I have a lenovo thinkcenter M920Q with an added DP. I have two LG monitors set at 4K. One allows me to set at 60HZ while the other at 30Hz. Both are using DP cables, and if I reverse the cables, the other screen now runs at 30HZ. Any ideas? I have the latest BIOS. The processors is the Intel UHD 630. on an Intel Core(TM) i5-8500T CPU @ 2.10GHZ
連結已複製
Hello SRoth5,
Thank you for posting on the Intel ® communities.
I would like to know if you are using the exact model of DP Cables with the system. This is important to make sure they are both working as intended. You can also try exchanging the one that doesn't deliver the 60Hz for testing purposes.
Please provide me with an System Support Utility report, this report can be generated from our tool, you can refer to the link below so you can download it:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Make sure to attach the created report to this thread.
David V
A Contingent Worker at Intel
Ok. I 've tried switching out DP cables. that did not work. Then I actually switched the monitor with an identical monitor. The new one allows both monitors 4K at 59HZ (2160x3840). Even though under modes I see 2160 x 3840 True color (32 bit) 59 HZ and 60 HZ for one of the monitors (and 60 Hz) is selected only 59 Hz shows as the refresh rate. ON the other monitor only 59Hz shows up (with the previous identical model monitor (only 30 hz) showed up. when I take the swtiched out monitor (that only went to 30 hz) and hook it up to a different computer - it allows 4K at 60HZ. when I bring it back here - it drops down to 30 HZ.
I'M BAFFLED. as to what is going on. The "defective" monitor is fine being used for a different computer. WE have 3 of them ( LG 24UD58) and it has 2 HDMI 2.0 ports and a DP.
hard to see but shows refresh rate at 59HZ - even thought 60Hz was selected.
Hello SRoth5,
Thank you for your response.
When you say you tried the "defective" LG monitor in the different computer, did you try it along with another one as a second monitor? This is to see if that monitor works properly when using dual-monitor or only when being the only monitor connected.
Did you try HDMI to see if the resolution is possible? Just for testing purposes. Make sure to update the drivers of the monitor to see if this helps. Refer to the link below:
https://www.lg.com/us/support/product/lg-24UD58-B.AUS
* Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there. *
I hope this helps.
David V
Hello SRoth5,
I understand now, thank you for clarifying the situation with the monitors. I can see that you attached 2 images but I am unable to see them. Can you please attach this files directly in the thread? This is because if you do it through the e-mail I am unable to see them.
How can you tell the refresh rate goes down to 59HZ when in the main screen? Can you please provide me with a graphics report? To do so, please follow the steps in the link below:
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics-drivers.html
David V
and second one. when I go to display properties both allow me to select 60Hz but they show up as under advanced display properties at 59HZ
I'm using 2 LG monitors that now allow me to go to 59HZ
when I used the older LG monitor (same make and model) as a 2nd monitor it would only allow 30HZ. When I set it up as a single monitor, it would allow 60Hz. a few days ago, when I dropped down to one monitor, it only allowed 30HZ but I can't recreate that anymore.
System
Intel(R) UHD Graphics 630
Report Date: Friday, August 9, 2019
Report Time [hh:mm:ss]: 2:40:59 PM
Driver Version: 26.20.100.6860
Operating System: Windows* 10 Pro (10.0.17134)
Physical Memory: 32607 MB
Vendor ID: 8086
Device ID: 3E92
Device Revision: 00
Graphics Output Protocol (GOP) Version: 9.0.1080
Current Resolution: 2160 x 3840
Processor: Intel(R) Core(TM) i5-8500T CPU @ 2.10GHz
Processor Speed: 2112 MHz
Processor Graphics in Use: Intel(R) UHD Graphics 630
Shader Version: 5.1
OpenGL* Version: 4.6
OpenCL* Version: 2.1
Vulkan* Version: 1.1.103
CUI Appx Version: 3.2.0.0
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 12.0
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Digital Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Device Type: DisplayPort
Maximum Image Size
Horizontal Size: 23.62 inches
Vertical Size: 13.39 inches
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1280 x 1024 (60p Hz)
1600 x 900 (60p Hz)
1920 x 1080 (60p Hz)
2560 x 1440 (60p Hz)
3840 x 2160 (60p Hz)
3840 x 2160 (30p Hz)
Power Management Support
Standby Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 1E 6D 09 5B F4 57 01 00
0A 1C 01 04 B5 3C 22 78 9E 30 35 A7 55 4E A3 26
0F 50 54 21 08 00 71 40 81 80 81 C0 A9 C0 D1 C0
81 00 01 01 01 01 4D D0 00 A0 F0 70 3E 80 30 20
65 0C 58 54 21 00 00 1A 28 68 00 A0 F0 70 3E 80
08 90 65 0C 58 54 21 00 00 1A 00 00 00 FD 00 38
3D 1E 87 38 00 0A 20 20 20 20 20 20 00 00 00 FC
00 4C 47 20 55 6C 74 72 61 20 48 44 0A 20 01 49
02 03 11 71 44 90 04 03 01 23 09 07 07 83 01 00
00 02 3A 80 18 71 38 2D 40 58 2C 45 00 58 54 21
00 00 1E 56 5E 00 A0 A0 A0 29 50 30 20 35 00 58
54 21 00 00 1A 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C8
* Digital Display2 *
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1600 x 900 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 1E 6D 09 5B 7C C2 01 00
07 1C 01 04 B5 3C 22 78 9E 30 35 A7 55 4E A3 26
00 4C 47 20 55 6C 74 72 61 20 48 44 0A 20 01 59
* Other names and brands are the property of their respective owners.
Display 1
Report Time [hh:mm:ss]: 2:41:23 PM
Vendor ID: 8086
Device ID: 3E92
Device Revision: 00
Shader Version: 5.1
Active Displays: 2
* Digital Display *
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1600 x 900 (60p Hz)
Raw EDID:
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1600 x 900 (60p Hz)
Raw EDID:
display 2
Report Time [hh:mm:ss]: 2:41:43 PM
Vendor ID: 8086
Device ID: 3E92
Device Revision: 00
Shader Version: 5.1
Active Displays: 2
* Digital Display *
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1600 x 900 (60p Hz)
Raw EDID:
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1600 x 900 (60p Hz)
Raw EDID:
Hello SRoth5,
I was analyzing the reports you have attached and I can see that your Windows build is not the latest. If possible, please attempt to update it, refer to the link below for more information on how to do so:
https://www.microsoft.com/en-us/software-download/windows10
Something else is the graphics driver installed, after upadting the O.S, please try updating your graphics driver, refer to the link below:
https://downloadcenter.intel.com/download/28991/Intel-Graphics-Windows-10-DCH-Drivers?product=126790
Once all this has been done, check to see if the issue persists. I would also like to know what you meant when you said "an added DP", does this mean you added an adapter to be able to use Display Port?
Let me know so I can assist you further.
David V
Hello SRoth5,
Please provide me with a graphics report to see if the information shows different after the update. This report can be created by following the steps in the link below:
Please attach the file in the thread.
David V
Hello SRoth5,
I do not see the file attached, please try attaching it directly in the thread, if you attached it on an e-mail it will not be shown.
David V
Report Date: Wednesday, August 28, 2019
Report Time [hh:mm:ss]: 1:18:37 PM
Operating System: Windows* 10 Pro (10.0.18362)
Vendor ID: 8086
Device ID: 3E92
Device Revision: 00
Shader Version: 5.1
Active Displays: 2
* Digital Display *
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1600 x 900 (60p Hz)
Raw EDID:
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1600 x 900 (60p Hz)
Raw EDID:
Report Time [hh:mm:ss]: 1:18:21 PM
Vendor ID: 8086
Device ID: 3E92
Device Revision: 00
Shader Version: 5.1
Active Displays: 2
* Digital Display *
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1600 x 900 (60p Hz)
Raw EDID:
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1600 x 900 (60p Hz)
Raw EDID:
