. Did you test with different cables? yes, several including both vesa and non vesa certified cables
4. Have you performed any firmware updates to the monitors? Monitors are on latest drivers/software
5. Just to confirm, the configuration only works if you use an adapter HDMI to USB-C? yes, only way i can run 2 monitors together is one via hdmi to hdmi and the other hdmi to hdmi/usb-c adapter. if i go directly to usb-c only one monitor will work at a time
DeividA_Intel
Hello DrZoidberg,
Thanks for the confirmation. I was checking your AOC cu34g2x specifications and noticed that it only includes 2xHDMI and 2xDisplay port, it does not mention Thunderbolt support for video. It mentions a "USB fast-charge port" that usually is USB-C only, but in this case for power and not for video support.
I recommend you to get in contact with AOC to confirm this information and for advice. Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
DrZoidberg
@DeividA_Intel
Not sure what your point is?
Intel own advice is to connect the Monitors as i am trying, see this link
so connection from NUC to Monitor as follows
TB3/USB-C to Displayport
Is absolutely fine, no need to contact AOC
And anyway the connection works fine for a single monitor, the problem is when the second is connected via HDMI to HDMI
DeividA_Intel
Hello DrZoidberg,
I do apologize for the misunderstanding. I would like to continue with the investigation and I will require the following reports.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Provide the Report for Intel® Graphics Drivers with both monitors connected:
Deivid A.
DrZoidberg
Hi @DeividA_Intel
See attached reports,
For some reason windows will not allow me to download and install Intel Graphics Control Panel?
DeividA_Intel
Hello DrZoidberg,
Thanks for the information provided. I would like to let you know that for 6th Generation Intel® Core Processors and newer: The Intel® Graphics Control Panel has been discontinued from Microsoft and has been replaced with the Intel® Graphics Command Center.
Also, I will proceed to check the issue internally and post back soon with more details.
Deivid A.
DeividA_Intel
Hello DrZoidberg,
Thanks for your patience. From your report, you are using Windows 11 Enterprise and this operating system is not listed as supported/compatible for this NUC. I recommend you to test with one of the supported operating systems (Windows 11, Windows 10) and then, make sure you have both Firmwares are up to date (thunderbolt and HDMI).
Deivid A.
DrZoidberg
Hi @DeividA_Intel ,
From my understanding Windows Enterprise is not missing anything that would cause these issues, its simply a more comprehensive edition, no NUC is listed as supported with Enterprise.
I have run both Thunderbolt and HDMI updates and the problem remains
DeividA_Intel
Hello DrZoidberg,
I understand your concern. However, your NUC is compatible with
Windows 11 and Windows 10, even though Windows 11 Enterprise is working with your NUC, it may encounter unexpected issues like this one.
If possible, try any of the supported operating systems to confirm if the issue persists.
Deivid A.
DrZoidberg
Hi @DeividA_Intel
Sorry if i have this wrong, are you suggesting i buy another copy of windows 11 or 10 to try with the NUC?
DeividA_Intel
Hello DrZoidberg,
In this case, there is no need for you to buy a new license, you can test with a new install without a license just to make sure if this issue is related to the operating system or this NUC.
Thanks for your comprehension.
Deivid A.
DrZoidberg
Apologies for my ignorance, how do i do that?
DeividA_Intel
Hello DrZoidberg,
You can check this Microsoft forum where there are steps and recommendations on how to install Windows without a license. However, I recommend you to check with Microsoft to make sure you are following the right steps, you can mention that it is just for a test.
Forum: https://answers.microsoft.com/en-us/windows/forum/all/install-windows-10-without-product-key/f0b59b4f-b818-46f4-a0a6-63c85aca695f
Deivid A.
DeividA_Intel
Hello DrZoidberg,
I would like to know if you were able to use a supported operating system for your NUC or if you had troubles during the process.
Let me know if you need further support.
Deivid A.
DeividA_Intel
Hello DrZoidberg,
I was checking your thread and noticed that I have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
