Get the samsung S34E790C monitor with standard resolution and refresh rate 3440 x 1440, 50 Hz.
And can't increase the refresh rate more than 30 Hz.
Have the Intel HD Graphics 4000 (3rd gen), with the last driver version.
Any ideas how to increase this rate to the needed 50 Hz? Does my hardware (or driver) support this issue?
Additional information:
Intel(R) HD Graphics 4000
Report Date: Sunday, November 8, 2015
Report Time [hh:mm:ss]: 6:57:34 PM
Driver Version: 10.18.10.4276
Operating System: Windows* 10 Pro Insider Preview (10.0.10240)
Default Language: Russian (Russia)
Installed DirectX* Version: 12.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 6029 MB
Processor: Intel(R) Core(TM) i7-3517U CPU @ 1.90GHz
Processor Speed: 2395 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 0.0
Current Resolution: 1366 x 768
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Built-in Display *
Display Type: Digital
Serial Number: LGD033f
DDC2 Protocol: Supported
Gamma: 2,2
Connector Type: LVDS
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 12,2 inches
Vertical Size: 6,69 inches
Supported Modes
1366 x 768 (60p Гц)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 3F 03 00 00 00 00
00 15 01 03 80 1F 11 78 EA D1 05 95 58 57 8F 29
20 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 12 1B 56 68 50 00 12 30 20 20
35 00 36 AE 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 34 30 57 48 32 2D 54 4C 45 32 00 CB
* Digital Television *
Serial Number: SAM0bfe
Gamma: 2,2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 31,5 inches
Vertical Size: 12,99 inches
Supported Modes
640 x 480 (60p Гц)
640 x 480 (67p Гц)
640 x 480 (72p Гц)
640 x 480 (75p Гц)
720 x 400 (70p Гц)
720 x 480 (60p Гц)
720 x 576 (50p Гц)
800 x 600 (56p Гц)
800 x 600 (60p Гц)
800 x 600 (72p Гц)
800 x 600 (75p Гц)
832 x 624 (75p Гц)
1024 x 768 (60p Гц)
1024 x 768 (70p Гц)
1024 x 768 (75p Гц)
1152 x 870 (75p Гц)
1152 x 864 (75p Гц)
1280 x 800 (60p Гц)
1280 x 720 (60p Гц)
1280 x 1024 (60p Гц)
1280 x 720 (50p Гц)
1280 x 1024 (75p Гц)
1440 x 900 (60p Гц)
1600 x 900 (60p Гц)
1680 x 1050 (60p Гц)
1920 x 1080 (30p Гц)
1920 x 1080 (60p Гц)
1920 x 1080 (50p Гц)
1920 x 1080 (24p Гц)
2560 x 1440 (60p Гц)
2560 x 1080 (60p Гц)
3440 x 1440 (30p Гц)
3440 x 1440 (50p Гц)
Raw EDID:
00 FF FF FF FF FF FF 00 4C 2D FE 0B 38 52 4C 30
27 18 01 03 80 50 21 78 2A 52 95 A5 56 54 9D 25
0E 50 54 BF EF 80 71 4F 81 00 81 C0 81 80 95 00
A9 C0 B3 00 01 01 9D 67 70 A0 D0 A0 22 50 30 20
3A 00 1D 4D 31 00 00 1A 00 00 00 FD 00 18 4B 1E
5A 1E 00 0A 20 20 20 20 20 20 00 00 00 FC 00 53
45 37 39 30 43 0A 20 20 20 20 20 20 00 00 00 FF
00 48 54 48 46 43 30 30 31 36 32 0A 20 20 01 B4
02 03 1D F1 48 90 04 1F 13 03 12 20 22 23 09 07
07 83 01 00 00 67 03 0C 00 10 00 80 3C 9F 3D 70
A0 D0 A0 15 50 30 20 3A 00 1D 4D 31 00 00 1A 7E
48 00 E0 A0 38 1F 40 40 40 3A 00 1D 4D 31 00 00
18 02 3A 80 18 71 38 2D 40 58 2C 45 00 1D 4D 31
00 00 1E 56 5E 00 A0 A0 A0 29 50 30 20 35 00 1D
4D 31 00 00 1A 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8B
* Other names and brands are the property of their respective owners.
Any propositions?
Have you loaded any monitor INF file?
By loading INF, it will interact with the Vbios and monitor's EDID. Please bear in mind that your computer manufacturer may impose some restrictions according to their market target or company needs.
After loading monitor drivers, make sure you test different video cables and check graphics control panel for higher refresh rates.
Allan.
