23854 Discussions
4GB memory for Q45
I have a Lenovo M58p and it has the Intel Q45 mainboard with a Intel 4500 intergrated graphics card.
It came with 2GB of RAM, however I have now bought a Kingston 4GB RAM.
It does not work
The details for the memory are:
KVR1066D3D4R7S/4G
It is PC3 - 8500 CL7 reg
Shouldnt this be supported by the M58p?
I have installed the latest BIOS, which is supposed to have support for 4GB ram "pieces".
Allan_J_Intel1
<!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0in; margin-right:0in; margin-bottom:10.0pt; margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} p {mso-style-noshow:yes; mso-style-priority:99; mso-margin-top-alt:auto; margin-right:0in; mso-margin-bottom-alt:auto; margin-left:0in; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"Times New Roman";} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} -->
Memory upgrade depends on the computer manufacturer or the motherboard maker. The Intel chipset supports up to 16 GB at 1333MHz / 1066MHz / 800MHz. I recommend contacting Lenovo for memory compatibility information.
See more chipset details below:
http://ark.intel.com/chipset.aspx?familyID=36522&code=Intel%C2%AE+Q45+Express+Chipset
Yes, and thats the strange part.
According to this:
http://www.valueram.com/datasheets/KVR1066D3D4R7S_4G.pdf http://www.valueram.com/datasheets/KVR1066D3D4R7S_4G.pdf
I cannot see that the RAM is not beeing supported? Is it anything I've missed?
It is :
PC3-8500
1066 CL7 SDRAM
Should not this be OK?
Still haven't solved this, I have now flashed the latest Lenovo BIOS
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-70892 http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-70892
and it is still just "beeping" at startup.
Could the RAM stick be DOA?
I've also tried the RAM in a XFX mobo (X58i) and a G'byte X58 UD3R 2.0
Same result.
