22656 Discussions
4K 60Hz On Intel UHD Graphics 630 via Type C To Type C Thunderbolt 3
MayMeteonyker
I have Problem with my pc and monitor can run on 4K 30Hz not 4K 60Hz
connection cable with type c from mainboard to typc c monitor
System Hardware
- Cpu: i9 9900ks with Intel® UHD Graphics 630
- Mainbord: Z390 Aorus Xtreme
Spec: Integrated Graphics Processor+Intel® Thunderbolt™ 3 Controller:
  1. 2 x Intel® Thunderbolt™ 3 connectors (USB Type-C™ ports), supporting DisplayPort and Thunderbolt™ video outputs and a maximum resolution of 4096x2304@60 Hz
    * Because of the limited I/O resources of the PC architecture, the number of Thunderbolt™ devices that can be used is dependent on the number of the PCI Express devices being installed. (Refer to Chapter 1-7, "Back Panel Connectors," for more information.)
    * Support for DisplayPort 1.2 version
Link: https://www.gigabyte.com/Motherboard/Z390-AORUS-XTREME-rev-10/sp#sp
- Monitor: Philips 436M6VBRAB/67
1. Please notice that your display
works best at native resolution
of 3840 x 2160 @ 60Hz. For best
display quality, please follow this
resolution recommendation.
Recommended resolution
VGA: 1920 x 1080 @ 60Hz
HDMI 2.0: 3840 x 2160 @ 60Hz
DP v1.1: 3840 x 2160 @ 30Hz
DP v1.4: 3840 x 2160 @ 60Hz
USB C: 3840 x 2160 @ 60Hz  <use this type>
Link: https://www.download.p4c.philips.com/files/4/436m6vbrab_67/436m6vbrab_67_dfu_aen.pdf
- Display Cable: Thunderbolt 3 USB C Cable 0.8m From Apple
Transfer data at up to 40 Gbps
USB 3.1 Gen 2 data transfer at up to 10 Gbps
DisplayPort video output (HBR3)
Connect to Thunderbolt 3– or USB-C–enabled devices and displays
Up to 100W Power Delivery
Etched Thunderbolt logo helps it stand out from other cables
Daisy-chain up to six Thunderbolt 3 devices
https://www.apple.com/th-en/shop/product/MQ4H2ZA/A/thunderbolt-3-usb%E2%80%91c-cable-08-m
thank you for answer
DeividA_Intel
Hello MayMeteonyker,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer  https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Provide the Report for Intel® Graphics Drivers:
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html
3. Is this issue recent? if so, did it happen after a system update?
4. Did you update the firmware for your monitor?
5. Did this configuration (4K 60Hz) before? (Ex: Monitor Philips with another computer or same computer with another laptop)
Deivid A.
MayMeteonyker
1.  details about the system
Answer: save to file attach Intel SSU.txt
Answer: save to file Intel® UHD Graphics 630 - Thursday, 25 March 2021.txt
3. Answer: After Update Intel UHD Driver.
Answer: i never up frimware monitor.
Answer: I've set it up before with gtx 1080 via display port, hdmi and via type c to type by laptop
in my laptop HP Pavilion x360 Convertible 14-dw1047TU can run on 4k 60hz
now after i'm update last driver type c to type monitor have blank screen when entering windows
in advance display setting display show error message "Display 1 isn't active" i try active display in Intel Graphics Command Center.  not responding.
if me uninstalll intel driver my screen is come back.
n_scott_pearson
The GTX 1080 has support for DisplayPort 1.4 (while UHD 630 only has DisplayPort 1.2). This means that, even with the loss of half of the channels in a USB-C connection, it is still capable of supporting 4K@60Hz. Bottom line, that's not an apples-to-apples comparison. With DisplayPort 1.2 and USB support in simultaneous use, you are limited to 4K@30Hz.
MayMeteonyker
What do i have to do To be able to run the display at 4K 60Hz
n_scott_pearson
Are you connecting the monitor with a USB-C-to-USB-C cable? Does the monitor offer USB port(s)?
If the answer to both questions is yes, then 4K@30Hz is the maximum attainable. Why? Well, (a) you only have support for DisplayPort 1.2 - which means best you can do is 4K@60Hz - and (b) when USB is supported, only 2 of the 4 lanes are available for DisplayPort usage - which means half of 4K@60Hz which is 4K@30Hz.
DeividA_Intel
Thank you for the information provided
Deivid A.
DeividA_Intel
Based on the tests and reports, I would like to inform you that this issue may be related to external factors such as:
- Cable used, try with a display port if possible or another USB-C.
- Motherboard limitation, check with motherboard manufacturer.
- Bandwidth limitation, as n_scott_pearson mentioned.
My recommendation will be to try with different cables and check with the motherboard manufacturer for more steps (driver/BIOS). Also, you may find helpful the following information:
1. https://www.intel.com/content/www/us/en/support/articles/000023945/graphics.html
2. https://ark.intel.com/content/www/us/en/ark/products/192943/intel-core-i9-9900ks-processor-16m-cache-up-to-5-00-ghz.html
Deivid A.
DeividA_Intel
Were you able to check the previous post and try the steps suggested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
