Comunicados
22772 Discussões
3 segundos delay audio / 3 seconds audio delay
Photobias
Principiante
5.651 Visualizações
Hi.
I just upgraded my pc to an 11700, I did almost anything, everytime I want to hear something, must wait 3 seconds to sound come audible... It`s frustrating
Driver, regedit edit, didn't solve the problem
14 Respostas
David_G_Intel
Moderador
5.624 Visualizações
Hello Photobias
Thank you for posting on the Intel️® communities.
Please share with us the Intel® System Support Utility (Intel® SSU)  results  to investigate:
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
Please share with us the following:
  • Which processor did you use before?
  • Did you reinstall the drivers and operating system?
  • Did it work fine before?
  • Does this happen with wireless and wired connections?
  • Which drivers did you try?
  • Does this happen with different audio devices?
David G
Intel Customer Support Technician
Photobias
Principiante
5.618 Visualizações
  • Core i3 10100
  • Yes. Upgrades or not, same issue.
  • Yes (whit regedit edit)
  • I don't use wireless
  • From Asus, Intel, Beta... Windows---
  • I don' use another audio device
Calinatus
Novato
5.618 Visualizações
I've been experiencing this problem on my other (HP) laptop every time after a new big Windows update (although it should be noted that that laptop is 'enrolled' in Windows Insider previews).
I solved this by using this workaround: https://h30434.www3.hp.com/t5/Notebook-Audio/3-seconds-delay-to-play-sounds-through-headphone/td-p/6631359/page/2
However, I have thenceforth not found a permanent, official solution to this problem.
Photobias
Principiante
5.614 Visualizações
I already this regedit edit, no luck, even with "all zeros", nothing.
Photobias
Principiante
5.580 Visualizações
Nobody???
I format 4 times, problem persists, it's very frustrating, year 2021 with this kind of problems... and worse, nobody gives a solution.
David_G_Intel
Moderador
5.569 Visualizações
Thanks for the information provided Photobias, we are working on this request, updates will be posted on the thread.
David G
Photobias
Principiante
5.556 Visualizações
I can confirm it's the UHD 750 audio problem, I just tested with Oppo DAC and no problem, pause video, resume, instant audio again, no 3 seconds of silence.
David_G_Intel
Moderador
5.522 Visualizações
Thank you for the update Photobias. We understand that the Oppo DAC doesn't give you any problems, could you please describe the device you used before for audio? (speakers, display speakers, headset, etc) Including the brand, model and how you connect this device.
We also noticed that you're using the Windows Insider version 19043, this can be the root of the behavior and we highly recommend rolling back to the previous stable version. Please check with Microsoft* for instructions.
Finally, we recommend the use of the OEM drivers, specially Realtek. You're using version 10.0.19041.1, the latest one available is Version 6.3.960. You can check with the motherboard manufacturer for instructions..
David G
Photobias
Principiante
5.512 Visualizações
Before 11700? Core I3 10100 with Asus STRIX B460-I GAMING, had to edit registry.
Sound via HDMI to Sony 55 905F now.
I tried with 2 different versions of Windows, 20H, 21H... same problem... system must be updated, I won't use older system.
I don't use Realtek audio but I will search driver...
I think it's a regedit thing, there's a lot of people with this problem, I haven't found a correct parameter of regedit yet.
Photobias
Principiante
5.503 Visualizações
Realtek  Version 6.3.960 installed, problem persists.
Photobias
Principiante
5.462 Visualizações
So... any solution?
David_G_Intel
Moderador
5.449 Visualizações
David G
Photobias
Principiante
5.398 Visualizações
Beta driver didn't solve the problem.
Have to play this https://www.youtube.com/watch?v=X0RK2jz5HOI to avoid de 3 seconds silence.
David_G_Intel
Moderador
5.388 Visualizações
We noticed you contacted live support and you have been working with them to resolve this request. This thread will be closed but if you need any additional information you can let the live support team know.
David G
Responder
