22817 Discussions
2nd monitor using DP 4K resolution at 30HZ vs 60Hz
SRoth5
I have a lenovo thinkcenter M920Q with an added DP. I have two LG monitors set at 4K. One allows me to set at 60HZ while the other at 30Hz. Both are using DP cables, and if I reverse the cables, the other screen now runs at 30HZ. Any ideas? I have the latest BIOS. The processors is the Intel UHD 630. on an Intel Core(TM) i5-8500T CPU @ 2.10GHZ
David_V_Intel
Hello SRoth5,
Thank you for your response.
I was reviewing the information attached and it seems like the monitors should output 60Hz as you mentioned before. I was checking also our previous conversations and I can see that you mentioned you added an extra card to get one more display port, how did you add this card? What card was it?
Let me know so I can assist you further.
David V
A Contingent Worker at Intel
David_V_Intel
Hello SRoth5,
Were you able to check my previous post?
Let me know if you need more assistance.
David V
David_V_Intel
Hello SRoth5,
Please contact us back if you need more assistance.
David V
