23780 Discussions
4644 will not install
Joseph64
they start ,get to the loading screen and then just stop. no error code. I've tried fixing my .net installation but to no avail.
Please do not give me the usual how to install arc drivers , I've installed every one that you've came out with using ddu in safe mode.
While im at it why does the driver page keep telling me to use asrock drivers? i have an asrock motherboard but the graphics card is intel an arc a770 16gb.
ASRock X570 Steel Legend WiFi ax
Jean_Intel
Hello Joseph64,
Thank you for trying the recommendations we requested before.
Unfortunately, after checking the new system report, we noticed that the Operating System build remains the same (22000). We recommend you contact Microsoft support for further instructions about the Operating System update process.
We also would like to inform you that we have a newer driver that was released last week. The new version is 31.0.101.4669. if you can, try installing this driver and see if the issue remains.
Jean O.
Jocelyn_Intel
Hello, @Joseph64
Thank you for posting on the Intel® communities. I will do my best to assist you here.
Have you tried installing it without using DDU (normal installation)? Does the same issue happen? This is the link to the latest driver 31.0.101.4644, in case you need it.
Jocelyn M.
Joseph64
yes , I've tried normal in windows, I've tried ddu in safe mode nothing works , I've emptied my appdata/local/temp folder, it starts says loading and then abruptly stops with no error or anything.
all other beta and normal up to this point have been no problem, besides sometimes arc control installs and sometimes not
Jean_Intel
Hello Joseph64,
We understand that after trying multiple driver update options, the issue remains. Please, share a video of the system behavior when processing a manual driver installation, of the latest driver version, and an old driver version. This would help us further troubleshoot this matter.
Jean O.
Joseph64
This is the 4644 ill do another one later
Jean_Intel
Hello Joseph64,
Thanks for sharing the video recording for the installation process of the new 101.4644 driver. We understand that you need more time to record a video for the installation process of an older driver. Please note that the more information we have, the better.
Jean O.
Joseph64
I cant give you a video of the older drivers because of the 71mb max file size but they just go normally no problem
Jean_Intel
Hello Joseph64,
We understand that you are unable to share a video file for the driver installation of an older driver.
We will now continue to look into this matter internally. We will post back as soon as we have further details.
Jean O.
Jean_Intel
Hello Joseph64,
We appreciate your patience.
After checking the Intel SSU report you shared, we noticed that:
  • Your Operating System build is reported to be 22000, and the latest build version is 22621.2215. We recommend you update your Operating System to the latest build available
  • The BIOS version is 3.60; after checking the ASRock website, the latest version available is the L5.01. You should update the BIOS to the newest version available on the ASRock website. If you need any more help with the BIOS update, you should contact ASRock support for instruction on how to update it.
Once you update your system, try installing the driver one more time, and let us know the outcome.
Jean O.
Joseph64
no change , i tried after updating windows and then again after bios updates i scanned again if you would like to look
Jean_Intel
Hello Joseph64,
Jean O.
Joseph64
That was it! windows wouldnt update i had to do it with the update manager now everything works as it should thanks!
Jean_Intel
Hello Joseph64,
We are glad to know that you have been able to update your Graphics Driver after updating the Windows through the update manager. Since your issue is now solved, we will close this thread. If you need additional information, please submit a new question since this thread will no longer be monitored.
Jean O.
